Question about GE Heating & Cooling
Need gas for my ac unit - GE Heating & Cooling
  • 828 Answers
In most cases refrigerants Can only be purchased by a certified technician. If your unit needs (gas) it has a leak which must be found and repaired. Refrigerating systems are a sealed system and if they require recharging there is a leak in the sealed system.
Posted on Jun 08, 2008
Not cooling room and every 45 seconds it makes a hum noise
window unit ac !! not a fridge . the hum you hear is the ac compressor trying to come on , but due to loss of gas charge it shuts right off again , this will require a professional ac repairman to fix this , 1st he needs to find leak then repair leak then add back lost gas charge , watch cost of all these services vs cost of entire new unit , it could get expensive
Jun 24, 2015 | Refrigerators
My 2003 VW Convertble AC unit is not blowing air as cold as it used to. The AC unit is working
Most likely yes it does need to be re-charged with refrigerant gas as this gas can leak over a long period of time
Many garages can re-charge the system for you
May 01, 2014 | 2003 Volkswagen New Beetle Convertible
AC vents not working
Does this vehicle have one AC unit in the front or two units one in the back and one in the front ?,if two units then the gas content is low as a two unit vehicle should hold at least 1.5 kgs if this drops over time due to leaks then only the front unit will work
May 30, 2013 | 2005 Honda Odyssey
AC unit is not blowing cold air
It may not be air con gas but a failed AC compressor.
If the AC gas does need to be added this is NOT a DIY job. You will need to take the car to an auto AC specialist to have it carried out.
Dec 21, 2012 | 2000 Lincoln Town Car
I wanna knw dat after how many months should split ac gas be topup? I also wanna knw dat what is d cost of split ac gas?
If the unit was charged correctly in the beginning and you have no leaks in the system - the refrigerant will reman good for the entire life of the AC and it's component parts. In other words, without a leak, the refrigerant will not wear out - or ever need replacing - and you will never need to add any.
Right now the average 'wholesale' cost of AC refrigerant (for residential units) is about $6 per pound.
Retail cost will vary depending on the service company providing the refrigerant - but you can figure somewhere around $12 - $15 per pound. The retail cost includes the tech putting it in for you and making sure the AC unit is correctly charged and that the reason for the need to add refrigerant has been fixed, i.e. a leak that had to be repaired.
hope this helps.
Aug 05, 2011 | Panasonic CW-1006FU Air Conditioner
What gas should I add to the portable air conditioning unit ?
First of all, you don't add "gas" to any AC unit. You add "refrigerant" i.e. freon because AC units (as is ALL cooling) devices run a refrigerant cycle. If you have to ask this question, you shouldn't be adding refrigerant to the AC. Seriously, there are EPA regulations that make it illegal for anyone to knowingly release refrigerant into the atmosphere, and you might be a good candidate for doing so. The fine is something like $200,000 per day per incident. But if you are adamant on doing so, you'll need some expensive tools to evacuate the refrigerant that's currently in the unit and replace it with something like R-134a. The AC should have documentation (if not written on the unit) on what type of refrigerant is is currently using. If you have to "add" refrigerant to it, that may mean that it is leaking; if it's leaking, you'll need to find and fix the leak first, or you'll be violating EPA regulations.
Jul 21, 2011 | Heating & Cooling
I have purchased one Samsung Split 1.5 ton AC from Vijay Sales ? Baner Road branch on 19th Sept 2010 by paying cash payment. The same ac was delivered to me on 21st Sept 2010. The Samsung Authorised...
You have a LEAK from installation that must be found & repaired before any more GAS is added to the system.Then it will normaly need a little gas every 3 years.
Sep 29, 2010 | Samsung Heating & Cooling
FIX AC
contact the air conditation guy as the procudes of filling the gas can be only handled by an expert.
Hope this was helpful.
Jun 08, 2008 | LG LXA1230ACL Air Conditioner
Heating & Cooling Logo
91 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
