Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Subzero model 650 refrigerator
Condenser blinks to be cleaned. after cleaning the condenser the temperator in the refrigerator is not going down
  • 1 more comment
  • soundstroo Aug 31, 2008
    Exact same problem...with icing on lower left of back wall. Compressor runs continuously. I noticed the flashing 'vacuum compressor', and I did so. Temp is around 42 and not going any lower. Do I also have an evaporator leak, and is this a difficult/expensive repair?
  • barbarav Nov 05, 2008
    I want to vacuum the condenser, is it located at the top and how do I remove the covering?
  • Anonymous Mar 23, 2014
    Where is condenser coil?
    Problem Solver:
  • 8 Answers
If the light keeps coming back on and temps are rising in the refer section, then you most likely have an evaporator leak. Check to see if you see either a moist spot or ice on the back wall on the left side of the back wall of the refer. If you do, it's definetly a leak. Call a authorized Servicer.
Posted on Oct 13, 2008
I had the same problem. Then ice started building up on the left back wall of the inside of the fridge.Turns out this is a common problem and the evaporator needs replacing. My fridge is 10 yrs. old. The warranty on this part is 12 yrs. just have to pay for the labour.
Posted on Aug 22, 2008
Water is collecting under my refrigerator
Posted on Aug 18, 2008
How can I get the refrigerator to cool (the freezer is working fine)?
Double check your refrigerator setting, it should be separate from the freezer. Check the vent is clean. If it is still not cooling, set freezer to warmer, turn off the unit, unplug, wait 3 minutes. Restart and see if the condenser starts
Jul 13, 2014 | Sub-Zero 650 / O Bottom Freezer...
The condensor is clean, but the vacum condensor lights keep coming on. What do I do?
when "vacuum condenser" or "service" lights r on, it means compressor is running more time than desired. most common issue that freon leaks out at evaporator in fresh food section. thats the most common issue with all subzero models. Hope thats helpful.
Jun 13, 2014 | Sub-Zero 650/SRH Stainless Steel
Why the Subzero Wine Cooler does not get cold?
Make sure the condenser area is clean, check the door seals and check that all venting inside the unit is free of obstructions.
Jun 02, 2014 | Sub-Zero 650 / O Bottom Freezer...
The ice cube indicator is blinking
From the manual:
The Control Center monitors refrigerator and
freezer temperatures as well as the ice maker
system. If there is a temperature or ice maker
problem, you'll be alerted by a flashing
SERVICE indicator light. This same SERVICE
light will also flash if the condenser needs
cleaning. Before calling for service, please
check and see if your condenser area needs
cleaning. Refer to Condenser Cleaning,
page 22.
CONDENSER CLEANING
In all Built-In models, the condenser is located
behind the grille. First, remove the grille. Then
using a soft bristle brush, vacuum to remove
dust and lint from the condenser. NOTE: To
avoid bending the condenser fins, be sure to
vacuum in the direction of the fins (up and
down). Clean the condenser area every three
to six months.
CAUTION
Before cleaning the unit, shut the electricity
off at the control panel. When you
clean the condenser, wear gloves to avoid
injury from the sharp condenser fins.
Failure to clean the condenser could
result in temperature loss or mechanical
failure or damage.
Mar 14, 2011 | Sub-Zero 650 / O Bottom Freezer...
Water is not draining down the drain tube in the main compartment of the subzero 550 refrigerator
clean drain line . force hot water down the drain as the get algi and stuff in them . if problem happens again then use a drain heater kit ( subzero ahd one for this model ) this will prevent ice over .. **** hope this will help ..
Dec 23, 2009 | Sub-Zero 650 / O Bottom Freezer...
We have been getting service code 50 for our SubZero -- it;s a 690 model fridge/freezer. I cleaned everything however over last three weeks the error repeats. I reset the board by pulling power from the...
Error code 50 means excessive refrierator section compressor run. Possible causes include: dirty condenser, stopped condenser motor, faulty termistor or an evaporator refrigerant leak. If it is a refrigerant leak it usually shows up as frost or water driplets half way down on the back wall. Clear codes by holding the alarm button in for 15 seconds.
Aug 26, 2009 | Sub-Zero 632 / S
Subzero--Vacuum Condenser Signal Won't Turn Off
The vacuum condenser indicator keeps flashing on and off. I did vacuum the unit, the the indicator lights keeps flashing on and off. How can I reset it and keep it off?
Thanks,
Rob
Aug 22, 2009 | Sub-Zero 650 / O Bottom Freezer...
My 650/f sub-zero is not cooling in the refer but the freezer is working fine?
Subzero uses two compressors so the freezer is a separate system. The first thing to do is clean the condenser. You can find instructions on how in the owners manual or at subzero.com. They even have videos. If that doesn't take care of it you could have a bad condenser fan motor a sealed system issue or a temperature sensor issue. Also I have seen if you put something tall enough to push up on the light cover on the top shelf that can stop the evaporator fan at the top of the refrigerator section.
Aug 01, 2009 | Sub-Zero 650 / O Bottom Freezer...
My subzero 650 bottom freezer working top part not working (warm)
Make sure the condenser is clean. Instructions are in your manual or subzero.com. If cleaning it doesn't work call for service
Apr 04, 2009 | Sub-Zero 650/SRH Stainless Steel
Subzero model 650 needs the condensor cleaned
The best way to clean the condensor coils on this model is to blow it out with an air tank.
Jan 07, 2008 | Refrigerators
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
525 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
