Question about Vivitar Cameras
I have Vivitar 3900 flash that has not been used for several years. It will not run on batteries, due to excess current drain. If connected to a 5-7 volt power supply, the drain goes over .5 amps. The main capacitor (350 ufd @ 400 volts charges to 300 volts and when the flash is turned off holds a charge. Any suggestions for repair?
The capacitor needs to be 're-formed'. Briefly, run through several charge/discharge cycles.
Posted on Nov 05, 2008
Bought a new flash, I got my money's worth from the old Vivitar, 10+ years old.
Posted on Jun 09, 2008
Something inside popped when I fired it up after several years
Likely the capacitor that stores the electricity used to make the flash. Replacement may be more expensive than the flash itself.
May 16, 2015 | Vivitar 2800 Flash
Hello! I have a s500 2001Benz and our battery keep dying overnight why is this..
You have an excessive power drain from some electric component in the car and it is draining the battery power rapidly. That is, assuming you have a sound battery that is holding its charge.
You need to have some tests run to identify the source of the drain and rectify it. You will need to either have Mercedes do this or a competent auto electrician who is familiar with Mercedes systems.
The battery will not last very long if it is being constantly discharged like this due to the excessive power drain.
Furthermore, if the battery is old and on the way out it will not hold its charge for very long even if there is no excessive power drain. When the car is idle and everything is in working order, there are still systems on the car that drain a small amount of power constantly so you still need a sound well charged battery.
Mar 10, 2015 | 2001 Mercedes-Benz S-Class
I have a draw from my battery how can I find it? I have put a test light in between the neg. post and the cable and the light stays on.I have pull all the fuses one at a time and the light dose not go...
Could be a ground problem; I send you a drain test to check it, you will need a digital volt and ohm meter to perform a battery draw test.
WARNING: Do not attempt this test on a lead-acid battery that has recently been recharged. Explosive gases may cause personal injury. Failure to follow these instructions may result in personal injury.
CAUTION: To prevent damage to the meter, do not crank the engine or operate accessories that draw more than 10A.
NOTE: No factory-equipped vehicle should have more than a 50 mA (0.050 amp) draw.
Check for current drains on the battery in excess of 50 milliamps (0.050 amp) with all the electrical accessories off and the vehicle at rest for at least 40 minutes . Current drains can be tested with the following procedure:
Many electronic modules draw 10 mA (0.010 amp) or more continuously.
Use an in-line ammeter between the negative battery post and its respective cable.
Typically, a drain of approximately one amp can be attributed to an engine compartment lamp, glove compartment lamp, or interior lamp staying on continually. Other component failures or wiring shorts may be located by selectively pulling fuses to pinpoint the location of the current drain. When the current drain is found, the meter reading will fall to an acceptable level. If the drain is still not located after checking all the fuses, it may be due to the generator.
To accurately test the drain on a battery, an in-line digital ammeter must be used. Use of a test lamp or voltmeter is not an accurate method due to the number of electronic modules.
When the battery has been disconnected and reconnected, some abnormal drive symptoms may occur while the powertrain control module (PCM) relearns its fuel trim. The vehicle may need to be driven to relearn the strategy.
Make sure the junction box(es)/fuse panel(s) is accessible without turning on interior or underhood lights. Drive the vehicle at least 5 minutes and over 48 km/h (30 mph) to turn on and activate the vehicle systems.
Allow the vehicle to sit with the key OFF for at least 40 minutes to allow modules to time out/power down.
Connect a fused jumper wire between the negative battery cable and the negative battery post to prevent modules from resetting and to catch capacitive drains.
Disconnect the negative battery cable from the negative battery post without breaking the connection of the jumper wire.
NOTE: It is very important that continuity is not broken between the negative battery post and the negative battery cable when connecting the meter. If this happens, the entire procedure must be repeated. Connect the tester between the negative battery cable and the post. The meter must be capable of reading milliamps and should have a 10 amp capability.
If the meter settings need to be switched or the test leads need to be moved to another jack, the jumper wire must be reinstalled to avoid breaking continuity.
Amperage draw will vary from vehicle to vehicle depending on the equipment package. Compare to a similar vehicle for reference.
Remove the jumper wire. If the draw is found to be excessive, remove fuses from the central junction box one at a time and note the current drop. Do not reinstall the fuses until you are finished testing. To properly isolate each of the circuits, all of the fuses may need to be removed and install one fuse, note the amperage draw, then remove the fuse and install the next fuse, etc.
If the current draw is still excessive, remove the fuses from the battery junction box (BJB) one at a time and note the current drop. Do not reinstall the fuses until you have finished testing. To properly isolate each of the circuits, all of the fuses may need to be removed. After removal of all of the fuses, install one fuse, note the amperage draw, then remove the fuse and install the next fuse until each circuit has been tested. When the current level drops to an acceptable level after removing a fuse, the circuit containing the excessive draw has been located.
Check the wiring schematic in the wiring diagram for any circuits that run from the battery without passing through the junction boxes. This could find in the Service Manual or Haynes books. If the current draw is still excessive, disconnect these circuits until the draw is found. Also disconnect the generator electrical connections if the draw can not be located. The generator may be internally shorted, causing the current drain.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 18, 2011 | 2004 GMC Envoy
How to charge a vivitar dvr 850w flash media camcorder?
Connect the camera to either a powered USB port on a computer or a wall outlet using the supplied charger. The connector is inside the cover on the back of the handgrip. Be aware that not all computer USB ports put out enough current to charge batteries.
The full instructions are in the "Preparing Your Camcorder for Use" section of the manual. If you need a manual, you can download one at
Jul 07, 2011 | Vivitar DVR 850W Flash Media Camcorder
1. flash overexposes unless I am at least 10 feet from subject. 2. Even slight movement causes a blur - even with flash. 3. automatic focus works sometimes, many pics are out of focus. This is my wife's...
Hi davidiven,
There must be a problem with the circuit within the digital camera. if that is not the case then it is most likely the lens and imaging processor, since this is a Physical problem and not a software issue. due to maybe an excess of dust or rust had been formed due to humidity. i would recommend for you to take the camera to you local electronic store and ask them if they can help you with your issue. other than that nothing much can be suggested.
i hope this helps.
Mar 28, 2011 | Vivitar ViviCam X029 Digital Camera
Where can I purchase a new or used battery holder for a Vivitar 283 flash attachment? Mine was left in too long and the batteries destroyed the contacts.
Best place for finding Vivitar 283 anything is on e-Bay, I use a gang of them doing my location photography and have several holders preloaded with batteries so when the cycle time starts to get more then I can bare I just switch out the holders.
All my stuff came off e-Bay.
Feb 21, 2011 | Vivitar 283 Flash
Why does it take more than 20 seconds to change up in order to fire the flash strobe on the vivitar 285hv
My first impression is that you are using the flash at its maximum capacity and completely draining the charge each time. I'd also say that you are only going to get about a dozen flash burst before the batteries are exhausted. I use several Vivitar 283's 285's and a couple 285HV's in a portable studio set up I have and the 285 HV's have got to be tuned down about 1/3 before I can get them to match the other flash outputs. If I need all out brute power then the 285HV's are used on full inside a softbox. I generally work with a 16 batteries between the two 285HV, also they need good fresh batteries off the charger. On a photo shoot I'll get maybe 15 shots before the power is down enough that I change then, I'd say powering back up it'll take about 15 to 20 seconds before they come out.
Jan 30, 2011 | Vivitar 285HV Flash
My Kenmore HE has the "SUD" error message. Why and what do I need to do
HI;The Motor Control Unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential Suds Lock is detected. This may signify a bad pump, extra heavy load, excessive detergent, or excessive suds, due to using a non- HE detergent.
Possible Causes and necessary procedures are as follows:
If too much detergent was used:
A.Run the unit through a Rinse/Spin cycle.
B.Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent. Once the unit is clear; Follow the procedures below:
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch, and Central Control Unit (CCU).
4. Check and clean the drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any cycle.
Aug 13, 2010 | Kenmore HE2 Plus Front Load Washer
No power for my 'old' Vivitar 285HV Flash
I've got three 285HVs and have had this problem. Obviously, make sure the batteries are good and the door and inside terminals are not corroded. The whine sound that you usually hear is the high voltage circuit. the reason it changes pitch is that the main capacitor is charging. As the charge gets greater and greater, the pitch with go up as the circuit changes the power being fed to the capacitor. If you don't hear the "whine" then it's either the HV circuit isn't working (probably not) or the capacitor has gone bad. These things are sealed but can decay internally due to their structure. Usually this is due to the dielectric components breaking down or the electrolytic goo drying up (usually what causes it).
Sometimes, you can let it sit with good batteries and the switch on to see if it will eventually start to charge the cap. Most of the time tho, this is an indication that the capacitor or the charging circuit is dead. It can be repaired but sending it off will usually be more expensive than replacing the unit.
Be sure and rate me!!
Feb 09, 2009 | Vivitar 285HV Flash
Digital rebel battery drain with flash only
I would suspect the batteries
Ive got an eos Rebel think its just over 4 years old
for the last year its been used every weekend for several hours 300+ pics per weekend between 2 nights I found that recently where one battery would last a night the battery was running out midway through & also taking longer to charge afterwards
2 after market replacements cost me about £10 and things are back to normal
5 years is a pretty good lifespan for a battery so its probably just getting old
Nov 29, 2008 | Canon Digital Rebel / EOS-300D Digital...
Cameras Logo
218 people viewed this question
Top Vivitar Cameras Experts
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
