SOURCE: Canon ZR60 Mini DV Digital, remove the cassete message
This is a tape transport problem and is expensive to fix. Unless you know a cheap tech, it's time for a new one. Be patient loading and unloading tapes. This is usually what causes this problem. The Yellow warning sticker is REALLY important. Another important item is to always use the same brand of tape because switching tapes causes a gummy build-up the makes tapes get caught in the machine.
Videoteacher
SOURCE: error C:32:11 what can i do
This error means that the heads are not turning. This unit requires service. This is not a homeowner repair.
Dan
SOURCE: Samsung SC-D363 Mini DV digital camcorder
sir if your camcorder is new then it has a warranty. we should send it first for their service because they have a spare parts for replacement and info. if your going to fix it by yourself then the warranty of that will be void. by the way the place for the service center for camcorder samsung in the philippines is in makati i think. i got a problem with my samsung just like your model and they told me that it is located at makati. hope that helps!
CHARCOIS
SOURCE: The camcorder casset is stuck in the eject
for tape loading issues,do a power reset procedure. make sure ac adapter is not connected.set cam to off position.remove the battery and leave the camera without power for at least a minute.use the ac adapter and turn cam on.see if this resolves it.if not...service is required.
