Question about Kitchen Appliances - Others
Old westinghouse toaster 1941
One of the heating elements has broken. It is a thin wire that stuck out a little too far and it finally broke. Can it be fixed?
  • 2 more comments
  • cantoo Jun 12, 2008
    The toaster is a 2 slot. Three of the 4 heating elements heat up and one side does not. How do I find the part number? The only numbers I find were on the bottom of the toaster and were posted on this site.
  • cantoo Jun 20, 2008
    I prefer to fix the problem rather than throw it away. Is there no one who can still fix old things or at least tell me how to do it myself?
    I will try an electronics store if I can find one in Miami. What gauge wire? I will try to take out the part that is broken . Don't go away now.
  • cantoo Jul 06, 2008
    The toaster is a Westinghouse L 352597. Cat. No. TO - 501 B 115V 1320W.
    I now have the panels out of the toaster, carefully brushed off and intact. The wire I saw broken is the only one. All the rest are perfect. I suppose I will have to take the panels to the electrical shop to find out what the wire replacement size is needed. The way the wire element is threaded around and through will be hard to duplicate without breaking the panel. Could it be isinglass? (Sp)
  • 2,071 Answers
Yes it can repair to reconnect the elements by using tungsten wire tide its end of the broken element so heat can go through it that is i did problem like these this only cheap solution..
Posted on Jun 20, 2008
  • 1 more comment
  • LORETO LACARON
    LORETO LACARON Jun 20, 2008
    all heat resistant wire u can but it in electrical hardware supply store..
  • LORETO LACARON
    LORETO LACARON Jul 07, 2008
    this site where you can buy spare parts on line.
    http://www.repairclinic.com/SmartSearch/...
  • LORETO LACARON
    http://www.resistancewire.com
    Ni Chrome stands for I THINK a trade name, but it means a nickel and chrome combination, of high resistance wire.
    The site above has all kinds of formulas, and I bet you can find what you need there.
    If for some reason you cannot, let me know.
    Remember like everything else, it has a duty cycle, for example a 10
    foot coil of size x, with x volts provides X heat in x ambient.
    A toaster uses a certain size of wire designed with knowledge it will
    be in the toaster enclosure and only on for a certain amount of time.
    A space heater might have a ni-chrome weave of wire, but it has a fan
    blowing on it to take the heat away, so in a static position, it needs
    to withstand the current for the period of time you need, with all
    other factors considered.
  • 1,512 Answers
Hi there
You would need to refurbish the appliance anyway. Fit newer elemets to resolve the problem of unavailable parts., This is not something that you can easily be told how to do, is just a matter of pulling it apart, perhaps posting a few photos of the problems you are having and we can go from there. You could salvage the nichrome wire of a new element to fix the old on, but the dismantling and getting the element out is something that you just have to get into yourself, or find a mate thats hady with this sort of thing.
I am happy to assist you and answer any questions you may have, and offer more advice to you.
regards
robotek
  • 3 more comments
  • Graeme Ross
    Graeme Ross Jun 20, 2008
    It is not copper wire(mentioned elswhere), but ni-chrome wire, This is resistance wire. Best bet is to buy another toaster element from an electrical wholesaler, unwind the wire from it and rewind into the existing element faulty element. If you were to take in your old element with you, they may have a similar one that you can retro fit into the toaster. Explaining to the parts attendant what you are trying to do may be best so he can match up the what you need.
  • Graeme Ross
    I found some interesting blogs here about restoring old toasters... you are not the only one that beleives in fixing quality gear! :) A great guide to give you some repair "confidence" is here
  • Graeme Ross
    I found an easy way to get what you need right from where you sit. Ebay can provide a good source and easy selection by site of a part that can help us with the repairs. check out here, and here, and here... there are many more just do a search for toaster element. :) or check out the shops at the bottom of the pages, these guys often do just about everything. :) How are you going with the dis assembly?
  • Graeme Ross
    Graeme Ross Jul 05, 2008
    Just following up, how did you get on with the fixing of the old toaster? :)
    regards
    robotek
  • Graeme Ross
    Graeme Ross Jul 07, 2008
    You know you could try to get a a small crimp type connector to reconnect the broken wire. This would also fix the toaster, even if a small amount of wire is missing.
    Genius:
  • 1,142 Answers
It is pretty simple and easy to repair,,,, if you can open the toaster you will be able to see the (element) copper flat wire, if it is broken than try to get the element replaced which is easily available in any electronic parts shop. there are 4 sheets of elements you need to replace the one which has gone bad.
  • 13,433 Answers
Toasters are cheap electronics Im not sure if its worth the repair, I would suggest to buy a new one.
Posted on Jun 18, 2008
    Brigadier General:
  • 3,614 Answers
That part was almost replaceable.
Posted on Jun 11, 2008
  • micromaster
    micromaster Jun 11, 2008
    you need to identiy the part # to order for the spare parts...
    BTW... are you sure it was the only part has a problem, check if any other part related to it was also affected.
  • micromaster
    micromaster Jun 12, 2008
    tell me the exact model name of the unit..
Only the side elements are working on the toaster. The middle elements which would toast one side of a slice of bread are not working. Is it possible to repair/replace the middle elements?
Maybe. Unplug the toaster and remove the bottom plate as you would for cleaning. look for the wires connected to the middle elements and see if one has become disconnected or broken. If one or more of the connections to the middle element is a quick disconnect type (click link for a picture),
https://s16-us2.ixquick.com/cgi-bin/serveimage?url=http%3A%2F%2Fts4.mm.bing.net%2Fth%3Fid%3DJN.EnzjOARZwnQZZjF7oGU2Dw%26pid%3D15.1%26f%3D1&sp=5dc5e8fde9f2f3462b6483c20bb42f01 then inspect it for overheating, oxidation or corrosion. You may be able to clean it up with a Scotch-brite metal polishing pad.
On my toaster, the connections to the heater elements are metal strips riveted to tabs from the element assemblies. One strip is riveted to the power neutral; the other has a quick disconnect tab for a wire from the thermostat. A loose or broken rivet could be the problem, but do not use an aluminum pop rivet to repair it. It can't take the heat, even if you could find one small enough.
I've seen toaster heater elements evaporate over the years - they get a hot spot, which burns off metal, making it thinner and hotter until finally there's nothing left there. At that point the element is gone. I suppose if you could find nichrome ribbon wire of the same width and thickness as the original, you could rebuild the heating element plate, but it would be a delicate task because the mica insulating material is fragile. It's probably more practical to scavenge a working heater assembly from another toaster of similar design, if the electrical connections are serviceable with the tools you have.
Unless this is a very fancy unit, it's probably cheaper and easier to scrap it out and replace the whole thing.
Jun 26, 2015 | Bodum Kitchen Appliances - Others
My 4 slice dual it keeps popping the breaker
One of the heating element is broken and the heating wire which have live electricity is touching the body of the toaster and thus the poppong of the breaker. So you can use this link and check which is the broken heating element . You can buy one or more heating element from ebay there are only two kinds CENTER and END which you have choose from, they will aslo supply aslo replaceing instructions.
Dec 07, 2011 | Dualit 40352 4Slice Toaster
Far right side coil panel not working.
Good observation!-- Let's take that a little further?-- Are you willing to tear into it, and check it out further?
Your toaster likely has 4 heating elements, correct? (Or possibly 3-- if the center shares toasting the 'inside' of both slices all the time?)
Anyway-- you are concerned with the outside element-- Something is 'open' in that circuit to that element only.
Can you remove the exterior, and get into the interiro, so we cn look for a broken wire?
BE SURE TO UNPLUG THE PLUG FROM THE OUTLET!!
Look for a supply wire, that has broken off, or one of the heating element wires has separated-- either from itself, or the junction where it connects to the power.
Temporarily you might be able to join the break-- but the permanent solution is to replace this element.
o replace the element, we will need make, model, serial number, and will have to do some searching for the part.
How far do you want to go on this repair?
Mack B
Jan 15, 2011 | Dualit 20084 2Slice Toaster
Krups Sensotoast Deluxe -- Stopped working!!! Checked outlet. Not the problem.
Did the same to me
The ceramic heater to wire connection broke off
not a prayer of fixing it
The heating elements are in a series circuit, so as goes one element, so goes both elements.
Aug 06, 2010 | Krups SensoToast Deluxe 4-Slice Toaster
My toaster will not heat up to make toast on any level
This could be a broken heating element. If it's less than a year old, take it back for an exchange.
Jul 11, 2010 | Back to Basics TEM-500 Egg & Muffin...
The two inside elements do not toast. The outside
You either have a stuck/defective bagel button, which turns off two elements; the elements have a break in them; or there is a wire broke or loose on the inside elements.
If you can use a multimeter, you can unplug the toaster and remove the case and check for all of these conditions. At each end of the toasting element, check for continuity, if OK, then check the bagel button to see if it is working correctly, again with the continuity check.
Check all connections to make sure none have burned off at the wire/connector points, and finally, check the thermal fuse to see if it might have failed.
Other than that, there isn't much else to check.
Hope you found this Very Helpful - Best regards!
Aug 19, 2009 | Kitchen Appliances - Others
Black and /decker toaster model T3550. The outside elements work but the middle ones do not. so only one side of the bread is toaster.And the handle must be held down the whole time to toast
The heating element wire is really thin and there is a great posssibilty of breakage. There is also a spring switch in which the lever locks when toasting. needs replacement.
May 11, 2009 | Black & Decker Toast-It-All Plus T3550...
Heating element broken
Now we are using kanthol heating element,,,,,,,, capacity 200A,,,,
its frequently cutoff during process whats the reason,,,,,,,,
Dec 20, 2008 | Waring WCT704 4-Slice Toaster
Top element broken
Oster 6233 toaster oven top heating elements don't work
Nov 11, 2008 | Toaster Ovens
Kitchen Appliances - Others Logo
434 people viewed this question
Top Kitchen Appliances - Others Experts
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
