Question about RCA OPAL M4001 MP3 Player
OPAL won't charge.
My OPAL was working fine, and it has been having these moments where it just turns off, and I have to wait for the battery to die before I can charge it. Only this time, the OPAL won't charge! I've tried resetting it, checking the hold button, turning it off, and it just won't work! Any suggestions?
  • Anonymous Jun 11, 2008
  • tnene Jun 13, 2008
    it want charge or turn on
  • 8,596 Answers
Get the firmware upgrade for the player. If the pc will not recognize, force recognition:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If this does not work, I suggest that you reformat the player by using the WindowsTM format command on the unit. To reformat the memory
1. Right click on the device within the Explorer or My Computer window
2. Select the format command (full format) to reformat the internal memory of the device.
3. Reinstall the firmware from http://download.rcaaudiovideo.com/downloads/opal_fwutility_v2.3.0.exe
Posted on Jun 18, 2008
My car won't turn on it was working fine last
Just because you charged the battery it doesn't mean it is any good. Modern sealed batteries fail; just as you described, fine one moment and then nothing, they go open internally.
Jul 19, 2013 | Cars & Trucks
Won't start, but after sitting a day or two It starts right up.
check fuel pressure could have clogged fuel filter or bad fuel pump.
Jun 11, 2013 | 1995 Geo Prizm
2006 Jetta 2.5 battery died, jumped car, radio won't turn on
Take it in to have a charge system check done on it, Your alternator is probally shot,
Nov 27, 2012 | Cars & Trucks
Phone was charged yesterday and was working fine last night- This morning there is only a black screen / on/off button does nothing What is prob
Take out the battery and wait for 2 minutes. Re-insert the battery, try booting. If it doesn't work, then check whether the battery is charged or not.Give it for charging, wait a few moments it wont start charging immediately if fully discharged. Kindly comment if the problem persists.
Jul 23, 2011 | Samsung Galaxy S GTI9000 Smartphone
Rca opal 4gb M4304-A has completely stopped functioning
Wow, I didn't realize so many people were having the same problem I was having. First try re-installing the firmware for it. Since your computer won't recognize it you will need to download the software, then you will have 2 boxes pop up. One is the install instructions and the other is the actual program install. You will have to hold down the play button on your player while you plug it into the computer. DO NOT RELEASE THE BUTTON UNTIL THE PROGRAM SAYS "INITIALIZING".
It should work fine once you do this. I spent 3 hours going through RCA's website before I came across this step.
Nov 22, 2009 | RCA M4304 Digital Media Player
Frozen rca mp3 player
wait until the battery dies, then charge it
Apr 11, 2009 | RCA OPAL M4001 MP3 Player
Problems With My RCA OPAL Mp3 Player
I have an opal also and it sounds like yours is defective.You should try returneing it to the factory if it is still under warrenty.
May 03, 2008 | RCA OPAL M4001 MP3 Player
Rca opal mp3 player
leave it on till the battery runs out or push the reset button on the back of the player with a pin, or a paperclip
Mar 23, 2008 | RCA OPAL M4001 MP3 Player
WWON'T POWER ON
For one, you don't need the CD to put music on the Opal. It's a plug and play device. Go to My Computer on your desktop and you will see under Audio Devices "OPAL". Click on that and you'll see a folder called "Media" and that's where you put your music.
For not turning on, click Pause/Play twice
For charging, You need to plug in the USB cord into the computer to charge it. Wait 3 hours. The Opal doesn't have a real long battery life, i'd say around 10-15 hours. So you'll be needing to charge it quite a bit.
Dec 23, 2007 | RCA OPAL M4001 MP3 Player
Motorzor
you simply fried your battery by overcharging it. Just get a new one, let it fully charge and fully die twice before you start normal charging. Then you will want to only charge it for about 2 to 3 hours or find a charger that has a smart chip that tells it when to stop charging once the battery is full.
May 13, 2007 | Motorola Mobility RAZR V3
RCA OPAL M4001 MP3 Player Logo
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
