Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Philips Magnavox, no cule model num
Husband watching tv yesterday, it just turned off. When turned back on only green light is on. When menue is pushed on remote no words on screene. I have tried multiple inputs still no pic. He checked high voltage through out the unit and it looks good all the way through. Nothing looks like it shorted out or leaked. (he is a board level teck for high end keyboards). What else can we look at. {ps convergence was allways bad}
Teklady@tampabay.rr.com
    Problem Solver:
  • 17 Answers
could be regulator in power supply,there are like 3 ics in charge or the regulation,ask him to get schematic for this tv and find regulator ics one ar more of them could be bad,thanks.
Posted on Jun 09, 2008
My magnavox tv model num 50mf231d137 will not turn on it turns on then turns off with red light blinking
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information google.com/+GopakumarGopalan
Nov 19, 2013 | Philips Magnavox 27MS343S 27" TV
Hi i have a magnavox 42" plasma TV (model
I'd look for the manual and see what it says about that red light. I can't find squat for "Magnavox KM42010P".
May 28, 2011 | Philips Magnavox MRD120 - home theater...
My 50in projective philips magnavox comes in green model number 9p5040c104
Sounds like a simple problem....Go into menu...then to picture...Should be a Color option: See if it is adjusted all the way to one side...if it is...then try reseting it back to the center. If that doesn't help...Iono
Mar 05, 2009 | Philips 9P5040C TV
Tv wont turn on
Switch off the surge protector for 2-3 minutes then switch back on and TV should work.
Feb 19, 2009 | Philips Magnavox 27MS343S 27" TV
No power, lost power while watching tv
after picture is lost, does the screen remain lighting?
Jan 13, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Serial num 44021591 model num PR1310 C125
I have not worked on this model of set, but on many TV models, you can get it out of the demo mode by holding down the menu button for at least 10 seconds or longer.
If this does not work call the tech support for your set. They should have a definate answer. It is also possible that there is a fault condition with the set, and it is not properly responding to the front panel controls to be able to be put out of the demo mode. But, this is not a common type of fault.
Jerry G.
Sep 16, 2008 | Philips Magnavox 27MS343S 27" TV
55 inch Philips
I have 50" philips magnavox big screen. I recently started to have a problem with the edges of my tv. They became blurry. the center of the tv is clear and the edges are blurry. what should I do to fix this problem.
Sep 06, 2008 | Philips 9P5034C 50" Rear Projection...
Since you report that the convergence has been off as well, I would first suspect that the convergence ICs have failed. These are large black ICs attached to a heat sink and should be marked STKxxx. Try resoldering the pins first. If that fails, replace the ICs. Also in that area should be a number of pico fuses. Check those as well.
Keep us posted.
Dan
Jun 09, 2008 | Philips Magnavox 9P6034C 60" Rear...
Phillips Magnavox
Sounds like your Convertion bord pops. Tv Technical Prop, Take for service.
May 06, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
