Question about Gateway 4028GZ Notebook
Usb trouble I have a problem with my usb ports in my gateway laptop. for some reason they quit working. I have down loaded new chip set drivers from gateway and can get two of the four working. They will work for a week or two then they quit working. so i again reload the chip set drivers and they will work for a while. When i plug anything into them it says the device is not working properly. I have unloaded and loaded the drivers several times but no help. I have even gone as far as formated the hard drive and reloaded the complete recovery cds. still it wont recognize the device no matter if its a mouse or my flash drive. help!!!
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 262 Answers
Ok common prombelm with notebooks what the prombelm is you are over loading your usb ports ( it happenes in note books nd laptops ) my sugestion is get your self a extension usb cord and that should take care of your promblem just amke sure that you keep the same thing plug into the same usb port onthe extension
and it should all work lala linda
Posted on Jun 08, 2008
  • 96 Answers
Update you device in the internet if didn't your again, try to used another OS. Use Windows XP
All usb ports on my gateway laptop aren't working... I've reinstalled the drivers several time, still no progress there... checked system BIOS all settings are correct, dont kno what else to do
http://support.gateway.com/s/Manuals/Mobile/8510913.pdf
this shows the user guide But I did not see anything for USB specific trouble shooting.
Other wierd things I have sceen...check ALL USB ports to make sure that they are not broken or have something stuck in them and are shorting out, can cause a MB functions to expire. Try a lighted item in the ports, is the say USB mouse lighting up? If so then this is a software issiue.
Turn off all usb functions and try rebooting then turn off and try them again only turn them on this time. You mentioned that you checked bios setting but did you also check to see if the bios needed upgraded?
Apr 30, 2011 | Gateway M360 Notebook
Gateway GT5228 - USB Ports & All-In-One Card Reader don't work...
what service pack froom MS have you downloaded and installed? Sounds like the SM BUS DRIVER ARE MISSING. Install SP3 AND LET ME KNOW.
Feb 16, 2010 | Gateway GT5228 PC Desktop
The USB ports on my Toshiba A135 S2356 laptop are not working. I tried to use my printer and it says not connected. I bought a new cord but it still doesn't work. What should I do?
1. first check ur USB port using any other USB device, like pen drive, mouse, keyboard,etc.
if system detects that device, then ur USB port is OK!
2. if USB is OK, then the problem is with the 'Printer Driver' not the cord!
3. reinstall the printer driver!
4. update the driver!
5. if USB port is not working, then replace it!
if this helps, tell me.......
Dec 30, 2009 | Computers & Internet
My gateway nx560x needs the bios updated and another driver re installed but windows will not load up what can i do?
hello, your model of laptop (NX560X) is able to boot of the usb port, what that means is even if you don't have the laptop working, and don't have a floppy drive, you can use USB flash drive, usb floppy etc to boot up the laptop from.
you should use other PC (perhaps the one you are using to post here :-)) to download bios from gateway website and then use usb device to boot your laptop. Below is the direct link for your laptop and here you will find latest firmware and drivers;
http://support.gateway.com/support/drivers/search.asp?st=pn&param=1008644
After you are able to flash the BIOS, test to see if the you can get into windows.
post back your results so we can further troubleshoot the issue.
hope this helps
regards
Amar Sondhi
Dec 07, 2009 | Gateway NX560X Notebook
USB ports no longer work
you need to check your device manager and make sure the device manager is reading the USB ports, if not, you will need top get a USB driver or go to ADD NEW HARDWARE, and search through there until you find universal serial hub or bus then click ADD
May 05, 2009 | Gateway 6510GZ Notebook
Why doesnt the mouse work usb ports no sound no key board
not quite sure what you mean ,motherboard controller;regarding usb they have their own controllers just a case of update drivers.windows update should do the trick unless you cant use net.in which case access from another pc and down load latest drivers for your model and instal
Jan 05, 2009 | Acer Aspire 5100 Notebook
Lexmark x2500m printer do not communicate with Gateway laptop
check it on device manager whether the printer is detecting or not, or put usb cable on some different port then check, also uninstall the drivers, then install it again
Oct 21, 2008 | Gateway MX6920 Notebook
Usb ports quit working in gateway laptop
This article references a Dell computer but maybe it'll work for yours.
Jul 04, 2008 | Computers & Internet
Vivitar v55 camera
The cable is not causing any trouble by simply being connected to the PC end. Remove all the camera drivers prior to reinstalling the software you downloaded.
Mar 26, 2017 | Vivitar ViviCam 55 Digital Camera
Gateway 4028GZ Notebook Logo
116 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
