Question about GE Spacemaker JVM1640SJ Microwave Oven
Constant rattling noise during operation
We have a GE Spacemaker microwave that is 6 years old, model number JVM1441WD003.  Recently it started making a constant loud rattling noise during operation.  It is still heating properly and in every other way seemingly working fine.  Do you know the problem?
  • 2 more comments
  • aju0619 Jun 12, 2008
    Our microwave (model JVM1441WD 001) also started rattling recently. It's also about 6 years old. I've cleaned all the turntable parts to make sure that wasn't the problem, but the noise sounds like it's coming from the top.
  • Anonymous Jun 21, 2008
    I have the same problem with a JVM1660WB003. Rattling noise started within the last month but the microwave has been running fine.
    I have been able to isolate the noise to the top of the microwave, it is not the turntable.
  • velvet40 Jun 21, 2008
    We have a GE model JVM1860BZ002 and it is 6 yrs old and making a squeaky noise with the turntable-- when we turn off the rotation it stops. What should we do?? What is it?? What's with the 6 year mark and appliances-- our Lennox air conditioner big $$ went out after 6 years too!!!
  • sbierer Jan 13, 2009
    Same problem, it is mounted so difficult to see the top.
Possibly the "stirrer" motor - this is in the top and turns a metal reflecting ring to disperse the microwaves around the oven more evenly. About $70 on GE site for my oven.
Posted on Oct 24, 2008
GE spacesaver II making loud noise and is not heating up food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jun 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
It is making a lound noise and no longer heats
heatman101
dgh
Oct 24, 2009 | GE Profile Spacemaker II PEM31 Microwave...
It made a loud noise and was starting to smoke.
Sounds like the magnitron is shot, I wouldn't attempt to use it anymore. When a magnitron goes bad it actually gets much stronger than the unit is made to handle.
Aug 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacemaker Microwave-Model # JVM1441WD003 no heat -clock ok
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Feb 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1800(JVM1850CF001) - Loud Humming noise
You either have a bad magnetron tube (5 or 10 year parts warranty item through GE Factory Service 1-800-432-2737 or www.geappliances.com) or a shorted high voltage rectifier. I think the light being out is a secondary problem.
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1800 first no inside light followed by loud noise
I agree that the light is unrelated. 99.9% chance you have a bad magnetron tube but it is covered by either a 5 or 10 year parts warranty through GE. Call GE Factory Service at 1-800-432-2737 or schedule online at www.geappliances.com
Dec 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Loud and not heating
If it's less than a year old, it's still under warranty. If it's just over a year old, GE will still cover parts, but you'd have to pay for labor.
Contact them at http://www.geappliances.com/service_and_support/contact/
The most likely causes are a shorted high-voltage diode or a bad magnetron.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Nov 13, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
New microwave; loud fan when heating items
Since you say it's new, it should be under warranty. I would call GE (see your owner's manual) to get a local authorized service center. Then while you're on the phone with the service center, you can start it up and hold the phone close to it to demonstrate to the technician how loud it is. They should be able to tell you if it will be covered under warranty so you get it fixed free.
Mar 27, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
2,306 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
