Question about Goodman GMS90703BXA Heater
AIR or Heat wont come on/ goodman GMP075-3
MY Goodman GMP075-3 unit will not come on. The Status light is red, I checked the fuse, and replaced the Termostat. nothing worked.
  • rhglass59 Jun 27, 2008
    I have the same model. I disconnected the thermostat so the unit would run independently and the ignitor ignites and the fan blower comes on. I checked for frayed wires in the low voltage but didn't see any. I think checked the transformer to be good. Other than safety low voltage relays, door switches and thermal overloads, the only solution has to be the circuit board. The red light stays on constantly. I didn't see that in the code sheet. I would assume a solid 'green' light would indicate the board to be working correctly. Now who sells the boards where I won't be robbed.??
    Thanks.
  • deniseiscold Nov 17, 2008
    Does anyone know what type of circuit board to buy?
  • 1,420 Answers
If there is no blinking light, then the unit is not seeing a call for heat or cool. My guess is a lose or broken wire in the thermostat circuit. Try and putting a jumper across the red and white heat terminals inside the furnace and manually closing the door switch. If you get heat, it's telling you there is a wiring issue. If you get nothing, it's a bad circuit board.
Posted on Jun 10, 2008
1993 goodman status light 4 times blinking
Witch blower is running, the inducer or the systems blower?
System blower could mean the the high limit is opening and shutting down the systems gas train, I would check this out first.
The other problem could be with the pressure switch for the gas train, it is supplied from the inducer motor, check to see if it is operating fully.
HSI boards do go from time to time, this sounds more like a system control problem.
Jan 24, 2008 | Goodman GMS90703BXA Heater
Replaced the gas valve in my goodman furnace now it won't light and red status light stays solid
solid means it is on stand by, no call for heat, put jumper wire between r and w it should start, if it does check t- stat
Oct 27, 2015 | Goodman Heating & Cooling
I have a Goodman CPE30-1AB (Outside heat exchanger), with a Goodman (air blower) as well. Air blows inside, but not cold. Outside unit is not turning on at all. Can you please assist?
check your breaker or fuses at outside unit. verify you have 24 volts feeding outside unit replace outside unit contactor if you have the 24 volts and not starting.
Aug 08, 2015 | Goodman Heating & Cooling
What cause 3 amp fuse to keep blowing when power in turn on goodman air handler
The 3 amp fuse is in the red low voltage (24 volt) thermostat wire
and only gets power when the thermostat is set to turn on heat or a/c It should be connected to the red wire from the thermostat
Nov 13, 2014 | Goodman Manufacturing Goodman ARUF48D14...
Whats wrong with this A30-15 electric goodman heat/air furnance that will not turn on?
CHECK FUSE INDE UNIT ON CIRCUIT BOARD. TURN OFF POWER BEFORE STICKING HANDS INSIDE TO PULL FUSE OFF OF CIRCUIT BOARD
Jun 09, 2014 | Goodman Heating & Cooling
My Goodman Condensing Unit will have fan operation, but the compressor remains off. I've confirmed fuse and thermostat status, and everything appears normal, just no A/C. Any suggestions?
If you mean the fan on the outside unit is running,first I would replace the capacitor on the outside unit. Also check the wires on the compressor for a loose or broken wire.
Sep 11, 2011 | Goodman CKL36AR36 Air Conditioner
Goodman gmp0503 unit has status light blinking slowly all the time. The indoor blower wont even come on when you switch from auto to fan on thermastat. The status light says for one blink to check gas...
Take a jumper wire and jump out the R and W terminals on the furnace. The heat should come on. If it does not, you have a bad board. A steady blink indicates no call for heat. You may have either a broken thermostat wire or a bad thermostat if unit fires when you jump it.
Mar 20, 2011 | Goodman Heating & Cooling
Goodman GMS90703BXA Heater Logo
422 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
