Question about Amana Refrigerators
Don't know how to remove drain pan from the bottom/back of our Amana refrigerator. Model #ABB222aFEB (freezer on bottom)
My solution will cost you $39.95 and I will wait another 24 hours before sending you the answer. YOU'VE GOT TO BE KIDDING ME!
Posted on Jun 09, 2008
My refrigerator door is not closing tight - and water is leaking from the freezer.
Definitely a clogged drain line. you will need to remove the back wall and pour hot water into the bottom middle in the back of the freezer compartment, one glass at a time, until it drains through to the drip pan at the bottom of fridge. It is a messy job but the results will save a good fridge.
Good Luck
Mastatech!
Sep 08, 2011 | Amana ATB1832AR Top Freezer Refrigerator
I have a Amana Bottom Freezer Refrigerator Model BC20ML that is about 20 yr.s old, works fine except the drain tube from refrig. compartment to evaporator drain pan sames to be plugged. Water and ice...
You have to remove the bottom drawer, remove one of the drawer slider mounts on the freezer wall, and remove the rear panel. If yours has an ice maker you will have to disconnect it and remove it also. Unplug it so the water valve does not dump water on you while you are working inside.
Aug 13, 2011 | Amana Refrigerators
Our amana bottom freezer refrigerator Model ABB2224DEQ at times leaks onto our kitchen floor. We don't have an ice maker so I am wondering where it would be coming from and what needs to be done to...
This is likely water from the auto defrost operation leaking from the evaporating pan. Sounds like the pan may have a hole in it, or the hose which drains the water into the pan is leaking, The pan is at the very bottom of the unit.
Charlie
Mar 27, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Where is the drain located in the amana refrigerator that empties the water into the bottom drain pan? ModelTC20E-L Amana frigerator
Good day,
In the freezer compartment, after you remove the rear panel, you will see the cooling (evaporator) coil. There is an aluminum pan directly below the coil. The drain hole would be obvious unless it is iced over, in which case you would need to melt the ice out.
It is connected to the drain hose which you can see by removing the back bottom cover of the machine that houses the compressor. If open and working properly, the hose carries the water to the drain pan which allowsit to evaporate.
If the freezer has an ice maker, it will have to be removed first. In addition any support brackets if they prevent the removal of the rear panel.
Jul 26, 2010 | Amana ARB8057CSL Bottom Freezer...
The inside of the refrigerator get full of water condensation(lots)
It is not condensation
The drain at the bottom of the freezer under the coils is clogged. Remove Icemaker if you have one, remove bottom floor of freezer, remove back panel of freezer. Use hairdryer to melt ice. ALL ICE MUST BE REMOVED. Use hot water and a turkey baster to get ice out of drain hole located about middle under coils. Be patient, do not chip ice with sharp tool. After ice is removed pour hot water down drain hole. Water must come out in drain pan under refrigerator(you may have to take front grille off to get to pan)
If Ice returns after a few weeks, you need to look at defrost thermostat which is usually clipped on cold coil at back of freezer. This part or the defrost timer could be defective.
Sep 14, 2009 | Amana Refrigerators
Leaking from side of bottom freezer
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Aug 26, 2009 | Amana ABB1927DE Bottom Freezer...
either you ice maker is overflowing,(not likely but possible) or you have a clog in your drain behind hte rear cover, not allowing defrost water to drain away in to the pan under refrig instead flowing to bottom of freezer area. rempove the rear cover and thawe all ice, especially near the middle of hte aluminum oan yull find a clogged/frozen drain tube
Nov 10, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Water dripping into refrigerator someone told me that the drain in the back of the freezer could be blocked, its a self free defrost freezer. cant find drain tube to check.
remove rear panel inside freezer and you will find drain pan at bottom with drain in the middle. probably blocked with ice. melt off with a hairdryer and follow up with hot water till water flows away freely
Sep 14, 2008 | Amana Refrigerators
Freezer leaks water!
luvbug, Your refrigerator is "frost free" which means it is automatically defrosts after the compressor runs 8 to 12 hours. The defrost cycle lasts approximately 30 minutes. If it is in normal condition, defrosted water goes through the drain into the drip pan under the refrigerator and then evaporates. The problem you are having is one of the most common - the drain line is clogged up. To fix it you have to remove the freezer drawer, defrost and clean the drain. The drawer removal procedure described in the refrigerator manual book. If you do not have one you can find it there: http://www.amana.com/amana/jsp/manual.do You will see the drain hole on the freezer floor by the rear panel. To defrost it you can use your hair dryer. To make sure it is open, run a cup of very hot water through the drain. Reinstall the freezer drawer and enjoy it! Gendos....post it back
Dec 21, 2006 | Amana ABB1927DE Bottom Freezer...
Refrigerators Logo
63 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
