Question about Motorola Mobility RAZR V3
Finding a back for my motorola razor 3
I am searching for a back cover for my magenta motorola razor 3. Actually the color of the back doesn't matter I am so desperate.... The back of this phone cover I am looking for has two prongs or tabs at the bottom of the cover (one on each side at the botttom). My challenge is the only cover I can find is one with one tab or prong in the middle of the cover at the bottom. The lower back of my phone where the cover slides down into does not have a slot in the middle but one to the right of the middle and one to the left of the middle. Everyone I talk to says there is no difference, but trust me, there is... as the one they try to sell me doesn't fit and it's like, golly, what's going on here. thank you for any advice you can give me...
jeanne teel
  • 497 Answers
Why not try the moto service centre itself.??.frm where u wud have bought the mob from.
Have a nice day!
Posted on Jun 09, 2008
Print Quality Issue In magenta color in HP color laserjet cp3505n i hv to change cratridge but problem not resolve Pleae help us
I received a similar HP Laserjet Color Printer with same issue for repair/ maintenance a few months back.
Actually the problem is with the printer design not the magenta cartridge and it needs professional hands for servicing and cleaning. The mirrors which reflect laser beam get covered with dust and toner. hence the image is not produced properly. note that first magenta goes off, followed by yellow, then cyan and lastly black. this is because of the mirrors placement inside the printer.
Rest assure that the printer requires ONLY CLEANING OF THE MIRRORS, which are inside the printer.
Clean them yourself with dry n soft cloth (if you are familar with such tasks) or get it cleaned by any printer repair/ service professional. Please note that the mirrors, lenses and scanner assembly inside such printers is extremely complex and can get damaged very easily especially the mirrors.
Hope it would help, looking forward
I have a jabra ote3 bluetooth. i don't have the manual. can i connect the bluetooth to a verizon motorola razor?
Yes,You can connect the Jabra head set to motorola razor.
Please follow the steps to connect it to motorola razor
1. Turn headset off. Press and hold until solid light comes on.
2. Activate Bluetooth on your phone.
3. Search for Bluetooth devices and select Jabra BT2070.
4. Press ‘OK’ on the phone ,If the phone asks for a PIN then confirm with PIN code 0000 .
Thank You
Aug 11, 2010 | Cell Phones
I have a HP color laserjet 4650dn that when you print a document, there are pink spots all throughout the document. Is this due to replacing the fuser or transfer bar? There are no warning indications on...
It depends on the true color of the spots. If what you describe as pink are actually Magenta colored spots then I would suspect the Magenta toner/drum cartridge. It is definately not the fuser. The transfer bar or actually transfer belt unit in this case is doubtful to be the cause. A defect in the tranfer belt unit does not normally show up as 1 color. It is usally multiple colors. I would open the front cover and at least visually inspect the Magenta toner cartridge. If you have a spare unit, even an old one to swap it out with even better. Look at the color of the Magenta toner and compare it to the spots you are seeing. If they are similar then in my opinion the problem is in the Magenta drum unit.
Apr 21, 2010 | HP Color LaserJet 4650DTN Printer
The lt magenta and magenta just quit printing between pages
1. Check if the cartriges are correctly installed:
Installing the Ink Cartridges
2. Print a diagnostic page and clean print heads, using the printer cleaning utility:
Color Mix or Missing Colors on the Diagnostic Page
Repeat if needed.
3. If this still doesn´t solve you problem, try resetting the printer and manually cleaning the cartrigdes as advised in this FAQ:
Ink Cartridge is Missing, Incorrectly Installed, or Not Intended for Your Device' Error Message is Displayed on the Printer
Sep 06, 2009 | HP Photosmart C6180 All-In-One InkJet...
Magenta print out very light
This is caused by dust in the scanner assembly. There's a fan right by the magenta laser scanner that blows dust and particulate matter in the air directly on that laser scanner.
Requiring its removal and careful cleaning of all lenses and mirrors. Unfortunately, this is not covered in the service manual. Getting the laser/scanner out is not too bad: Start by removing the printer covers, the rear plate, and the plate on which the DC controller and formatter mount. Remove the four laser/scanner unit corner screws and the single screw for its cover. Be careful to remove the small shutter spring on the cover before removing the cover. Use a strong flashlight to carefully examine the copper-colored mirrors for dust. Use dry cotton swabs to carefully clean all dust from the mirrors and the lenses. Blow dirt and dust from the inside of the scanner box. You will notice that the bottom mirror, facing up, is the one with the most dust.
Jul 23, 2008 | HP Color LaserJet 2600n Printer
Linking two razors
activate both bluetooth devices on the phones' after that put one of on search......and you will find it.
Mar 15, 2008 | Motorola Mobility RAZR V3
Lost battery cover
You can either go to the store where you signed up for service & purchased the phone or you can buy one on EBAY. I saw a blue one for sale there for $4.99 + shipping. Prices vary and there will be shipping charges.
There might be a couple different colors of blue, so you will want to make sure you get the right color.
- Jim
Feb 11, 2008 | Motorola Mobility RAZR V3
Can't color balance 2605
well, the density is actually a combination of two aspects. The original document settings, especially in color transforms. Usually, the software will have a transform specific for the printer. In my experiences, trying to tweak the printer for each print job, can cause extreme frustration. Check the software manual for settings for your printer, and perhaps you'll get closer to this solution.
Got backup?
Feb 07, 2008 | HP Color LaserJet 2600n Printer
Motorola h700
5 Steps
First, CLOSE your boom
Second, Hold the talk button( about 5 secs it should turn to purple color)
Third, DO NOT release the button while opening your boom
Fourth, your BT should be in discover mode( show the steady light not flashing )
Fifth, open your phone bluetooth and search for device. Choose your bluetooth that appeared on the list ( pair code normally "0000" ).
Dec 13, 2007 | Motorola Mobility H700 Wireless Headset
New Motorola Red Razor via Sprint
i can help you with your problem ??? please message me and i can assist you from here
Aug 09, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
29 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
