Question about Vacuums
Steam vac hoover F7458900
Brushes don't rotate on steam cleaner, called warranty center, suggested the belt might have broken, can not ifnd replacement info or how to repace on owner's manual. if is possible there is not belt that drives the brush?
  • steam cleane Jun 08, 2008
    Thank you for your information. Will check it out. Called a warranty center for assistance, they keep saying to check the belt. We were unable to find any info on Hoover site re: belt for steam cleaner and how to replace it. Will try your suggestion.
  • wsherm Dec 09, 2008
    I have the same problem - the drive pin keeps breaking - and they want to charge me $30 for a complete brush assembly - Who can tell me where to buy just the brush prior to the drive pin being cut off? If you look at the brush assembly, all the brushes are made the same, with the drive pin, but they cut all but one off to fit it into the machine. I cannot continue to buy complete brush assembies. Thank You for any inoput
    President:
  • 1,673 Answers
There is no belt, the brush block is turned by a turbine. Check the brush block, make sure that the shaft that goes into the turbine isn't broke off, If ok, then replace the turbine, or take it apart and clean it out.
Posted on Jun 08, 2008
The spin brushes on my hoover steam And vac don't
Either the pin on the brushes that attaches to the motor shaft is broken, or the motor is dead. Did you check the switch on the front of the unit to make sure it wasn't turned off?
May 16, 2012 | Hoover Vacuums
Drive went out on my Hoover Steam Vac Shampooer and brushes won't turn plus there's a burning smell coming from it. Only used it 6 times - bought it in March - 2008.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=761326
Generic problem for all Vacuums
Posted by buster_lls on Jul 09, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sounds to me like you have multiple problems with your power drive; a burning smell and the brushes don’t turn, and the dop is on March, 2008 – the Hoover Steam Vac Shampooer has a one year factory warranty and it could be a broken part for the brushes won’t turn or a belt would cause the burning smell. If it is not the belt or broken part it probably is the motor of which you should take it to a authorized Hoover vacuum cleaner dealer in your area or to contact the Hoover factory cust serv listed below or the Hoover website for information. If it is the motor the factory authorized dealer will replace the part for the motor and the broken part for the brushes, if it is the belt that would be an out of pocket expense. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 09, 2008 | Vacuums
Brushes not spinning
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40473&thid=732696
Posted by mathis_23 on Jul 02, 2008
I cleaned filter and the brushes are still not rotating.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It probably is not the filter that will start the brushes turning again, it may be a few other things. There is a switch in the front that indicates brushes on and brushes off, and the switch could be broken, it could be that the brushes come in an assembly and the assm could be belt driven and you would have to replace the belt or the drive mechanism the turns the brushes is broken. These are just suggestions and you should check the schematic in your owner’s manual under trouble shooting. If you don’t have a owner’s manual, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
Jul 02, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover F7458900 steam vac brushes won't turn
No, there is a turbine that turns the brushes. You can take the top cover off to get to it, open it up and clean it out and then try it again. If that doesn't work, then replace it, or just replace it to begin with.
Jun 08, 2008 | Vacuums
Hoover steam vac, brushes won't rotate, have cleaned filter by brushes, removed brushes and they rotate okay when off steam vac, tried to ajust level for carpet cleaning and brushes still don't move
Check to see if the shaft on the brush block hasn't broken off. Otherwise it is the turbine that drives the brushes and is either clogged up inside or needs to be replaced.
Jun 07, 2008 | Vacuums
Spin brushes spin freely on steam vac when not attached to cleaner indicator screen not dirty speed selector is in high position brushes are clean spin brush indicator when brushes attached to machine...
If this is a Hoover Steam vac, the turbine which drives the brushes is bad. If not a Hoover, then what is it, they are different, need brand and model number.
May 14, 2008 | Vacuums
Brushes do not rotate on Hoover steam-vac upright
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=564960
posted by marshad on May 02, 2008
brushes do not rotate on Hoover steam-vac upright
This also happened to my own Hoover Steam Vac and there was a broken part that connected to the brush assm that I had to replace, it has been a while but once they replaced the part everything worked just fine and it was not that expensive and I am still using the vacuum still to date and it is working just fine. I believe it was something like the switch for the brushes on/off switch or the part was part of the handle assm. Check you owner’s manual for the exploded view on the vacuum or also check with your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
May 02, 2008 | Vacuums
Hoover steam vac dual model F7425900
If you are talking about the brush block, take it out and see if the shaft that goes up into the turbine is broken off, if not, then the turbine has gone bad and will have to be replaced. The turbine is what turns the brushes.
Jan 20, 2008 | Vacuums
Vacuums Logo
258 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
