Question about Frost Inglis 17.6 Cu. Ft. -Free Top-Mount Refrigerator - Silver - IT18SKXRD
Light off The light inside of the refrigerator went off
If not ya light bulb it might be light swwitch
Posted on Sep 01, 2008
    President:
  • 1,462 Answers
Probably just the bulb. look in yoiur instruction book and it will tell you how to replace. usually just a matter of removing the cover over the light
Posted on Jun 22, 2008
The Fresh food light and the display lights went out at the same time.
Thank you for your post, Gearld Beebe!
I understand that the light inside of your Frigidaire refrigerator and the display lights are no longer working. It sounds like you could be having a faulty wiring issue or power issue. You may want to have a technician come out to review your refrigerator to assure each component is getting the proper amount of energy or have a electrician come out to review the receptacle to assure it is providing accurate energy. I hope this information is helpful. -Matt
Dec 12, 2014 | Frigidaire Refrigerators
Light stays on
Check the door frame for a protruding small lever that gets pushed down when the door closes. If one is visible, that should be the light switch, which probably went bad and needs to be replaced. Without a model # hard to say how the light are set to go off, but most use the above method, hope this helps.
Jan 30, 2014 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Our kenmore refrigerator/freezer went warm. We
It could be one of several problems -
1) Failed compressor relay
2) Failed compressor
3) Failed component in the defrost system
4) Bad door gaskets
5) Failed door light switch
Questions to answer -
1) Was the compressor (large black domed item with three tubes (one stubbed) at the bottom back of the frig.) warm or hot?
2) Was the condenser fan running?
3) Was there thick ice buildup inside the louvers of the back wall of the freezer?
4) Was the fan running inside the freezer?
5) Look up my "Tips and Tricks" article on testing your door gaskets.
6) Open the door slightly and look inside as best you can. Is the light on or off? Continue to open the door until you see the light go on to confirm the light switch is working.
Your response will give us an idea where to look to find the problem.
Dec 13, 2009 | Cars & Trucks
Inside lights in the refrigerator went out. replaced them and they still don't come on
Good day,
Other than a wiring problem (unlikely) then replace the light switch.
I'm assuming the machine is running properly and plugged in.
Nov 28, 2009 | KitchenAid Refrigerators
Power went out briefly. Refrigerator control
Press the Power Freeze and the Power Cool button at the same time. Hold for 10 seconds and the digital panel reset.
Aug 14, 2009 | Samsung Refrigerators
Blinking light in refrigerator
I think that's the light letting you know the door is open so it won't drop ice. When I held in the catch on the left side (as if the door was closed) the red light went off for me.
-Drew
Jun 21, 2009 | KitchenAid KSCS25FKSS Side by Side...
My Whirpool refrigerator light went out
the light switch may be faulty replace it
Mar 10, 2009 | Whirlpool ED2FHSS Side by Side...
Interior Lighting on True Refrigerator Unit
A starter may be located in the top area inside the cooler. Not all true coolers have starters. Check the connections where the light pins slide into. Also may need new ballast.
Jul 24, 2008 | True GDM-9 Beverage Cooler
Magic chef #rb19k-4a refrigerator: bulb replacement
unplug refrigerator look inside light socket youll see a tab in the bottom of the socket bend tab up alittle bit then screw light bulb back in. if this doesnt help then the door switch is bad
Nov 21, 2007 | Refrigerators
Refrigerators Logo
74 people viewed this question
Top Frost Refrigerators Experts
jdthefixer
Charles T Nevin
Charles T Nevin
Mike
Are you a Frost Refrigerator Expert? Answer questions, earn points and help others
