Question about Carrier 38BRC048 Air Conditioner
Reset button does anyone know if there is a reset buttion on a carrier ac air handler model fa4bnf036. and where it is ? thanks steve
    Problem Solver:
  • 5 Answers
Nope but there is a control fuse
Posted on Sep 19, 2008
Carrier electric furnace (air handler) stopped running
The 5 amp fuse may be bad, they go quite often, and they are exactly the same as the car ones. Check the fuse with a meter. If its OK turn the unit on and check for voltage going to the blower fan. You should get a reading between at least one pair of wires. The unit should have a schematic on it somewhere, check it to see which wire pairs are used for the variable speeds of the fan.
Nov 08, 2014 | Heating & Cooling
Carrier electric furnace/air handler stopped running
Check fuses first! If yours is the model with a fuse box you will see a flap that pulls down to reveal a block of fuses, the blade fuse you described is part of it too! Are all fuses ok?
Carrier air handler/furnace won't turn on
from what your saying the motor is hot to touch if that is the case the motor is bad need to be replaced.
Kw for Carrier 42G150H
this is the m# of the air handler take frunt panel off an were the wires go into the unit there sould be another sticker with the kw usally there are 10to 15 kw is an averge house
Mar 15, 2010 | Carrier 38CKC042 Air Conditioner
What tonnage are these units and is it a variable speed.
The heat pump model number shows that it is a two and a half ton unit. I am sorry but I am not familiar with the air handler model number.
May 07, 2009 | Heating & Cooling
Btu's
That air handler can accamodate different size coils. Look for the coil model number. Also you can look at the outdoor unit model number they should be matched up. There is generally a set of 2-3 numbers in the model numbers that will tell you. xxx036xxx is 36,000 btu. tonnage is 12,000 btu per ton so 36,000 btu's would be 3 tons. xxx040xxx= 40,000btu's or 3.5 tons etc.
Mar 16, 2009 | Heating & Cooling
My outdoor heat will not operate. It is a Carrier 38YRA042330, with a Carrier Thermidistat thermostat and a Carrier Air Handler 40FFKB005300. I have an H5 error code on the thermostat will I put it in...
you need to go oside and look for a red reset button on the unit. you tripped the high ressure switch when you let your filter get that dirty. go check on this and when your done if it still is not working then ask me more.
Jan 25, 2009 | Carrier Heating & Cooling
Looking for installation manual
call the carrier dealer they have them.
Oct 03, 2008 | Carrier 38CKC042 Air Conditioner
Carrier, FC4BNF042
Chech for power to the ouside contactor and for 28 volts to the contactor!
Jun 29, 2008 | Carrier 38BRC048 Air Conditioner
Carrier 38BRC048 Air Conditioner Logo
730 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
