Question about Mitsubishi WS-48311 48" Rear Projection Television
Mitsubishi WS 48311 48'' HD 1080
I need a power supply and a new screen can anyone help me on how i can prder those parts ?
  • MoCountryboy Jun 08, 2008
    thank yopu for your quick response but im afraid as far as a screen goes im not having any luck :(
  • Mitsubishi Master
  • 8,617 Answers
There no longer available from mitsubishi, but the following link may have them or can get them. leave them an email with the model number of your set and what youre looking for.
http://servicemanuals.vstore.ca/
Posted on Jun 08, 2008
  • Sonny Berry
    Sonny Berry Jun 08, 2008
    that site should be able to help you out with what youre needing
I have a Mitsubishi 55" 1080 HD TV with a blurry
info16939,
You need to go to my tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which should solve your problem.
Thanks for using FixYa and for the great rating.
hardrocko
Dec 15, 2010 | Mitsubishi WS-65313 65" Rear Projection...
I have a Mitsubishi HD 1080 55
Your unit has some sort of Thermal problem either with the PSU fault, or a thermal problem elsewhere that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur. T
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Jan 24, 2010 | Mitsubishi WS-55805 55" Rear Projection...
Mitsubishi WS-55513 wont go from 480i t0 1080
Tries CBS or NBC channels have HD if displayed 1080i than ur box is working.The shows must say HD or Display 1080i to work HD programming.
Jan 15, 2010 | Mitsubishi VS-60111 60" Rear Projection...
I have an Mitsubishi HD 1080 big screen tv. When
Ur power ic inverter board is dead.
U need a new one.
Aug 26, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Diagonal colored lines run through the screen
Replace Both of your convergence ICs STK392-570 ICs will have Part number on them use same as old ones call 1-800-628-1118 MATS for parts.
Aug 07, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-65315 plug in HD comp shows as 480i
Greetings,
In the input assignment menu make sure that the DTV (the only 1080 input on this tv) is set to Y/Pb/Pr and see if that fixes your issue with at least the HD-DVR.
BTW- the HDMI information "1080i HD can only be selected if TV has HDMI inputs". is not correct.
Feb 25, 2009 | Mitsubishi WS-65315 65" Rear Projection...
MITSUBISHI HD 1080 series
most likely the convergence Ics have failed. Check F9a04 and F9A05 pico fuses if they are blown you will need to replace them and the convergence Ics.They are located on the center board they are green and look like resistors without the color band. see the photoa193b32.jpg82b89b8.jpg
Feb 08, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Need plexi-glass cover off my mitsubishi hd 1080 projection tv.
the plastic trim pops off and there are screws that hold the glass in place that you have to take out to be able to remove the plexi. it takes about 20 minutes to do
Jan 27, 2009 | Mitsubishi WS-55513 55" Rear Projection...
No color on mitsubishi 1080
1080 is a High Definition setting. If your Television is HD capabilities you need to make sure that the programming that you are viewing is being broadcasted in 1080. If it is not then you will see a difference in picture quality and sound. If no color at all and program being watch is HD programming check your connections on back of Television. depending on what kind of input the Television is receiving you might need to try new cables or a new input. Good luck
Oct 18, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi WS-48311 48" Rear Projection Television Logo
123 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
