Question about Microsoft Windows Vista Ultimate Edition
Vista media center will not work
Every time I try to start my media center it tells me that a problem has occured and media center has to shut down and that microsoft will notify me of any solutions
Ferfwf3wrdwdqwsc
Posted on Oct 04, 2008
Windows media player won't work
Which operating system ? Which version of Media player ?
Though designed with Windows 7 in mind, Windows Media Player 11 (WMP 11) is fully compatible with Windows XP.
The trick is knowing which version of WMP 11 to download.
Different versions of the software exist not only for Windows 7, Vista, and XP, but also for both 32-bit and 64-bit Windows XP.
Additionally, WMP 11 is only compatible with XP if it is using Service Pack 2 or Service Pack 3. Before downloading the appropriate installation file, you will need to verify which version your system requires.
Open the "Start" menu.
Open "My Computer."
Click "Help", then select "About Windows."
This will display a window with system information.
Find the listing that specifies your Service Pack. If you are operating without Service Pack 2 or 3, you will need to install one (see Resources).
Open the "Start" menu and click "Run." Within the text field, type "winmsd.exe."
Click "OK." Select "System Summary."
Find the heading labeled "Item."
Under this heading should be the word "Processor."
The value associated with "Processor" will determine which version of Windows XP you are running.
If the value begins with "x86," you are running a 32-bit version.
If it begins with "ia64" or "AMD64," then you are running a 64-bit version.
Download the Windows Media Player installation file that matches your version of Windows (see Below).
http://windows.microsoft.com/en-US/windows/downloads/windows-media-player
Open the file once it has finished downloading.
This will launch the installation wizard.
Follow the onscreen instructions to install WMP 11.
The program should now run normally.
How to Fix Windows Media Center
Windows Media Center is the home entertainment hub on a Windows computer.
With Media Center, you can play live television, songs, DVDs and slideshows.
It is preinstalled on Windows XP Media Center Edition, Windows Vista Home Premium/Ultimate Edition and Windows 7 Home Premium, Professional, Enterprise and Ultimate editions.
From time to time, users run into issues trying to play audio or video files, or with an extender connected to Media Center.
Extenders are devices that allow you to "extend" the Media Center onto a TV screen or larger display.
The Xbox 360 gaming console is an example of an extender.
Launch Windows Media Center from your computer's Start menu.
Scroll down to "Music" on the Media Center home screen.
Select "Music library."
If you find an empty folder under "Music Library," navigate to the folder on your hard drive that stores your music file and add it to Media Center's library.
If the problem isn't an empty folder, look at the file extension on the music file that won't play. Media Center can't play files with unknown or incompatible extensions.
If you find a questionable extension, skip that file. Click once on another file with a different extension, one you know is compatible with Media Center, and then click "Open" to test if you can play that one.
Media Center will play MP3, CDA, WAV and other music file formats.
Open Windows Media Player from the Start menu if you receive a codec error while trying to play either audio or video files.
If you open the file in Media Player, the codec will download automatically.
You should then be able to play the file in Media Center.
Troubleshoot your firewall settings if a Media Center extender doesn't work.
You'll have a problem using an extender if Windows Firewall blocks it.
Go to "Control Panel" from the Start menu and double-click on "Windows Firewall."
Click on "Allow a program or feature through Windows Firewall."
Click to check "Media Center Extenders."
Click on "Apply."
Check external speaker cables to make sure they're connected if you can't hear any sound. Check the computer's volume settings by clicking on the "VOL+" icon at the bottom right corner of the main Media Center screen to make sure the volume is not turned off or down too low.
You may need to reconfigure your speakers if you're having volume or sound issues.
Scroll down to "Tasks" in the Media Center home screen and select "Settings."
Click on "General" and select "Windows Media Center Setup."
Click on "Set Up Your Speakers."
Follow the on-screen prompts to reconfigure your speakers.
Dec 01, 2013 | Gateway ONE GZ7108 All-in-One Desktop PC
My media center stopped working due to error clr20r3. Could someone help me with this. Thanks.
http://mymce.wordpress.com/2009/07/17/fixing-clr20r3-issue-in-windows-media-center/
Is a site which has some suggestions, every one seems to say the same thing.
you could also poke around on google and use the search of MEDIA CENTER VISTA ERROR CLR20r3
Seems a very common error.
Nov 11, 2009 | Microsoft Windows Vista Ultimate Edition
Dell Media center
go to Dell.com........go to drivers and downloads.......check to see if there is an update for the media center from them if there is download and install. When media starts up just reduce it so that you don't shut down in order to get any updates for media center. If Dell doesn't have one try Windows updates and see what updates they have for your system. If you have any questions just ask and I will answer as soon as I get it.
Thx
Aug 01, 2009 | Dell Inspiron E1505 Notebook
Black screen error boot manager missing
sometime system restore wont work other solution might be to pop in your Xp or Vista cd assuming thats what you have.... and shut the Computer off and back on at start up during the first screen usually press F8 a couple times and select Option A and try the first option it gives you after that and continue down that list if it don't work then a reformat is the solution usually...
Jul 26, 2009 | HP Pavilion Media Center m8425f 2.66GHz...
Speakers work fine,then they stop working...
This usually occurs if you have to much running in the background. Nothing to do with the speakers.
Try this;
start button>msconfig>startup tab>disable all (remember which you turned of so you can turn them back on later. Now reboot and then try your media player. If they work fine now, you know you are running out of memory. Either turn on only essential programs, or increase your computers ram (memory)
Apr 03, 2009 | Logitech Z-2300 Computer Speakers
Compaq Presario CQ50 Labtop, makes awful constant beeps
If you shut it down when WinFlash was running, then bad news - BIOS corrupted. This means faulty motherboard. Solution - replace motherboard.
Mar 11, 2009 | Acer TravelMate 2480 Notebook
I have DELL Inspiron 1525 with Vista and working fine normally. But today i tried to use the Media Direct and it failed. Now iam getting 'NTLDR missing, press any key to restart' message. I have data on my...
or just try starting your laptop with the home key located to the right of the power button. when started close down correctly with shut down from the start menu.
hopefully problemo vamooosh
Mar 08, 2009 | E-Machines eMonster 600 PC Desktop
Xbox 360-computer?
To connect the Xbox 360 console to this computer, you must be running Windows XP Service Pack 2, Update Rollup 2 for Windows XP Media Center Edition 2005, or Windows Vista.
To obtain your setup package or instructions for connecting your Xbox 360, select the version of Windows installed on this computer from the following list.
To determine the version of Windows XP Media Center Edition that you are running, follow these steps:
  1. Start Media Center.
  2. On the Settings menu, click General.
  3. Scroll down, and then click About Media Center.
  4. Click Software Version
    The version number of Media Center you are running is displayed.
To determine the version of Windows XP that you are running, follow these steps:
  1. On the Start menu, right-click My Computer, and then click Properties.
  2. On the General tab, under System, look for the version of Windows that you are running.
Oct 05, 2008 | Microsoft Xbox 360 Console
Microsoft Windows Vista Ultimate Edition Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
