Question about Samsung HL-P5063W 50" Rear Projection HDTV
HL-P5063W vibrating and won't turn on
Last night I was watching my DLP and the colors went all crazy. It's hard to explain exaclty but there was a lot of purple and red. I turned it off to reset it and now it won't turn back on. There is a loud vibrating noice coming from the back and the lamp light flashes, and it wil then shut itself back down and try to power up again. Eventually all three lights on the front power button will start to flash but the screen will not turn on, any ideas?
  • jtcarr1228 Jun 26, 2008
    Problem is a little different. Set will make loud vibrating noise and picture will flash in and out and looks hazy. We will immediately turn off TV and the vibrating noise gradually stops. It sounds very bad but maybe a quick fix?
  • ptmoose May 11, 2010
    I have a new wheel but can't find the old in the TV. How do I get to it???
Same problem: No onset, symptom or anything just all of a sudden, blank screen, and a loud humming/vibrating sound. Believe it or not I had the protection plan from Circuit City and called them up. Suprisingly they were easy to deal with, set up an appointment and the guy showed up on time! He knew right off the bat that it was the color wheel and it took him 20 minutes to replace it. The wheel itself actually shattered! He explained that the bearings can go bad and the wheel gets loose. Subsequently it wobbled, hitting the housing and shattered (explains the sudden blackout.)
I read somwhere else in this forum that it took someone an hour and a half to replace it. I'm pretty handy but when I opened the back of the TV, my wife gave me "the look" so I called.
For those who care: The guy was courteous, answered all my quests. and even vaccuumed ou the back of the TV. I don't advocate the Protection Plan but I was glad I had it. Cost me $499 in 2004 expiring this November. He explained that it would have cost me out of pocket $218 for them to come plus parts which in this case was another $130. So I guess I lose in the end but if you told me I had to dump $350 into the TV now, I seriously would have considered buying something new (That's just me).
Posted on Jul 10, 2008
You need to replace your color wheel. I had the same problem
Posted on Jun 19, 2008
I have Samsung DLP TV 50 inch HL-P5063W
First thing to look at is the color wheel this model uses--usually it will make a high pitched fan like sound but can make a grinding sound also.
If it slows down from the 12,000 or so RPM speed it will cause color issues.
HAVE GRINDING OR HIGH PITCHED SOUND?
Apr 02, 2012 | Samsung Televison & Video
Started making a humming or vibrating sound, and the color and resolution went bad at the same time. Now when I attempt to turn it on, I get the same vibration sound and nothing else.
This tv have a colors wheel,it dead.Require changing.Humming or vibrating sound,Flashes pictures black&white.The colors wheel is dead and it not spinning in it axis motor correctly anymore.Hire a tv Tech. to change the colors wheel,it very hard to change the colors wheel.Because u have to take out many machanical parts,even before u can get to the colors wheel itself.
Oct 14, 2010 | Samsung HL-R5656W 56" DLP HDTV
Samsung 50" DLP No picture and very deep & lound vibrating sound. Red lights flashing,Sand By Temp. And Green lights flash Lamp.
Loud sound you are hearing is coming from your color wheel and has your Lamp ever been replaced? this set has 3 Fans they all must be running for set to operate correctly! Encompass Parts has Boards and Color Wheel But for Lamps Mats has them for 99.00 1-800-628-1118 and EC Parts 1-800-638-3328
Jan 21, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
Tv turns off after watching an hour - then proceeds to turn off every 15 to 20 minutes there after
Hi if your tv is a DLP or LCD and you hear clicking or like wanting to turn on ,most likely its an issue with the ballast which is the board that powers the lamp.(Discard if tv is )If you hear buzzing or spinning noises it could be you color wheel.Also check if fans are running ok or if they are dusty, clean them with an air pressure can if they are dirty.It could also be time to replace the lamp.they normally last 6000-8000 hrs if it's a Philips brand if it's na Osram lamp they will last 4000-5000 hrs 1-2 yrs.God bless you!
Oct 05, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
i have had this happen to me several times in the field, and if it is what i think it is, you are not going to be happy =(
inside of a DLP type TV, there is a device called a 'color wheel'... it is essentially a disc made up of different colored glass that spins really fast. this disc has 3 or 6 (depending on make/model) pieces of colored glass like pieces of a pie affixed (read: glued) to a hub.
what happens sometimes is that one of the pieces of colored glass flys out of the hub, and causes a massive unbalance in the spinning wheel, which causes the hum/vibration, and since the colored glass is missing, the colors will be all messed up.
if this is what happened, then your television will require a new DLP engine.
Dec 08, 2008 | Televison & Video
How to change the color wheel of Samsung HL-P5063W
Look on Youtube for samsung color wheel. you should find your answers there...
Jul 18, 2008 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung HLS4266W 43" dlp
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Dec 24, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung DLP loud vibrating noise
The color wheel is the most common problem in DLPs that cause noise. To determine the cause: Turn the set off. If the noise goes away after about five seconds, then, the problem is the color wheel. If the noise goes away one to two minutes after shut off, then, the problem is a fan. You can find an Authorized Servicer in your area that can tell you the price of repair, by clicking on the Samsung link: http://www.samsung.com/Support/ServiceLocations/index.htm
Apr 22, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung HL-P5063W 50" Rear Projection HDTV Logo
94 people viewed this question
Henry  Thomas
Henry Thomas
