SOURCE: Washer Does Not Spin!
You either need a new pump or the pump is blocked, the washer will not spin whilst there is water in the drum.
SOURCE: Removal of front cabinet panel of washer section
Should be two screws on each side of the bottom of the front panel. Takes those out and push the panel up and out. (There are two "tabs?" in the middle of the front panel that lock into the side panels, so you have to push up and then pull out.)
SOURCE: removing front panel from kenmore elite HE-3 front load washer?
If you've removed the screws and the panel sticks, tapping on each side will knock it loose. The panel should drop down, then off. You can also try propping the two front feet of the washer up slightly for better access. A 2x4 works real well. This will allow more room for the panel to drop and gives better access to the screws. The washer is very heavy, so you may need some assistance to lift the front. Either lift from the bottom, or place your hands on the front facing of the cabinet to push the washer back. DO NOT push on the door or control panel.
If you still need assistance, please let me know. I hope this helps you.
SOURCE: Need to remove the front panel of front load washer
you will have to remove the rear panel in order to remove the front panel. The bolt and clamp are inside the front panel.
SOURCE: how to remove front kick panel on whirlpool duet washer
just pull out the bottom it will un hook,,
Hello friend, thank you for your post!
I understand that you would like to remove the front cover on your Frigidaire washer. Your question is labeled under model ATF7000E I was able to locate the parts manual for that appliance that shows a parts breakdown inside of your washer but no instruction guide to disassemble the front panel. I hope this information helps to some degree. -Matt
Frigidaire Manual Search Results
