Question about Microsoft Windows XP Professional
Can't connect to the internet new hard drive installed, windows XP pro installed when checking hardware : says ethernet controller driver - not installed. tried finding it on the installation CD, get a code 28. How can I download this driver on another computer connected to the internet and install the drivers on the problem computer thanks
    Scholar:
  • 85 Answers
You need the Intel Pro 100 driver for XP. Go to the following web link at Intel: http://www.intel.com/p/en_US/support/highlights/network/pro100ve and download the driver. Copy it to a flash drive. Put the flash drive into your PC that needs the LAN driver and double-click it to install it.
Posted on Oct 25, 2010
Testimonial: "worked as advertised, thanks for the advise. Iam not connected"
SOURCE:
I just install win7 on my computer then plug in the internet cable then i cant get no connection. i went to device manager it say driver needed call (ethernet controllor) agp8x motherboard driver ...
click start control panel admistrive tools computer management device manager scroll down network adapters + expand Ethernet driver right click you will have options to update driver disable uninstall or select properties general you will have the options to troubleshoot or to update driver rollback or uninstall
a yellow? ! question or exclamation mark or red x means you need to install/update driver right click to install driver
http://www.driverstt.com/downloadfile/50575/asus-p5p800-vm-realtek-rtl8100c-ethernet-driver-5-624-304-2005/
hope this helps
http://download.cnet.com/realtek-rtl8168-8111-pci/3000-2112_4-99235.html Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC: The Realtek RTL8168 Gigabit Ethernet controller combines a triple-speed IEEE 802.3 compliant Media Access Controller (MAC) with a triple-speed Ethernet transceiver, PCI Express bus controller, and embedded memory. With state-of-the-art DSP technology and mixed-mode signal technology, it offers high-speed transmission over CAT 5 UTP cable or CAT 3 UTP (10Mbps only) cable. Functions such as Crossover Detection & Auto-Correction, polarity correction, adaptive equalization, cross-talk cancellation, echo cancellation, timing recovery, and error correction are implemented to provide robust transmission and reception capability at high speeds.
Apr 24, 2011 | MSI 661FM-L, 601-6540G-010, Microstar P4...
Ethernet controller
Please right click on my computer icon and select properties.Then under the HARDWARE tab click on device manager and then go to network adapter.Double click on it under that you will see your ethernet card click on it and select Driver tab and install it.
Aug 06, 2008 | IBM NetVista PC Desktop
When i connect 500GB External USB hard disk on winXP machine .I get the display on my PC that new hardware found & asking for Drivers
Let the system to search for drivers automatically. Before proceeding that place any driver cd into the CD drive if came along with your ext. harddisk so that the drivers from CD will be automatically taken by the driver installer.
Thanks
Apr 12, 2010 | Seagate FreeAgent Pro 500GB External USB...
Found new hardware bubble pops up then mouse and keyboard freze
disconect all the things that is connected to the pc and do them one at a time
Mar 12, 2010 | Dell OptiPlex SX280 PC Desktop
I reinstalled XP Pro and I cannot connect to the intern et. It appears I am missing drivers for the Ethernet Controller. What is the simplest solution? Where can I get the driver?
when you update a driver, you also need a cd installer. If you lost the cd installer of the product, you really have to do the worst thing.: search and search for the drivers over the internet until you find it. Goodluck men..!
Dec 30, 2009 | Microsoft Windows XP Professional
Ethernet controller and USB are missing on XP
Yes, the device-drivers can be downloaded from the Internet, to one computer, and then burned onto a CD-writable, or written to a USB memory-stick, and then the files can be physically moved to the other computer.
But, "which" device-drivers is completely dependent on which computer that you have. Some motherboards have "integrated" network-adapters and "integrated" USB-ports.
Easiest solution is to take an add-in PCI network-adapter card, and install it, and connect the Ethernet cable to its socket.
Hopefully, Windows will recognize that card, and automatically load the correct device-drivers from the C: drive, i.e., without Internet access.
Or, if you buy an add-in card, it may come with a CD-ROM that contains the device-driver.
Once the device-drivers have been installed, you will have Internet connectivity. Access: http://WindowsUpdate.Microsoft.com
and click "Custom" scan, and then click "Optional Hardware".
Windows Update should find the device-drivers for your motherboard, and install them. Then, you can remove the add-in card, and connect the Ethernet cable to the "on-mother-board" network socket.
Dec 14, 2009 | Microsoft Windows XP Professional
Not recognized
A Network Drive, that which is connected via an Ethernet cable will not appear as new hardware. You should have connected it to the router on your network, then seen it as a network device.
Check My Network Places.
You will need to Map a drive to see it every time you boot.
Nov 29, 2009 | Western Digital 500GB My Book World...
Ethernet not working after format and xp reinstall
Right-click the My Computer icon and select Manage, then go to the Device Manager in the list on the left and find the Network Adapter from the list on the right, right-click Network Adapter and select Uninstall. When you reboot, XP should find the Adapter and reinstall it automatically. Another reboot may be required.
If it still will not connect, go to the NIC Manufacturer's website and download the driver to removable media. The Driver Update option can be accessed in the Device Manager, but this time select Properties when you right-click the Network Adapter, and go to the Driver tab.
Dec 22, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Ethernet Drivers (slow internet access)?
the fastest speed is the slowest path on the network.
right click on the my network place.
right click on the NIC local connection
click on configuration at the right of the connect using (NIC)
second tab, "advanced" check the speed & duplex- it should be auto, but you can change it. do not recommend it.
check resources- make sure it has no conflect with any other device.
if that doesn't help. uninstall the NIC driver and try to find a older driver. Sometime that works better, don't ask me, but it works.
Oct 30, 2008 | Gigabyte GA-M59SLI-S5 Motherboard
I had to reinstall windows xp. Now I cannot connect to the internet.
Make sure the driver of the Ethernet Card on your computer is installed. You check it under Device Manager
Right-click My Computer > Properties > Hardware Tab > Device Manager > Network Adapters (click the +). If you see Other Devices with yellow exclamations like Ethernet Controller, that's it. You need to run the Motherboard CD to automatically install the ethernet driver.
Jul 24, 2008 | Computers & Internet
Microsoft Windows XP Professional Logo
328 people viewed this question
Top Microsoft Computers & Internet Experts
Alun Cox
Peter Dragonetti
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
