Question about Sony Cyber-Shot DSC-P200 Digital Camera
C:13:01 it tells me that their is a memory stick error. i have formatted it.checked if it works else where, which it does. reset it, still no joy. stuck in a new stick still no joy what can i do?
  • 33 Answers
Is the camera under warranty. If it is, we need to change it for you. The second thing to remember there is that if the camera needs to be opened, don't do it yourself. Take it to a professional.
Posted on Jun 08, 2008
I have format error on my cybershot camera. I need to access photoc on camera
The Camera may display the FORMAT Error if the inserted media is not formatted or if the media was formatted on a computer. This error may also display if the inserted media is not supported by the Camera. The maximum supported capacity and media used is Memory Stick Pro Duo with 1 or 2 GB.
If you've already captured the images in the Camera and the error message displays, then try to open different images captured in the Camera and check if the message appears for all the images.
If this happens with all the images, then remove and reinsert the MS (Memory Stick) in the Camera and check if it works. You may also try cleaning the MS terminals and also check if the Internal Memory of the Camera displays the error. If the issue persists, then insert the MS in the Computer slot and transfer all the images to the Computer. If the images appear normally in the Computer, then Format the media in the Camera. To Format the Memory Stick, select the Format option in the Memory Stick Tool Menu of the Camera. (Menu-->Setup-->Memory Stick Tool-->Format)
Formatting the MS will delete all the files saved.
Formatting the MS should resolve the issue.
Thanks for using FixYa.
Jan 18, 2011 | Sony Cyber-shot DSC-S700 Digital Camera
Sony DSC-P32 Memory Stick Error, "C:13:01"? When I went to review pics on memory card, camera would not scroll through and it would immediately shut off. Assuming it was the batteries, I...
The C:13:01 error code is the self diagnosis display of the camera to identify the cause of the issue with the Camera. This error code indicates the issue with the medium used in the Camera. You can try few steps to check if the issue can be resolved.
Try using different Memory Stick in the Camera.
Make sure that the Memory Stick used is compatible with the Camera. (The maximum capacity that can be used in the Camera is of 2GB Memory Stick PRO Duo.)
Format the Memory Stick in the Camera and check if it works. (Formatting the Memory Stick will delete all the files saved in it).
This may happen if the files in the Memory Stick is damaged or corrupted.
Try turning the camera power off and on.
Remove and re-insert the Memory Stick several times.
Insert another Memory Stick in the Camera to check if the issue is with the particular Memory Stick.
Try resetting the Camera and check if it helps. To reset the Camera, press the RESET button located inside the jack cover using a sharp pointed object.
If the issue happens with different Memory Sticks after performing all the steps, service may be required.
Dec 05, 2010 | Sony Cyber-Shot DSC-P32 Digital Camera
Hi I have a sony cyber shot camera when i tried to ON it The memory stick error appears saying " INSERT MEMERY STICK" inspite of memery stick is inserted also i get this error.And when i tried to format it...
The Reinsert Memory Stick error message appears when the inserted Memory Stick is corrupted or not in a correct Format. This issue can be resolved by trying the steps mentioned below:
  • Remove and re-insert the Memory Stick in the Camera.
  • Check if the inserted Memory Stick is compatible with the Camera.
  • Format the Memory Stick in the Camera. Do not Format the Memory Stick in the Computer, as this will damage the Memory Stick being used in the Camera. The Camera will not detect the Memory Stick again, if it is formatted in the Camera.
  • Clean the terminals of the Memory Stick by using a soft dry cloth.
  • Remove the Memory Stick from the Camera and check if the Internal Memory is working fine.
You may also try power resetting the Camera. Power resetting can be done by removing the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute.
If the issue persists, service may be required.
Thanks,
KenSolutions
FixYa
Oct 21, 2010 | Sony Cameras
13:01 error
The C:13:01 error code indicates the issue with the Media used in the Camera.
This may be due to the:
Format Error of the Internal Memory.
Un-formatted Memory Stick Duo.
Broken Memory Stick Duo.
Memory Stick Duo type error.
When the Camera cannot Read or Write the data in the Memory Stick Duo.
This can be resolved by Formatting the Internal Memory and Memory Stick Duo.
If not resolved, try inserting a new Memory Stick Duo which is supported.
Try power resetting, remove and reinsert the Memory Stick etc.
This will resolve the issue, if not the Camera may require service.
Aug 06, 2010 | Sony Cyber-Shot DSC-F717 Digital Camera
Problems with my Sony Cybershot W210
1) Make sure that you're not using more than 4 GB memory stick pro duo with the camera. Then try to remove the memory stick and capture 2 images in the internal memory and turn OFF and turn ON the Camera and check. If the error message comes, its the issue with the Camera itself and requires service after resetting. to reset the Camera, select Initialize under Main Settings 1 menu under Settings. if the issue persists, the camera may require service
If its working fine, transfer all the images to the Computer and format the memory stick. Formatting will delete all the contents. If the issue persists, memory stick should be replaced.
Sep 21, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Keeps telling me to reinsert my memory stick
I will forward a link to a page where you can get the information about this issue.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C166567
Also please check whether you're using a Compatible Memory Stick with the Camera.
It's not recommended to Format the Memory Stick in the Computer.
The Memory Stick should be Formatted in the Camera only, other wise such error messages can occur.
Please try using a different Memory Stick and check whether the issue persists with the other Memory Stick.
This is to check whether the issue is with the Memory Stick.
Apr 14, 2009 | Sony Cyber-shot DSC-W300 Digital Camera
I connect my dsc-s730 to my pc and i get a message saying 'you need to format the disk in drive f before you can use it' then when i press format it says 'windows cannot format etc'
Please take out memory stick from camera by opening battery compartment and put it back. Power up camera and press Menu and go to Format option and select Format and OK.
If still no joy after formatting memory stick then it looks defective, buy new memory stick.
Jan 28, 2009 | Sony Cyber-shot DSC-S730 Digital Camera
Format error
If Duo Pro got hardware problem, then it can not be fixed and you can't retieve data on it. Regarding new memory stick, camera will check it and let you know about format it or not.
Jul 31, 2008 | Cameras
Format error
i have orignal memory stick but i am also getting same error.. have forated stick on camera but no effect on error. so plz can u tell me how can i format my memory stick ... SONY GURU
Jun 07, 2008 | Sony Cyber-Shot DSC-S500 Digital Camera
Sony cyber shot DSC F717
Hi
Switch your camera to Setup on the control **** located on the top.
Take out the memory stick and press the reset button located inside the battery compartment.
Now switch on the camera and insert the memory stick.
If you do not get the error go to the little toolbox on the menu. Select the format option and proceed through the warning messages. Remeber you will loose all data on the memory stick.
Things should now work. If not some simple thing that sound bezare but has worked for me is pushing the memory stick in and out before the camera displays the error. Do this several times until the camera actually reads the stick and them format the stick first chance you get.
Good luck.
Oct 22, 2007 | Sony Cyber-Shot DSC-F717 Digital Camera
Sony Cyber-Shot DSC-P200 Digital Camera Logo
66 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
