Question about Dishwashers
Dishwasher leaves heavy residue
For some reason my GE dishwasher leaves heavy residue on all of my dishes wether it's full or a light load. I use jet dry and pre rinse everytime. The model number is GSD2000J01BB and the serial number is GL717562B. Any suggestions will be greatly appreciated.
  • 868 Answers
Check your spray arms and look for the holes that water sprays through .Are there any clogged holes.Clean them if you see they are clogged.If not clogged up,your heater is not working ,check for voltage > 120V. If you have 120V. Check water level,it should be just under the heater. PLEASE LEAVE A RATING !!!!!
Posted on Jun 08, 2008
My Maytag quiet series 200 is not cleaning and despite many attempts it is also leaving terrible residue on dishes.
I found this on ehow I believe it will help. How to Troubleshoot Dishwasher Residue By Dale Yalanovsky eHow Contributor
5Found This HelpfulGeorge Doyle/Stockbyte/Getty images
Dishwater residue is a fairly common occurrence, and several things can cause it. Even the newest dishwashers may leave residue, and it might have nothing to do with the actual dishwasher function itself. However, there are things you can do to prevent, limit or completely remove dishwasher residue during every washing cycle.
Other People Are Reading
  1. Detergent Residue
    • Modern phosphate-free detergents are the main culprits when it comes to detergent residue. After every wash, many leave a slight whitish residue behind. After several washings, the residue becomes caked on and leaves a noticeable white tint to your dishes. Some dishwasher detergent brands are better than others, and either minimize residue or do not leave any. Once residue is present, however, the only way to remove it is by hand scrubbing or scraping.
    Hard-Water Residue
    • Hard-water residue comes from non-softened water from your hot water tank. Non-softened water leaves a white tint on dishes, but no amount of scrubbing will remove it. Only by wiping a small patch of the dish with vinegar or lemon juice will you be able to ascertain whether the white residue left is hard water or detergent. The slight acidic action of the vinegar or lemon juice removes hard-water stains, but they have no effect on detergent residue.
    Greasy Residue
    • If the dishes feel greasy when they come out of the dishwasher freshly washed, you are dealing with a greasy residue. There are two main reasons for this: either the detergent is not an effective grease remover, or the hot water inside of the dishwasher, either from the hot water tank or the dishwasher's heating elements, is not hot enough. Boosting the hot water temperature on the water tank may solve the problem, and a second wash cycle may be needed for the dishes. A preventive measure of running the dishwasher empty with a full load of detergent also removes the residue inside of the dishwasher.
    Streaking and Spotting Residue
    • If you have spotting or streaking on your dishes, that may be a sign you need a rinse agent. Many modern dishwashers recommend a rinse agent to prevent spotting or streaking, and without one, your dishes will never be crystal clear or streak-free. The next time you do a dishwasher load, add a rinse agent. If the dishes come out spot- and streak-free, the problem is solved.
Read more : http://www.ehow.com/info_12285021_troubleshoot-dishwasher-residue.html
May 19, 2015 | Maytag Dishwashers
Built-in dishwasher. dishes not clean, plus nasty white residue on everything...
Hi
The white residue is from the new environmentally safe soap. Check your soap and see if it is phosphate free soap and that will be your issue. Also either you have hard water or you're seeing either calcium or lime deposits. You should use the jet dry for every load. There should never be any suds in a dishwasher. Do not use liquid dish detergent for the dishwasher.Try running a load without dishes, using vinegar, or a bottle of Dishwasher Magic. Another possibility could be you're not getting enough water. The level should be close to the heater(check your tech sheet to be sure). The water temp should be at least 140 deg.F (no matter what the box says) Also, use a good brand of detergent (Cascade) and be sure your wetting Agent dispenser is full. (jet dry)You should not have to pre-wash your dishes..just scrape them well.The detergent actually needs some dirty dishes to work properly..fats, protien, etc. to make up 1 more chemical for the detergent.Another important step is to run the hot water faucet before running your d/w to "purge" the cold water out of the line.
Also check this links for some helpful information:-
http://www.appliance-repair-it.com/dishwasher-leaves-white-film-on-dishes.html
http://askville.amazon.com/dishwasher-washes-dishes-clean-white-residue-problem/AnswerViewer.do?requestId=6117170
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6192
Please get back to us if you have further query else please accept this particular suggestion.
Thanks for contacting fixya.com
Aug 23, 2011 | Kenmore 16602 / 16604 / 16609 Built-in...
I have a brand new dishwasher and it leaves a white residue on my dishes. I has jet dry filled to the top. please help.
Check the manual for the settings for the rinse aid dispenser, and try the recommended settings. Also, try using less detergent. It sometimes takes a little tweaking to get the right amount of soap and rinse aid for a given machine with a given water hardness.
Mar 16, 2011 | GE Dishwashers
I have a DD603 Double drawer Fisher and Paykel dishwasher, it is leaving a residue on the dishes. I currently have Jet Dry in the rinse aid reservoir. What is causing the dishes not to get clean?
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Nov 29, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
White powder residue left on dishes after washing. I run hot water before running dishwasher, use Cascade powder (fill dispenser less than 1/2 full per installer and do not use prewash detergent...
heatman101
Nov 10, 2010 | Whirlpool DU805DWG Dishwasher
GE Triton XL dishwasher, at first I had the left over powder soap issue until I dismantled the lower spray arm and cleaned the nets and removed the rusty particles in the hole in bottom of washer and also...
heatman101
Sep 25, 2010 | GE Tritonr XL GSD6260JCC Dishwasher
KITCHENAID DISHWASHER WONT REPEATEDLY WONT RINSE DETERGENT OFF
Fist what detergent are you useing is it dishwasher detergent and second the dishes wet and stemy how long do you wait after the machine has completed the cycle before opening it
Jan 21, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
I have a whirlpool quiet partner dishwasher that is not getting even light food residue off the dishes. Cycles seem to be running and progressing normally, tho I do not think the water is spraying from the...
Welcome to fixya,
You said, you have a whirlpool quiet partner dishwasher that is not getting even light food residue off the dishes. Cycles seem to be running and progressing normally, tho you do not think the water is spraying from the arms with adequate force.
I have the same machine.
And I notice if I leave the dishes in the sink rather than rinsing them off and putting them directly into the dishwasher, (Like My Wife says to do). That sometimes I have the same problem.
So I bought Jet Dry, and filled the holder. It's a small sometimes clear plastic knob that unscrews out above the soap dish.Fill it once a month!
Do you put the detergent in both cups or only the closed one?
1. If the load is not real dirty you should only have to fill the one with the door that closes.
If it is real dirty then both. To always use both is a waste of money!
2. If your hot water heater is far from your dishwasher, let the hot water tap run a minute till it comes out hot, before starting the dishwasher.
3.If the dishes or pans are very dirty and or baked on use hi temp scower and heavy or potscruber for those loads.
I use heavy wash and hot temp scower if the stuff is relly messy or dryed on.
And for baked on HI- temp scower and pot scruber which sprays harder.
You will have to experiment a little to see what works for you.
You will find it washeing good after you find what works for your families dish habits!
If you have any more questions let me know!!!
Please remember to leave me a solved before you leave the site.
Thank You for using us!
Huuum
Oct 02, 2008 | Dishwashers
Bosch dishwasher
Although I previously posted with the same problem of a film on the dishes after cleaning, I did find a section in the owner's manual which solved my problem. Lift up the rinse aid cap on the inside door - the factory setting is on "4". The rinse aid works in conjunction with your local water, which has variations in it's hardness or softness. When your dishes are streaky, lower the rinse aid setting to 1 or 2. If your dishes are spotted, raise the rinse aid setting higher.
Sep 23, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
485 people viewed this question
Top Dishwashers Experts
