Toys Logo
Posted on Oct 25, 2010
I have Lionel 682 s2 turbine. Front axle and both front wheels are stripped. Wheels spin on axle. Need (2) 682-11 front wheels with boss. Need swaged front axle 681-18. Need (2) 681-23 center wheels. Need (1) 671-182 smoke cam.Does anybody have these parts new? and if so how much. also any kind of repair sheet or manual showing exploded view of loco on how to reinstall these wheels and axles. Thank you,toptech
Traindoc
Level 1:
New Friend:
  • Contributor 38 Answers
  • Posted on Sep 03, 2017
Traindoc
Contributor
Level 1:
New Friend:
Answers
38
Questions
0
Helped
30940
Points
47
Your best bet is to take your locomotive to a Lionel Service Center. All these parts and diagrams are available but some special tools are required.
5 Related Answers
Anonymous
  • Posted on Feb 07, 2009
SOURCE: NEED NEW WHEELS
The place where we bought our MacLaren (Planet Kids, NYC) recommended Pledge furniture polish to cure squeaky wheels. They said WD-40 and similar products collect too much dust. Its worked great for us. We carry a can in the car so we can reapply when necessary.
Anonymous
  • 1689 Answers
  • Posted on May 04, 2009
SOURCE: replace front wheel bearings
hi emelinabarne
the link below is the parts catalogue for your bike. page 47 and 48 includes an EXPLODED view of the front wheel assembly. actually of all the parts.
http://www.yamaha-motor.com.mx/Manual_Partes/Catalogos/Deportivas%20(Crucero)/XVS1100%20V%20Star/5YS8_2005.PDF
hope this helps you out buddy.
regards,
voodoo
romney2012
  • 156 Answers
  • Posted on Jun 01, 2009
SOURCE: Where to find bushings for front wheels of little tike wagon?
You can try these push nuts from this site:
http://www.shopjandl.com/0801-0226.html
I don't know what size of axles you have on your toy, but these fit my little tikes hummer wheels.
Hope this helps
Anonymous
  • 246 Answers
  • Posted on Aug 03, 2009
SOURCE: Looking for Diagram of a Dana-44 Front Axle.
Try this: http://broncograveyard.com/images/addon/73dana44.jpg
Anonymous
  • 16 Answers
  • Posted on Dec 21, 2009
SOURCE: front axle does not engage when I shift into 4wd
It sounds like maybe your auto lockers in your front wheel hubs are not locking. You may be able to get them to lock if while in 4x4 you jab your brake pedal several times, sometimes this will work to get them to engage but even if this works I would advise that you either invest in a good set of manual locking hubs or replace the ones you have with new auto lockers. The auto locking 4x4 hubs are great when they work but when they don't they are not serviceable. The manual lockers are allot less likely to fail on you in the future.
The value of a train set 1953 Locomotive 1130
A Lionel 1130 is a "Scout" type locomotive....they are not particularly valuable even to collectors. They were a part of the low end starter sets Lionel made. Now if you had a similar vintage 736 Berkshire or a 681 or 682 Turbine they are worth considerably more.
1helpful
Rear wheels not engaging what can I do to troubleshoot the awd?
awd drive cars have a differential action between front and rear wheels and there should be a switch that allows you to lock up that action for adverse conditions
if the rear wheels are not working , it is because there is no drive action to the front wheels ( front wheels spinning or broken drive shaft to the front)
all wheel drive means that in normal driving when there is traction on all 4 wheels that the power is transmitted evenly to all 4 wheels
It is not 4 wheel drive where power is applied to both axles or in the event of one axle loosing traction the other axle still drives
Tractor case 585xl front diff not driving. Front shaft drives but not wheels.
I am thinking that you have a broken/ stripped drive spline on a front axle. If you have reduction gears in the hubs , it may be stripped teeth on a gear. If you jack up one front wheel and turn the drive shaft that wheel should turn. IF so repeat the procedure for the other wheel and if it doesn't turn like the other side then that is the side with the problem
3answers
4wheel drive wont engage
First, start checking the fuses an there is also an electrial activaced switch at the transmission or transfer case that may be bad.
95-96
Your control knob should say 2wd, 4auto, 4low.
First, we need to narrow it down to a transfer case issue, or a front axle issue.
Step 1) Jack up the front end and place it securely on jack stands.
Step 2) Verify that the front driveshaft turns by hand. When turning the front driveshaft by hand, the front wheels may or may not turn. Do not be alarmed if they don't turn. This is normal for your vehicle.
Step 3) Start the vehicle and let it idle. Place your foot firmly on the brakes, place the transmission in NEUTRAL, engage 4low, then place the vehicle back in park. DO NOT ENGAGE ANY GEAR!! The lurch as the transmission engages could cause the vehicle to lurch and potentially fall off the jack stands.**If you can turn the front driveshaft, the transfer case is not locking. This could be due to a mechanical issue with the transfer case itself, or an electrical gremlin with the control system. Start a new thread with the results of your checks, and we'll go from there.
**If the front driveshaft does not turn, the transfer case is locking properly and we need to continue searching.
Step 4) With the front wheels in the air, engine idling in PARK, spin one front wheel. The other wheel should spin the opposite direction. If both wheels spin in opposite directions, then the front axle *should* be properly engaged. Take it for a test drive (after safely lowering it to the ground, of course). If the front wheels do not spin in opposite directions, there is a problem with the front axle. This could be due to a mechanical problem with the diff, or a failure of the center axle disconnect to engage the passenger side axle shaft. Start a new thread with the results of your checks, and we'll go from there.
Troubleshooting the CAD on a 95-96 is a bit more involved than I want to get into here, and the problems can vary widely. This'll get you started.
97-01 4-door and 96-00 Sports
Your control knob should say 4auto, 4high, 4low.
Step 2) Verify that the front driveshaft turns by hand. When turning the front driveshaft by hand, the front wheels should turn. (If only one turns, don't be alarmed. One wheel sometimes has more resistance in the brakes, bearings, or CV joints. This is normal)
Step 3) Start the vehicle and let it idle in PARK. Engage 4high. DO NOT PUT THE VEHICLE IN GEAR!!! Crawl underneath and see if you can turn the front driveshaft.
Step 4) With the front wheels in the air, engine idling in PARK, spin one front wheel. The other wheel should spin the opposite direction. If both wheels spin in opposite directions, then the front axle *should* be properly engaged. Take it for a test drive (after safely lowering it to the ground, of course). If the front wheels do not spin in opposite directions, there is a problem with the front axle. Start a new thread with the results of your checks, and we'll go from there.
'01-'03 Sport and '01-'05 Sport Trac
Your control knob should say 2wd, 4high, 4low
The transfer case in these trucks functions essentially like the 1st-gens' 13-54 t-case. (i.e. it uses a lockup collar engaged by the transfer case shift motor) The troubleshooting procedure is very similar, but you don't need to worry about hubs or center-axle disconnects engaging.
**If you can turn the front driveshaft, the transfer case is not locking. The shift motor could be falsely reading an incorrect t-case position, or it could be a mechanical issue with the case itself. Start a new thread with the results of your checks, and we'll go from there.
Step 4) With the front wheels in the air, engine idling in PARK, spin one front wheel. The other wheel should spin the opposite direction. If it does, the system should be properly engaged. Safely lower the vehicle to the ground and take it for a test drive. If the wheels do NOT spin in opposite directions, there is a problem with the front differential or axle. Start a new thread with the results of your checks, and we'll go from there.
Keep us updated.
I have a Lionel 2055 post war train that I have not used in many years. I am setting it up around the Xmas tree. It ran well on the carpet when I tested it out but not around the tree on the hardwood...
Check to see if you picked up any fibers on the wheels or axles from your carpet running. Also check to be sure the pilot truck can swing freely from side to side and is not bent. There is also a light coil spring on the front truck pivot pin. Be sure that the spring is there and is not damaged. Another thing to check is the drawbar between the locomotive and tender. Your front wheels may be getting lifted off the track because the rear of the locomotive is getting pressed down. This a soft carpet may compensate for this but not a hard surface. Run your train at a speed where it derails and look closely at the locomotive to see if the rear is being pressed down.
May 23, 2017 • Lionel Toys
I have a 2000 z 71 all leds work replaced frt axel motor and wtched it work while out it goes in low range but still in 2 wheel drive like the frt end wont engage is there any thing eles i can look at ...
Check the transfer case. Put a jack under the rear axle and jack up the rear wheels. Have a helper put in 4 wheel and the trans in drive. Have him/her ease off the brake and see if the rear wheels spin. If they spin, 4x4 isn't working. If the truck tries to pull forward with the rear wheels up then it works. Now, if the rear wheels are spinning carefully look under the truck and see if the front driveshaft is spinning along with the rear driveshaft. If the front shaft is spinning then it is an axle problem. If the front shaft is not spinning then it is a transfer case problem. GM has a problem with the NP263 case.
5helpful
2answers
My wheels are not turning on my Polaris 280, what can I do?
When my polaris wheels stopped spinning it was the water jet which spins the turbine was clogged. The in-line filter had failed and some small debris had passed through to clog the jet. Easy fix to take off the top cover then take off the turbine cover and examine /clear the hose (clamped on by zip ties) and the plastic jet.
2answers
Transfer case locks into low gear but front wheels do not pull
You have to have your front hubs locked in for four-wheel drive to work
Upper wheel on a model 28-682 bandsaw. How do you adjust it.
With saw unpluged!!!!! open top wheel gaurd.Spin wheel by hand while moving the adjuster knob on back of the machine. As you turn both at the same time the blade will trac either the front or back of the wheel. Move the knob (while spinning the wheel) until the blade is tracking in the middle of the tire. (rubber strip around the wheel)
Jun 10, 2009 • Saws
Top Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Toy Expert? Answer questions, earn points and help others
