Intel Desktop Board SE440BX-2 Motherboard Logo
Posted on Oct 25, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have p3 550 Mhz system i want to install 80 GB hard and increase RAM so i need updated BIOS for my System
sentsignal7
Level 2:
  • Expert 186 Answers
  • Posted on Oct 25, 2010
sentsignal7
Expert
Level 2:
Answers
186
Questions
Helped
41182
Points
666
You can find info about flashing the BIOS at the motherboard manufacturer's website.
1helpful
How do I upgrade my bios for toshiba laptop ?
Why do you want to update the BIOS of your laptop? Be careful about updating your BIOS because it might cause your computer to crash.
Or are you trying to update the drivers in your computer?
If you are having some issues with its performance, then you need to update all the outdated drivers in your computer. I know that it's a total headache if you do the update manually but don't worry because there are Automatic PC Updater like RadarSync. It will scan and update all outdated drivers in your computer.
I hope this helps!
David
Installed physical memory 4 GB but total physical memory 2.67GB
You need to be using a 64-bit operating system to address all 4GB of RAM.
Sir my inspiron laptop b130, intel pentium processor 1.70 mhz 598 mhz, it is suitable for upgration r not? ram 1gb. 40 gb hard disk.? I need 2 gb ram and 500gb usb hard disk for oracle applications...
Max RAM for that system is 2GB
http://www.crucial.com/store/listparts.aspx?model=Inspiron%20B130&Cat=RAM
The question is whether there are 500GB hdds for that system. The largest PATA HDD I found was 320 GB
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4600076&CatId=2675
and there is no guarantee the BIOS will recognise a HDD that large as PATA HDDs require BIOS support for the drive size where SATA HDDs will pretty much work.
My recommendation is to retire this system and BUY a new one.
http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=631874&csid=_23
I am using Intel845 motherboard and intel 2.4 p4 processor and 1gb ram. Can i install windows vista or windows 7 or microsoft server 2008 , is they supported to my Configuration. Any updates need to meet...
For Windows Vista to work : It requires minimum 2.0 ghz processor, 1 gb RAM and 60-80GB hard disk.
For Windows 7 : It requires minimum processor 3.0 ghz, 1 gb RAM and 60-80 GB hard disk.
Otherwise, your operating system or hardware problem will occur.
I am having hp 530 laptop with intel core duo inside,512mb RAM,80 gb hard disk.I want to upgrade my processor,ramand hard disk. can i do it ? upto what limit ?
Unfortunately I would have to say no, you won't be able to upgrade the processor. I located a user manual at
http://h18000.www1.hp.com/products/quickspecs/12722_na/12722_na.PDF
According to specifications you can increase the Ram to 2 MB and the hard drive should be a 120GB hard driver Sata
System Memory 1024-MB 533/667-MHz DDR2 SDRAM in one slot
Two SODIMM slots; supported memory 2048 MB2
Operates at a maximum of 533-MHz with 667-MHz memory
Hard Drive 120-GB3 5400 rpm SMART SATA
The processor will be limited to what the motherboard can support and it was designed for that 1.6 Ghz processor. Unfortunately it is very difficult to upgrade processors in laptop machines. I do have to ask how old this machine is. The specification indicates MegaBytes of ram and this is actually very little Ram in today's computing world. Most machines support at least 2 gigaBytes of Ram to start with.
4answers
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
1helpful
2answers
I have Acer laptop Aspire 5570z module Zr1 with memory 1GB I want to increase memory 2GB or 3GB Is it possible or not What will be the expenditure?
Your laptop's RAM is upgradeable to up to 4 GB using two DDR2 533/667 MHz SODIMM modules.
So your upgrade options here are:
1. Buy a 1 GB DDR2 533/667 MHz SODIMM module & install it to get a total RAM of 2 GB (Price around US$ 25).
2. Buy a 2 GB DDR2 533/667 MHz SODIMM module & install it to get a total RAM of 3 GB (Price around US$ 45).
Hello , I just bought an 80 gb hdd. I installed it to a MS 6119 ver 1.2 bx2 board, but its not picking in bios. But with Winxp it picks up when I start up the pc with xp cd, it picks up the 80 gb hard disk...
I am ArmyMason and I believe the issue is the hard drive is too large for the system you have. That board is old and back in the day they didnt support large hard drives. You could try using a boot disk and partition the hard drive into 20 GB drives and see if that works.
http://global.msi.com.tw/index.php?func=proddesc&prod_no=332&maincat_no=1
Link to specs.
Thanks ArmyMason
2answers
2.4ghz, 128ram, P4, 40GB HD.need to upgrade the system.
According to intel:
1.6 System Memory
The Desktop Boards provide the following memory features:
• Two DIMM sockets supporting one of the following10:
 2.5 V (only) 184-pin 200/266 MHz Double Data Rate (DDR) SDRAM DIMMs with goldplated
contacts, or
 3.3 V (only) 168-pin 133 MHz Single Data Rate (SDR) SDRAM DIMMs with gold-plated
contacts
• Unbuffered non-ECC DIMMs only
• Maximum total system memory: 2 GB; minimum total system memory: 64 MB
• Serial Presence Detect (SPD) DIMMs only
• Suspend to RAM
And yes, you can increase the hard disk.
ASUS P4S533 mother board not supporting full 160 gb
This is happing becuase of your motherboards BIOS !
Really, this happened to me too. You see, our motherboards which are very old cant support above 80 and so on. This is beacuse of the BIOS. You will need to update your BIOS inorder to give new features.
Try go to the Asus home page and download the latest driver for your motherboard. Then install it in your motherboard's BIOS. There is intructions for this in the Asus's home page.
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
