Question about GE 21018GE3 Cordless Phone
Low battery problem
I have been using my GE21018GE3 around two years, recently both of two handsets when I use them around 7 or 8 minutes, they will show "Low Battery" even they are always in charging set.
So what is the problem, is the battery going wrong or else?
Thanks/Lisa
    Guru:
  • 859 Answers
Although your batteries are exhibiting a charge memory effect a little early, it doesn't surprise me too much after the phones are in use for two years.
You need to replace the batteries in your cordless phones. These you can find at any Radio Shack. Once yo have installed the new batteries you want to let both batteries go dead from use, keep them off the charger stand for this break in period. If you can do this your phones batteries will last longer.
For more information on rechargeable battery memory effect read this article.
Regards and thanks for using Fixya.
Posted on Jun 08, 2008
How long do batteries last in a Three Handset VTECH 5.8 Digital Phone System?
batteries last up to 3 years and from e-bay are a fraction of that price
as for time in use should be at least 1 hour for a good battery
it is vital that after use you return the phone to the charge cradle
ensure that charger is operational
Apr 03, 2017 | Vtech Cars & Trucks
When i press a key it takes around 5 to 10 seconds for the screen to change.other case, when i press answer key(call in) it will hang.these things occured around 2 years after i bought it.for info, the...
Handsets that run slow, or freeze up, are in need of resetting, and to do this, you will simply take the battery out of the handset while it is powered on, let it sit for 1 minute, then reinstall the battery and power it back up. If this does not resolve the issue then you may be looking at a more serious issue, and may need to repair, or replace the handset.
Mar 30, 2011 | Nokia 5800 XpressMusic Smartphone
Recently upgraded my compaq presario c502us laptop from Vista Basic to Windows 7 Pro. Battery goes from 99% charge to nothing within 10 minutes... must use the power cord all of the time. Most of the...
The best fix you can get is a new battery.
Have you reviewed the Microsoft Hardware and software compatibility list concerning your computer and its equipment? Might be worth a look-see
Thanks for your visit today.
Jan 30, 2011 | HP Compaq Presario C502US Notebook
I've had this cordless phone with 7 handsets for many years. Recently most of the phones have been disconnecting mid call and the screen reads "no link to base." Is it possible that many of the phones...
it is likely they need new batteries. but first place each handset in the base (not the standalone charger) and wait for the battery light to flicker. try the phone then. if you do change the batteries in any of the handsets you will need to repeat doing that procedure of placing the handset in the base.
robert
Dec 02, 2009 | Panasonic KX-TGA271 Cordless Expansion...
Find HS doesn't work
Had sets will not beep if the battery is too low or drained of its charge. The power for the beep needs to come from a good battery charge, so if you are missing a hand set and its been out of the charge cradle for a long time, or the unit is more than 4 years old and the batteries wont charge anymore, then you can't use the find handset feature and probably can't use it to talk as well.
If you know that the batteries are good, then there are 2 other possibilities: the seek signal needs to be reset by unplugging power to the base unit for one minute and allowing the circuits to reset themselves, or the seek button is not making good contact inside and this would require someone with knowledge to open the base unit and clean or repair the button contacts. Finally, many hans sets have an on/off/standby feature. If the handset is in off position, the it isthe same as if you removed the battery and it will never beep; it must be on standby.
Oct 04, 2009 | Uniden DECT 6.0 Cordless Telephone...
I have a Panasonic KX-TG6051CM
I had the same problem, and it seems that the battery charging circuit in the handset had locked up, constantly charging the battery until it overheated. I was able to reset the circuit in my handset by completely draining the battery. Here is the procedure:
1. Remove the handset from the charging cradle, and leave it on for a few days until the battery runs out, and the handset finally turns off. At his point, the battery will be very low, BUT NOT COMPLETELY DRAINED.
2. Next, you must manually drain the charge remaining in the battery by shorting out the two contacts on it. Shorting won't damage the battery, since it is holding very little charge at this point. An easy way to physically do this is to remove the battery, and place a piece of thin wire across the the two contacts of the HANDSET. I am referring to the contacts inside the handset that connect to the battery, NOT the contacts on the bottom outside that connect the handset to the charging cradle. Next, put the battery back in, sandwiching the wire between the battery's contacts and those inside the handset. This will hold the wire in place. DO NOT PUT THE HANDSET BACK INTO THE CHARGER, WITH THE BATTERY SHORTED OUT.
3. Wait about 30 minutes for the battery to completely die. Remove the jumper wire, and but the handset back into the charger.
4. If the battery was fully discharged , you will get a message on the handset telling you that you should let it will charge for 7 hours. If you do not get this message, then either the battery was not fully discharged, or your problem is different from mine. Try the procedure again in Step 3 for another 30 minutes to discharge the battery some more.
5. If you get the "Wait for 7 hours to charge" message on the handset, then leave it in the charging cradle for the 7 hours requested. After that, it should work fine.
Let me know how you make out.
Mar 24, 2008 | Panasonic KX-TG6051M Cordless Phone
Handset for ATT 5.8 GHz Cordless Telephone Model 5870
i have at & t 5870 cordless phone it is no t working. handset is dead i change the battery but still not working .please give some advice.
Mar 16, 2008 | Lands Phones
Phone loses connection after few minutes
I looked up the battery specs for your phone. They are 3 X 200mah= 600mah battery packs. They should last 8 hrs talk time with the headsets. This style of battery pack in my experience only last about 1 1/2years and sometimes longer and "sometimes" shorter...much shorter. I bet you never had problems when you first got them. Basicly this "battery design arrangment" goes back many years before newer battery technlogy was developed. But designers still insist on using them even today. They are cheap to make. ****Time to replace them with new ones.**** Make sure you follow the mfgs charging instructions: "After battery installation, place the handsets in their base unit or charger and allow to charge for 16 hours before use. You can keep the battery charged by returning the handsets to their base unit or charger after each use. When the battery is fully depleted, a recharge takes about 12 hours. Average talk time on a fully charged battery is about eight hours depending on environmental conditions, standby time is approximately four days." Good luck
Jul 19, 2007 | AT&T E5640 Phone
Lost comunication
I solved this problem with a RESET of the handset. Instructions from the Philips website: Please perform a reset of your device. You will not loose your recorded data (phonebook and personal settings are being kept). 1. Unplug the mains of the base station. 2. Remove one of the batteries of each handset. 3. Put the batteries back in and re-plug the mains of the base station.
Mar 09, 2006 | Xact Communication XG2200 Cordless Phone
GE 21018GE3 Cordless Phone Logo
208 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
