After i shut the olevia lcd tv off it wont power back on
  • 203 Answers
Needs inverter board, or drive transformers on inverter board replaced. If 30" screen, board is p/n (48.v1448.001/f). Maybe you can search for part by model # if no luck with that number. Hope this helps.
Posted on Jun 09, 2008
Olevia 37" LCD TV will
my olevia a 232 s12 2nd hand tv . gift from a relative wont power on .just had the blue light on.i was able to reset my 32 inch olevia by pressing and holding down the power button much like a computer to reboot.might work for you.
Aug 20, 2011 | Olevia LT32HVM 32 in. LCD Television
My Olevia 32 inch HD TV shuts offf every 2 minutes by itself. The power just goes off? I turn it right back on and in 1-2 minutes it goes off?
Have the power supply checked for bad capaictors on the power board. Also this board can be purchased for around $100.00 at
Nov 09, 2010 | Olevia LT32HVM 32 in. LCD Television
Olevia 32" lcd tv made a loud, popping noise, shut off & now it won't come back on. When it popped, I noticed a spark
It seems that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done. It is that sound that gives it away, this is a typical switchmode Power Supply problem.
Feb 03, 2010 | Olevia LT32HVM 32 in. LCD Television
My lt26hve is used as a pc monitor. whe the pc is
I don't think so! Some LCD panels have this option, but not Olevia. Unless you may raid thru the menu and find power save option: no signal shut down. I use to own One of the first "Olevias", but can't recall this option. But, newer "Olevias"are based on different platform, not those on "Wesitnghouse". Olevia use to be from Europe, now it's all China. I know, Audiovox has this feature.
Good luck,
Jan 22, 2010 | Olevia LT26HVX 26 in. LCD Television
Olevia 332h comes on for a few minutes then turns off
I have the same problem with my Olevia 332h. The TV shuts off after 10 seconds. I decided to wedge a desk fan in between the wall and the back of the TV. It worked! The TV doesnt shut off anymore. This problem is obviously heat related. I hope this information helps you.
Jun 03, 2009 | Olevia LT23HVX 23 in. LCD Television
Tv wont turn on worked fine last night
If there is no power at all, then the problem is likely the power supply unit.
The PSU must be tested, then eventually replaced.
May 30, 2009 | Spectroniq PLTV3250 32 in. LCD TV
I have a 47 a 32 and a 37 inch olevia tv. Just bought the 37 because i havent had any probs with the others. Well recently i moved my 47 inch and had it plugged into an outlet that had a one of those one into three strips plugged into the outlet and my tv kept shutting off. So i plugged it into another outlet and it worked fine so do try another outlet.
Aug 18, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Olevia flat screen
If you haven't tried it yet, pull the AC plug and let it stew overnight.
If it still doesn't come back or fails after a short time again, the power supply is probably faulty.
Aug 02, 2008 | Olevia LT32HVM 32 in. LCD Television
Power problems
I have a 32'' olevia 232v hdtv. I had a similar problem where the tv stays on less and less as you use it longer and it gets warmer. I called customer service and they explained that its most likely a problem with it is doesnt have enough power to run well. They said turn the TV off, then hit the master turn off switch in the lower back of the tv, then unplug everything from the TV, then unplug everything from the wall. Then after 3 or 4 hours, plug all back in and try again. Then they said if i still have a problem, call customer service at 1 866 9 olevia
Sep 29, 2007 | Olevia LT37HVS 37 in. LCD HDTV
Televison & Video Logo
79 people viewed this question
Top Televison & Video Experts
