Question about HP Compaq Presario V5000Z Notebook
Compaq presario v5000
I have a compaq laptop it works fine, but you need to twist the top left corner of the screen to get it to show a picture. could this be the screen or the back lite inverter, need a little help. thanks
  • stevefr Jun 08, 2008
    Help please
I need the drivers of sound
Posted on Jun 15, 2008
I have a compaq presario v5000 that gives me white screen help!!?
have you remembered to reconnect that small wire under the screw on the hinge?
hope this helps
Jun 06, 2010 | Compaq Armada 1700 Notebook
My compaq presario v5000 a 5240NR was working fine
Fn+F1 Decreases the display brightness. Fn+F2 Increases the display brightness
Oct 01, 2009 | HP Compaq Presario V5000T Notebook
Broken touchpad on compaq v5000 series
Disassemble the laptop, down to where you can remove the top case cover, and get to the Touchpad. (AC adapter, {Charger}, removed, and battery removed)
Here's how:
1.http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=499847&lang=en&
This is HP.com/Support, and the Manuals page for the Compaq Presario V5000 CTO laptop. (Even if it isn't your exact model, your laptop is part of the Presario V5000 Series, and this information transfers directly over)
On this page I would like you to click on ->
Compaq Presario V5000 Notebook PC - Maintenance and Service
Guide <- in blue.
It states that it's a 'guide', but it's a Service Manual, believe me!
This is a PDF file download. After you click on it, you may not see
anything happening for up to 30 seconds. Usually after 10 seconds
you will see the first page. I caution you to Not look through it, until it has fully downloaded. You may accidentally break the connection.
AFTER it has fully downloaded, you can save it to your computer.
This way you can burn it to a CD disk, and look at it anytime you want. (You can also delete it off of your computer, and free up harddrive space, plus you can put the disk in another computer, and view it as you work on your laptop)
To do this click on the Floppy Disk icon. This is in the upper header, and is the second icon from the left. Hovering your mouse over it will briefly reveal, "Click to save this file to your computer or another location"
If you do not have your downloads set to be saved to your My Documents folder, this pdf file will go to your desktop screen.
(c00700903.pdf)
Suggest you start with Page 77 first, then on Page 125 (Base Enclosure and Top Cover), you'll find the info for removing the Top Cover. The Touchpad is in the Top Cover.
Jun 03, 2009 | HP Compaq Presario V5000Z Notebook
Hello GOD BLESS YOU all. my latop is compaq presario V5000
You can download latest drivers for your model here
Apr 09, 2009 | HP Compaq Presario V5000T Notebook
Computer will not boot up
Theres some information on how to do the recovery on your computer.
http://support.thetechguys.com/layout.aspx?ID={08478b5e-96b4-4e92-9e3a-61810647032b}&CatID={37257f71-f92f-4574-b3be-f0f6705594b4}
Jan 21, 2009 | Compaq Presario Notebook
How do I replace a Compaq Presario V5000 laptop keyboard?
You need a flat bladded thin screw driver to prise off the long cover the runs along the top of the keyboard and just below the screen. Make sure you remove any screws at the back of the screen hinges, and along the top above the battery housing (you need a small posidrive screwdriver for this). You will find there is a screw on the underside of the laptop that holds the keyboard in place from underneath, plus two or three very small screws on the top at the screen end. When all the screws are removed you can lift the keyboard up from the screen end and pull (gently) away from the touch-pad end. Tilt it up and you will see the keyboard data ribbon, don't twist it or pull it as you will damage it.
hope this helps
Sep 23, 2008 | HP Compaq Presario V5000Z Notebook
HP Compaq Presario V5000 LCD Problem
I have the same problem. I thought the problem was due to a loose cable so I opened the computer up only to find out the cables are all good. I still haven't found a solution
Sep 07, 2008 | HP Compaq Presario V5000Z Notebook
Could be a stuck key somewhere, has anything been wasted on the keypad, tap the keys one by one to refresh is. Could also be that the keyboard is broken.
Fixya me ... thanks!
Feb 20, 2008 | Compaq Presario 2170US Notebook
HP Compaq Presario V5000Z Notebook Logo
227 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
