Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Not spraying The machin e is new and i use it a few days ago, we cleaned it inside and out, it is not spraying any cleaner or water. Can you help me?
    President:
  • 1,673 Answers
• tanks are not sealed into receivers
• faulty auto load receiver
• pinched/clogged line
• defective component allowing air into system
• pump not mounted so it can move freely
• defective bridge rectifier
• clogged heater
• defective pump
• defective circuit board
another is the spray nozzles are clogged.
Posted on Jun 08, 2008
Does not spray cleaner
It helps to always run hot water in the soap holding tank after you have cleaned the carpet to make sure the soap does not dry inside and clog. Make sure that the dirty tank water filter is clear of debris, I have noticed that if it is clogged it won't spray out solution. Another thing to try is, it usually will always spray out of handheld cleaning attatchment. steve
Jun 06, 2010 | Bissell 1699 ProHeat Clear View Upright...
My bissell carpet shampooer won't spray out water
The tubes inside the machine are probably clogged. Dismantle top hood and disconnect the three lines at the pump, open up entire top housing and inspect heater. Disconnect two tubes and heater and blow out with air compressor. That will spray all the junk, soap that has built up and your machine will be good as new. If you can't do this yourself, contact bissell and ask where your local repair center is
Aug 29, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Wont spray soap
Please look at my other posts for this solution
Aug 24, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
No water or solution spraying
Used an air compressor to clean out the clogged tubes
Jul 18, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
A solution to many "non-spray" problems.
The Scotchguard is going to be dicey inside the Bissell, yes, as you have learned the hard way.
I think the Bissell and the Hoover shampoos sold for their carpet cleaning machines are reasonably safe to use in the Bissell. My own personal favorite for use with the Bissell is the Hoover Premium Pet Formula, which is pricey but effective even if you don't own pets. I also pre-treat stained areas with Resolve Carpet Cleaner, a few minutes before using the Bissell.
I don't know what will happen with your home brew containing Dove. It may work well.
Jun 06, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
My Bissell shampoo machine will not spray either water or soap
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
yuet
Oct 28, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell carpet cleaner won't spray water or cleaner
If I may! In most cases the heater is clogged. It might be clogged with soap that has harden over time. You need to take the handle apart. You will see a metal box(thats the heater) besides the wires there are two tubes connected to the heater. remove the tubes but label or watch which tube goes where. now turn the heater upside down. there are 6 screws on the side and 1 in the middle. remove them carefully. the 6 on the side have a small gaskets under them..you don't want to lose them. the 1 in the middle has no gasket, now the bottom plate of the heater can be taken off (there is a gasket with that plate ...be careful . you will now see the long channels inside the heater and need to clean it. the holes where the tubes where connected have to be clean also but carefully. the metal is soft.so it bends. now put it all back. hope this helps. if you want to keep this from happening.the best way is to run clear water after you are done.this will remove any soap in the machine which will harden after the machine drys out. hope I helped .
and to mr. reddevil6 I am learning lots from you. Thanks
Nov 06, 2007 | Bissell ProHeat Turbo Deep Cleaner Upright...
Hoover steam cleaner
Is it spraying and sucking up ok? Check the filter inside the dirty water tank, it needs a 1/4 in. gap from the top to the top of the filter. If it isn't spraying out a good stream along the bottom, maybe running a mix of vinegar and water may clean out the lines to help it spray better.
Nov 02, 2007 | Hoover F7431-900 SteamVac Vacuum
Bissell ProHeat Carpet Steam Cleaner stopped spraying.
The problem was a clogged heating unit which is located in the lower handle. There are two clear hoses going up the inside of the left leg of the lower handle that go to the heater and to the in-line water switch all within the lower handle. I unplugged the metal heating unit water lines and electrical connections (label the connections as you take them apart if you have a hard time remembering things...there were seven connection in all be it water and/or electrical). Removed the heat unit out and then removed the 6 screws holding the heater cover. Inside was a white powdery pasty debris (lime deposit ?) and the water path was clearly blocked in four different places. I cleansed the water trough with a little water and soft toothbrush and several toothpicks then reassembled. If you need new washers go to Orchard or ACE hardware. Take the old rubber washers(they are red) with you for comparison. I didn't need new washers...I just gently cleansed them. I immediately ran clear water through the machine and actually cleaned the carpet with a water rinse only. Will go back and finish the carpet the right way tomorrow. I had only used my machine three times before this happend over a three year period. A friend told me to always rinse it two maybe three times with clear water after using it and before storage. This took me exactly 42 minutes to disassembly and reassemble. Cost savings is several hundred dollars since I have a 5 bdrm house and would need a professional cleaner to do the small dirty traffic lanes all around the house.
Sep 29, 2007 | Bissell 7920 ProHeat Pro-Tech Upright...
Will not spray
I have the same problem. I took it apart and found that the water pump had leaked and burned out the water pump motor. It's a $20 part.
Aug 16, 2007 | Bissell 1425 Little Green ProHeat Handheld...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
83 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
