Back to:
Tags:
Haier HPAC99ER Air Conditioner
Haier HPRD12xc5 triangle with ! light is on and it...
posted by ladyphoto on Jun 08, 2008
I set up my airconditioner and it worked and then it just went off. I found the plug in the back and emptied the water out of it (maybe 1 cup?) and it turned back on for about an hour- then went back off again. I emptied it again (this time a little less), and now it is working- I used this ac all last summer without any problems- what can I do about this?
Thanks
Rebecca
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jun 16, 2008
FixYa! (100)
Richie_asg1
Rank:Guru Guru
Rating: 86%, 183 votes
I think this a fault with the cooling compressor.
When it cuts out aggain, turn off and unplug. See if the compressor is hot to the touch. If it is, I think it's tripping the overload protector. This is usually due to a faulty capacitor.
If you are unable to check the unit, take it to a service centre, or call an engineer to check and replace the defective components.
Hope this enables you to resolve the problem. If it does, please rate this as Fixya, or contact me again for further help.
Would you like the number of a local engineer? If so please supply your Zip code and I will contact one for you.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Haier HPRD12xc5 triangle with ! light is on and it keeps shutting off:
I don't want to Accept this solution
Solution #2
posted on Aug 20, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
The compressor will always be hot if running :/
Thank You!
Can you Help with these Air Conditioners problems?
@ days ago storm blew out power. Including Air Conditioner...
I have a haier 5200 btu room ac stuck on fan mode, changed...
I have had this unit for a year, but just out of warranty....
Hey people! The unit was working just fine yesterday....
Doesn't bring temp. down. Pulled off covers. The...
Loading problems.
Repair Service
Find Air Conditioner Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
