Question about Nikon Cameras
Nikon D300 constant flashing of CF lamp My D300 CF lamphas recently started flashing continiously when the camera is switched on or off. The battery power is completely drained within 12hours, despite having switched the camera off. I have three Compact flash cards that seemed to be working ok without a glitch. I have tried reformatting the cards in the camera but no luck. I hvae the following cards. (SanDisk extreme III 2GB, Lexar Professiional UDMA 300x speed 4GB& 2GB). The camera is still operating fine, with the exception of the light flashing and battery power being drained. Can anyone help please? "no information is available in the owners manual under trouble shooting"
  • 2 more comments
  • gflickr Jun 08, 2008
    HEY DO YOU CONDUCT A HARD RESET?
    Thanks I will try tomorrow and post a reply.
    Do I also need to have the Compact Flash memory card out of the camera for 24 hours?
  • gflickr Jun 10, 2008
    I followed your instructions and this addrssed the problem. The CF lamp stopped flashing.
    Today the problem has resurfaced again! Any other suggestions that you can recommend ?
    Regards Gary
    Guru:
  • 1,894 Answers
Did u do a hard reset?
Posted on Jun 08, 2008
  • 2 more comments
  • dewan nafees ahmed Jun 08, 2008
    because if u do a reset properly u can get it fixed easily.
    dont put in the batteries in camera for 24hours.
    then after that press the switch ON button with out the batteries.
    now put in fully charged batteries.
    now switch ON the camera.
    this is done to remove the stored unnecessary charges.
    that is so nice of you.
    i shall wait for your response
    yes sir
My nikon d300 will not format the SD card....
Hi, Dear
Nikon D300 does not use SD card! It use CF card.
But if you have format problem in camera then I recommend format from a computer using memory card reader. And then put the memory card into camera and try to format! Here it does not, then you should show to your local repair shop and it will cost between $120 to $265 usually. In minor problem case it will be replacement of memory card acceptance unit replacement. But the problem come from main pcb then the estimate will be totally different!
Hope You Luck! A Professional Camera Clinic Guy
Apr 05, 2015 | Nikon Cameras
CONSTANT FLASHING CF LAMP NIKON D300
Am afraid that it is an internal hardware problem. Chances are that the electronic trigger that fires the flash has shorted out and is therefore making the flash work even with the camera off. Since this would involve electronic circuitry and components, use of a DVM and a low wattage soldering iron or even a hot air blower, perhaps your best bet would be to seek the services of a qualified professional. Often even if you can actually open the unit for a look and see of the trigger/flash module, replacement part availability would be a major concern.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 07, 2008 | Nikon D40X Digital SLR Camera Digital...
D300 pop up flash button broken
Do you mean that the flash won't pop up? The usual cause is either impact to the flash unit or sticky liquid spillage on the flash causing it to stick down. Unfortunately Nikon stopped selling parts on July 13th so unless you can find parts on Ebay you will need to send the camera to Nikon to repair an impact problem. If the flash button is stuck it may be broken.
Aug 27, 2013 | Nikon D300 Body Only Digital Camera
Sigma ef-500 dg st won't work with my d300 or 200 in ttl mode
This Sigma flash is not Ittl compatible. The D300 and D200 Nikon must have Ittl compatible flash to operate in any of the Automatic modes. It is a great flash but will not work on those two cameras.
Dec 14, 2010 | Sigma EF-500 DG ST for Nikon Flash
Price for nikon d300
D300 can be found scarcely new. It has been replaced with a newer model D300S. The D300S incorporates video and both SD and CF capability for extended uses of writing the photos. One card can be used as backup, or one can be used to write RAW files and the other JPEGs. Some slight changes were added to the menu {active D-lighting}, and the D300S also was give a slight boost to 7FPS. Used D300 on the market go for $900 - $1300 depending on its history.
Apr 02, 2010 | Nikon D3000 Digital Camera
Nikon D300 and Quantaray Flash...
I use their products and have had great success as well as great response. I don't have the Quantaray, but if you contact them they will most likely have a direct solution for that flash.
http://www.flashzebra.com/products.shtml
Mar 08, 2010 | Quantaray QDC-900WA for Nikon TTL Flash
Don't know which card Nikon coolpix900
I believe the coolpix 900 takes compact flash (CF) I wouldn't worry about getting a particularly good one though just a standard CF card would be sufficient for testing purposes.
hope this helps.
Drew
Nov 15, 2008 | Nikon D300 Body Only Digital Camera
Sensor Cleaner making noises?? (Nikon D300)
Yes, all D300 makes this noise when the sensor is being cleaned.
Apr 24, 2008 | Nikon D300 Body Only Digital Camera
Nikon SD card for D80 / D200/ D300
You should have no trouble using the SDHC cards. SDHC stands for Secure Digital High Capacity. The images should load directly from camera to computer, without the need for any additional hardware.
Feb 12, 2008 | Nikon D80 Digital Camera with 18-135mm...
Cameras Logo
109 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
