Question about Frigidaire Heating & Cooling
I have some tree leaves and water stuck up on the back of my AC unit .I would like to open the back of the unit and remove all the dirty leaves. How do i get this done ?
With my Maytag window unit, I just unscrewed everything on the casing until the front part could be popped out/unclipped then cleaned out the debris with an air compressor.
Posted on Jun 09, 2009
Rubber tree plant
This can happen for a few reasons, all involving water in one form or another. A rubber tree that is underwatered or overwatered will curl its leaves. As will a rubber tree that is in too low of a humidity or in poor soil.
When watering water when the soil is dry to the touch about 1 inch down and then water with enough water to that water runs out the holes each time. This helps remove any build up of soluable salts. IF the tree has recently been moved and lost leaves, the tree should put out new leaves but they will not be in the quantity that they were when the plant was brought in. Fertilizer should not be used at this time of adjustment. Only after the plant gets settled into the new location and then about once a month or so.
Information About Rubber Trees
Feb 01, 2014 | Garden
Water on floor from ac unit
Hi John,
First, water from an A/C unit is normal, and is created when warm, moist air is passed over a cold surface (like a glass of cold water sweats sitting in a warm room). This is called condensation.
Solve the issue by making sure the unit is tilted slightly back - towards the outside. This allows the condensation that drips off the cold coil will land on the bottom of the case and roll towards the rear - which is outside.
Once it is tilted back, inspect the underside of the outside portion of the unit. You should find several openings designed to allow the water to drain out and fall to the ground. Over time, these holes can become clogged with dust, dirt, spiders, etc. Simply insert a small screwdriver into the hole(s) - just enough to clear the obstruction.
If the unit is draining water out the back to the outdoors AND also inside, water can not drain fast enough from the A/C. You may not have cleared all the openings outside and / or not have provided enough of an angle to the tilt. Locate and clear the additional openings and make the tilt adjustments as needed.
Make sure the filter is clean! A dirty filter can cause the A/C to eventually ice up - providing only partial cooling. When the unit is shut off, the ice will rapidly melt and may do so faster than the water can drain outside - leaving puddles on your floor again.
I hope this helps!
Mar 21, 2012 | Heating & Cooling
When it rains puddles of water on the passenger side floorboards mostly in the back not coming from sunroof and theres a crack in my windshield thought it might be that but the dashboard is never wet so...
The cowl drains could be clogged. Trace from the opening at the base of the windshield down to door hinges and look for debris such as leaves in the opening behind the hinges. You may have to use a coat hanger as a special tool to remove the debris.
Oct 10, 2017 | Cadillac Catera Cars & Trucks
Model: KFR-32GW/Ac Will not stop leaking water from the front of the unit. Coils have no ice. Shut off unit for 30 min the leaking stops but resumes when AC is turned back on.
Possible one of two problems. first make sure the unit is tilted away from the inside slightly. Second there are very small drains that let water flow from the front coil to the rear of the ac if the unit has been dirty it can plug these holes. You can find the holes by pulling the ac out or just remove it and use a hose to clean it. You can buy coil cleaner at a hardware store just follow the directions.
Aug 08, 2010 | Heating & Cooling
Some discharge coil in window ac effectiveness is reduced.what mi
Clean the air filter. It can be removed and ran under water. If the coils are dirty take the window unit out side, remove the cover and house out the coils. Be careful and try not to get a lot of water into the switches. Make sure it's dried out really good before plugging it back in. The number one problem for A\C units is dirt.
Apr 19, 2010 | LG Heat cool Window Air Conditioner
New AC unit mist
It sounds like the unit is either level or tilted down in the front, not allowing the water to run to the back of the ac and the blower wheel is picking the water up and blowing it into the room.
You need to put a level on it and lower the back of the ac so the water the coil removes can run to the back of the unit and that should solve your problem.
Jun 07, 2009 | Friedrich WallMaster WS10B30 Air...
Water leakage from internal unit of split AC
Draim pans do get dirty and partialy block drain pan. If possible take a shop vac and gently **** out the drain line. This will pull the restriction out of the line and help clean drain pan. Rusty
Jun 05, 2009 | Heating & Cooling
Wet carpet under front Passenger seat
You have drain blockage in the condesor case itself. There is a small tube that will drain the condensor case, the big black plastic case that contains most of your a/c system inside the car. This case collects moisture and that must drain normally from the case drain to the outside of your car onto the ground.. If this drain is plugged, you will have leakage on to the floor. If the moisture is allowed to remain in the carpet, mildew will set in and then you will have to replace the carpet.
Nov 19, 2008 | 2001 Volvo V70
Mothers AC unit
That has nothing to do with the water. Sounds to me like it needs cleanning, (the water is not drainning toward the back of the unit) ,,(dirty filter, which its trying to **** air anywhere it can even thru the drain hole, or not enough slope, leanning toward the back so gravity can flow the water to the back of the coil! Thank you-very-much!
Aug 28, 2008 | GE Zoneline AZ38H12DAD Split System Air...
A.C. unit
One of the cause of water dripping in the indoor is restricted drainage. To Identify if your drainage is restricted.
- Turn "off " the circuit breaker and take out the face cover of the unit.
- Turn "on" the circuit breaker and start the unit, wait until the unit drips.
- When the unit dripped check the drain pan if overflowed with water.
- If the drain pan is full of water you need to flush the drainage with water to remove the restriction. If the pressure of water in your area is high you can use your garden hose to flush the drainage.
Another is dirty evaporator fins (icing), dirty drain pan, broken drain pan or incorrect installation.
Aug 16, 2006 | Carrier IBM UNIT 2380 79F4796 Drive Case
Heating & Cooling Logo
35 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
