Question about Husqvarna Designer I
How do I add new thread colors such as the varigated colors
I would like to update my designer 1SE software (Customizer, Stitch Editor, etc) to include varigated threads and new colors and they evolve. Is there a place to go to get new colors from Husq or is there a way to create them myself and add them into the system?
Thanks...pflucki
  • Husqvarna Master
  • 1,388 Answers
Contact Husky HQ in your country, or ask your local dealer for advice.
Posted on Jun 09, 2008
Having difficulty with free motion machine embroidery on my Janome Mystyle 16, top thread keeps breaking. What can I do to stop the thread from breaking? Plus the stitching is very erratic,any ideas?
1. Set up for regular sewing (not embroidery).
2. Adjust the tension of the bobbin and the top thread so that you have a nice straight stitch.
3. Check your thread quality. Is it fuzzy or have small trails sticking out. No Walmart thread allowed. Only top notch embroidery thread allowed.
4. When you've been successful with the thread and tension go ahead and set up for free arm.
5. Sew free arm but remember machine has to keep up with you. If you go too fast you will be pulling the thread and probably will break the thread.
6. Your erratic stitch is caused by the speed at which you are moving the hoop. Going fast; then slow is going to make a long stitch and then a short stitch, etc.
Apr 03, 2015 | Janome Sewing Machines
I need to adjust my baby lock and just can not understand how it works,the tension Dial with the Blue,Green,Orange,Yellow and purple, What is the right tension for light weight Fabric for the side sea
Try setting up your machine with the 4 different thread colors as the guide--use yellow thread in the yellow guide, blue in the blue, etc. This is a good way to figure out what is not working with your tension dials. To start out with a 4-thread stitch, set the tension dials at the midway point on each and then test your stitch. You should be able to see which thread colors are off. If one color is wrapping over the edge of the fabric, then that tension is too loose and the opposite thread may be too tight. The tensions are correct when the threads meet in the middle of the fabric. It's a matter of sitting down and playing with it to see what happens when you make changes to the settings. Also, one particular setting that works on a particular fabric may not work on another, so learning how to test and adjust is a big part of using a serger.
As for stitch length, that is mostly a personal decision. The shorter the stitch length, the closer the stitches will be.
The anatomy of perfect serger tension Sew McCool
Serger Tension Made Easy Do It Better Yourself Club
There are many web sites and videos that could be helpful.
Feb 10, 2018 | Sewing Machines
I have the old VIP Customizing software for my Des 1 and my Iris My computer was stollen and I do not have the RSWE file needed to update my dongle to make it work....VERRRRY upsetting since HUS does not...
If you have the disc to install the program if should also install the dongle automatically. I just loaded my old copy 2 weeks ago and it was all done with that one disc. You have to install the software BEFORE plugging the dongle...
feel free to e-mail me lewgnr922@gmail.com
I'm looking how to put the sample fonts from the free floppies into the program to use on my designs. Disk Manager only does designs and customizer won't recognize the fonts directly off the disc.
Any suggestions??? lew
Jan 13, 2011 | Husqvarna Designer I
In the middle of stitching a design - and when I came to a color change, the new color began stitching 1 to 2 inches below where it should. The screen showed the correct place, but the needle was way too...
If the design isn't too big, try rotating it in the hoop and stitch it sideways. If it works in that position, you probably should have the embroidery unit cleaned. I recommend the embroidery unit be serviced every 5 years. It may need it more often depending on your environment.
Dec 11, 2010 | Husqvarna Designer I
Can you backstitch during embroidery?
You don't use the back stitch or reverse button during embroidery since you are stitching out a design and not using your utility stitches. If you missed some stitches and you want to re-stitch a portion of your design or what I think you mean by "back stitch", there is a button that either says reverse, back or shows stitches with a + and - so you can backup and go over the area you missed. It usually lets you back up a stitch at a time, 10 at a time and 100 at a time. I use it sometimes to get a thicker satin stitch if it looked too thin the first time. Just be careful not to go over it more than once as it might bunch up. They also show a button usually with a spool on it so you can back up an entire thread color. It will probably be in your manual under "what to do when the thread breaks" or something similar. Happy embroidering!
Jul 04, 2010 | Baby Lock Ellure
Trying to sew straight stitch but stitch loose and lots of thread on bottom
No top tension, follow manual to thread top again and make sure tension dial is set to 5 and thread is pulled between the tension discs fully.
May 21, 2010 | Singer 57815 Mechanical Sewing Machine
I just purchased a Janome CM350E and need Customizer software
You can use any machine embroidery software brand.
There are many that have free trials and demos. Embird is one brand that is very popular.
You start with Embird Studio and then add other programs as you become more knowledgeable about machine embroidery.
All ME software products run on Windows XP, Vista and some are now compatible with W7.
You can find more machine embroidery discussions/questions and answers at sewforum.com
Mar 25, 2010 | Janome Memory Craft 10000
I have the same issue with my computer + Customizer for #1+
What is the issue that you are having? Tell me where the ball dropped and perhaps we can get it back into your hands.
I have a copy of VIP Customizing running today and still have the ability to write cards and stitch designs out on the #1+. What is the problem??
Jul 05, 2009 | Husqvarna Viking 1
Free Motion Sewing - Jams
The Designer 1 usually has a very nice free motion stitch using the V1 stitch. It should pull only slightly to the rear so that no bobbin thread shows while doing free motion embroidery. Upper tension may be increased for balanced stitch when stippling.
If your machine doesn't sew with the regular stitches with the teeth up, and it's properly threaded, the thread must be dragging on the bobbin case somewhere. First get the machine sewing a straight line, then try V1 again.
Feb 19, 2008 | Husqvarna Designer I
Cannot get Janome 10001 to read via USB direct link from computer
You need to have Customizer og Digitizer pro to send design by cable to you MC10001.
You can also use a PCMCIA adapter in your MC10001 and a CF memorycard..you also need a memorycard reader to write to your CF card from your computer
Dec 28, 2007 | Janome Memory Craft 10000
Sewing Machines Logo
133 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
