Question about Whirlpool Washing Machines
We just had a flood in our basement and our Whirlpool Duet Sport HE front load washer is displaying F28 which I know means something electrical. Is there any way I can disengage the electronics to get the door to unlock? I have clothes in the machine and stopped the cycle when the water started filling our basement. I want to get the clothes out before they get moldy.
  • 413 Answers
Unplug the machine. Remove the bottom access panel (three torx screws along the bottom). Reach up under the area where the door lock is and feel for a round door release mechanism. Pull down and the door will unlock
Posted on Jun 08, 2008
What does f23 error mean?
Display shows an error code - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...error-code...w...
Whirlpool Home AppliancesCheck the following answers for error-code related issues you can correct: ... Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33.
What does error code f23 flashing mean on a Whirlpool ...
Nov 30, 2015 | Washing Machines
I have an F28 error what is wrong
As far as I know F28 error code means - SERIAL COMMUNICATIONS ERROR/MOTOR CONTROL UNIT ERROR. Caused by either a communications problem between the Central Control Unit and Motor Control Unit, or Motor Control Unit internal failure.
Jan 12, 2015 | Whirlpool Duet GHW9150P Front Load Washer
F28 code on a whirlpool duet sport model # wfw8300sw03
There is also a safety switch on the bottom compartment, if the cover is off it will display F28.
Aug 11, 2012 | Kenmore HE2 Plus Front Load Washer
Kenmore H2 PLUS reads F--28 code what does this mean?
The error code F28 means one or both of these parts are bad.
Motor Control Unit (8540135)
Microcomputer Machine Control Unit (8540788)
It would be a good idea to order both, as both components have been problematic for error code F28
If you find either the MCU or the CCU(Microcomputer Machine Control Unit) fixed it.
Here's the online repair manual for your
Whirlpool Duet Sport, but its identical to your HE2.
Give it time to download.
On page# 4-20 it shows how to access your MCU.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/6545d78b3f479480852571650061b1ba/$FILE/8178558.pdf
Feb 13, 2011 | Kenmore HE2 Plus Front Load Washer
The door is locked and cant get clothes out or washer to run. says f28
you will have to call a tech f28 is a control board failure, or if you are lucky and you have the anti flood hose, to your machine..i would remove them and put standard hose on the unit
Dec 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F28 code washer stops working. Reset will only
Error code F28 indicates that one of the below part is bad
  • Motor Control Unit (8540135)
  • Microcomputer Machine Control Unit (8540788)
If you find either the MCU or the CCU(Microcomputer Machine Control Unit) you can fix it,
Here's the online repair manual for Whirlpool Duet Sport, but its identical to your HE2.
Refer page# 4-20 it describes how to get to MCU.
May 04, 2010 | Kenmore HE2 Plus Front Load Washer
Washer displaying a fault code.
check your manual. it will tell you what it means and what to do
Apr 01, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
What id a F28 code on a whirlpool duet washer
Can be the machine control or the motor control here is a link to the Repair manual....
Sep 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport ~ E28 Error Code
serial communication error between central control and motor control.
Check connections at ccu (top front right corner) and mcu (bottom by motor), check belt drive for wear.
Did motor run ? Any other codes in diagnostic? (any one modifier button 4 sec on 4 secs off 5 times.) F codes are failures and C codes are portions of test cycle(automaticly run)
Apr 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F28 error
F28 is a communication error which usually means there is a connection that has come loose. Removing the top and unpplugging and replugging the connectors in will fix 75% of these codes. If the bottom toe panel is not on it will also give you an F28.
Jul 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
207 people viewed this question
Dan Webster
Dan Webster
Sal De
