Question about Cyberhome CH-DVD 300 DVD Player
Cyberhome CH-DVD 300 DVD doesn't work, Help! please.
Posted by Takusan on Jun 08, 2008 Report abuse
When I insert DVD, the screen come out say that no CD, or bad CD etc. and can't display. I do not know what is caused this problem, since It works well before. Please help and teach me how I can fix it.
Thank you for your time and attention. I am looking forward to hearing from you as soon as possible.
Comment by Takusan, posted on Jun 08, 2008 Today I tried again to see if it work but t became entirely nothing work even I try to turn on power, and see nothing come out on TV screen, and light is still keeping on red. Those things of problem and truble to let me dubt that Cyberhome CH-DVD 300 is certainly not a good product. I am regreting that I bought this bad product of Cyberhome CH-DVD 300. Help, please
  • 1 more comment
  • Takusan Jun 09, 2008
    Where can I buy the capacitors of circuit board that as you said that use a 16 volt in place of a 12 volt ? Please help. Thank yu so much for your time and attention. I apreciate your help.
  • Takusan Jun 10, 2008
    Could you tell me the part number of capacitors for cyberhome CH-300 DVD player? they ask me the part number of capacitors when I visit online at mouser.com and digikey.com, thank you so much for your time and attention. I am looking forward tohearing from you as soon as possible.
  • Takusan Jun 15, 2008
    I need the parts number to order the capacitors, mouser.com and digikey.com are asking the part number of capacitors, otherwise they can't find the one what I need. Thank you, please help.
    Scholar:
  • 104 Answers
It sounds like a common problem with these units, which is easily fixed...
Open the unit and look at the capacitors on the power supply circuit board, there are probably some bulging or leaking caps on it, just replace them and you should be good to go. You should replace them with a little higher voltage but keep the same micro-farad value. ie: use a 16volt in place of a 12volt.
Posted on Jun 08, 2008
  • Barry Gardner
    Barry Gardner Jun 10, 2008
    Radio Shack or any TV Repair shop should have the capacitors you need.
    If you cannot find them locally you can buy them online at Mouser.com
    or DigiKey.com
  • Barry Gardner
    Barry Gardner Jun 15, 2008
    You can find the parts by their description and values...
    On the mouser site simply search for the capacitor value ie:
    for a 1000 MicroFarad 12 Volt Cap the capacitor will be labeled 1000u
    12v and you would search for 1000u 12v. This will produce many results
    which can be narrowed down easily. I suggest that you get 105 degree
    rated caps, so search for, as example: 100u 12v 105 . Any caps of
    the correct value will work, however there may be some that are
    phisically larger that the room you have, so you can measure the
    diameter and height (in mm) and look for the same size. When you
    replace the caps be sure to note the polarity and put the new ones in
    the same way. There will be a stripe down one side indicating the
    Negative terminal. Also be sure to get Radial caps (both leads on
    one end) and not Axial (one lead on each end).
    Hope this helps.
Tip
Cyberhome CH-DVD 300 Manual Have you lost your Cyberhome CH-DVD 300 DVD Player...
Have you lost your Cyberhome CH-DVD 300 DVD Player Owners Manual?
Would you like a digital, searchable version of the users guide?
The pdf version of the Cyberhome CH-DVD 300 DVD player is available here.
I hope that helps.
on Apr 10, 2010 | Cyberhome CH-DVD 300 DVD Player
Cyberhome Ch- DVD 300
Your advice was very helpful. After two+ months of tooling around and navigating around the menu blind I was on the brink of trashing it.
At first I tried the stop button with a dvd in the player with no success. After taking the dvd out, turning in off/on then pressing the stop button for 20 seconds the screen turned blue as said.
This help saved me a great amount of fustation.
Thank You!
May 27, 2008 | Cyberhome CH-DVD 300 DVD Player
DVD problem
I have a cyberhome CH-300 my player running 50mins and next stuck the move .
Feb 12, 2008 | Cyberhome CH-DVD 300 DVD Player
Remote Codes
I found the code...
In the remote codes guide, the Cyberhome DVD player is listed under "Portable DVD"...the code is 2083...worked for me, enjoy.
Dec 28, 2007 | Cyberhome CH-DVD 300 DVD Player
CH-DVD 300 Blank Screen
This is almost the same problem for me...Please provide a solution
Aug 16, 2007 | Cyberhome CH-DVD 300 DVD Player
Cyberhome 300 DVD Player: pal to ntsc mode?
You might want to reset to factory defaults, but there is an error in the manual. In order to reset to factory defaults, turn on (with no disc inside), DO NOT OPEN THE DISC TRAY, just press the stop button on the player for 5 seconds.
Aug 02, 2007 | Cyberhome CH-DVD 300 DVD Player
Remote Control?
first un-plug the unit for about 1/2 an hour it should default to english
Mar 12, 2007 | Cyberhome CH-DVD 300 DVD Player
RGN ERROR
I found A great website on only Cyberhome DVD problems and answers hope this helps. http://forum.cyberhome-help.de/viewforum.php?f=4&sid=a36c52c7bf9d531a54b649a1dcf1f02e
Oct 08, 2006 | Cyberhome CH-DVD 300 DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
121 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
