Question about Microwave Ovens
Model MCD990ARB SS# 3513585800 . MICRO is in my 2006 camping unit and after cooking the micro will turn on by it's self and you can not turn it off but to flip breaker off. The micro gets bery hot when this happens and I'm worried about a fire.
  • goschofl Sep 30, 2008
    Microwave turns on by itself. Fire hazard!
SOURCE: micro stopped working
Try looking at the microswitches behind the door.
Posted on Apr 14, 2008
MicrowaveSvc
  • 9086 Answers
SOURCE: Micro Wave shuts down
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Posted on Nov 24, 2008
rickzilla
  • 706 Answers
SOURCE: micro turns on but doesnot heat also turn on by self
Hello bbmasonjim,
If your micro turns on ( meaning everything seems to be working from the control panel) and you aren't getting microwave energy to heat food..you may have any number of damaged or defective components : Magnetron Tube, Filament Power Supply or HV Capacitor.. None of which are something the untrained person should mess with. Even unplugged, there is High Voltage potential inside the electronics compartment. If it is less than a year old, it may still be under warranty.. otherwise.. the cost to repair would probably be higher than the cost to replace..
Regards,
Rick
Posted on Dec 13, 2008
kdrake84
  • 262 Answers
SOURCE: Blew an egg up in
Please post your complete model number so I may better assist you. I have posted a procedure on how to fine this information below.
But first just a warning on Microwaves....
THEY HOLD A POTENTIAL FATAL CHARGE EVEN WHEN THE POWER HAS BEEN DISCONNECTED!
MY ADVICE WOULD BE TO CALL A TECHNICIAN TO SERVICE THIS APPLIANCE.
Whenever any electrical device trips a breaker usually this is a indication of either a ground short...a wire that may have been burnt...or power being over the capacity of what the breaker is capable of handling. I.E. your breaker is allowing 10 amps of power to your outlet but the appliance is sending 11 amps....thus tripping the breaker. The breaker acts as a safety for your home against fire.
Your microwave has a transformer in it. It increases this power internally to generate enough power for the magnetron to distribute a very high voltage to produce heat to your microwave. My guess is something has shorted and or the magnetron or transformer has shorted internally. Really not worth repairing.
My two suggestions to you would be to call a service tech to repair or simply replace the unit. A tech will charge you a minimum of $125.00 plus parts a nice new unit can be purchased for under $200.00
If you would like to pursue this repair you will need to know how to use a volt meter and be able to read a wiring schematic.
Please post your decision...
Best regards...
Keith
Posted on Feb 26, 2011
  • 185 Answers
SOURCE: the micro goes on sounds like its cooking but does
more than likely a defective magnetron; less likely loose h.v. connections.
Posted on Aug 06, 2011
Jenn-air combo micro and oven
need to open the unit up and look for a fuse to be blown..
Jan 08, 2014 | Microwave Ovens
Microwave sometimes heats up food and sometimes it does not.
usually when you kill the power and then when you put power back on the machine works it's the computer board that's bad.all you're doing is resetting the board just like your house computer,if something happens to it you shut it down and reboot it,that's what you're doing with the micro wave just rebooting the board.here's the funny thing about micro waves sometimes the part you're gonna change is almost the same price as a new micro wave so i would first check how much the board is,i went on sears and they have the board for 115.00 repair clinic for 235 part number WPW10216347 they don't make this model anymore but you can get a stainless micro for around 290 to 300 dollars and if you buy the same brand all you should have to do is remove the bolts up above that hold it in place and remove the micro wave and the same brand should mount the same way so you won't have to drill new holes or replace the back metal panel.if i were you i would replace the unit instead of the board repair clinic shows most of the parts for this model out of stock so it might be a while before you can get any parts for this model but this is up to you.good luck with your micro wave.one more thing when you were in there did you see alot of grease,this is usually the cause of no heat,the grease from cooking on the stove top gets into the micro wave and on the mag tube and damages it,if there was grease in there i would just replace the unit
Dec 15, 2017 | Whirlpool WMH2175XVS Stainless Steel 1000...
I have a GE Profile Spacemaker model JVM1660SB005, maufactured in November 2000. I attempted to change a burned out bulb on the left side. I did not check the manual to see how to remove the bulb, nor...
I regularly see (and repair) this light and / or fan failure on model JVM1660SB005 and most any model of over the range microwave.
The problem is on the controller assembly, which I regularly repair very affordably.
At my Web site, you can get details, plus I have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
For more free DIY and other help & advice, feel free to contact me via my site.
Please include FULL model number*, FCC ID number*, + detailed symptom information. ( * on the tag in cooking cavity or around door frame or control frame or on back)
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 05, 2017 | GE Microwave Ovens
Mar 05, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
Ours magic chef 900W MCD990ARB completely stopped. We have it in our camper and everything on that end is fine. Checked the micro in a different outlet, still no go. Any suggestions?
Well if you are lucky it is an internal fuse. Open it up and look somewhere near where the cord comes into the unit. If it is not the fuse then I suggest you replace the whole thing.
I recently was attempting to repair one. The part cost $93, a new microwave costs that or less.
May 11, 2010 | Magic Chef MCD990W Microwave Oven
Why would my microwave no longer heat or cook?
micro waves use a tube inside that generates micro waves and like a light bulb they eventually blow out. the tube is not considered replaceable and cheaper to just get new unit.
Apr 23, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a Sharp micro wave model R-1492. It turns on, but nothing cooks. Do you think I may need to replace the magnatron
first before you replace the most expensive part of the unit,check the h.v. diode and h.v. capacitor, the thermistor on the magnetron tubes outer case side, you will need to remove the top cover to accomplish these things
Nov 14, 2009 | Sharp R-1492 Microwave Oven
Microwave made a loud pop,won't heat,sounds like it's only on half power, makes a low intermittent hum
This is almost certainly a blown high voltage diode.
Please reply back with your brand and model number so we can help you.
May 31, 2008 | Microwave Ovens
Sunbeam SMW5500 micro/convection oven shorted out when opening door
You are decribing a typical Door Safety Switch problem. The Door Safety Switches has Failed.The Door Safety Switch is designed to shut down the Micro in the event the Micro is still cooking when the door is being opened. The first "Click" of the switch cuts off the "Cook". If it does not cut off the "Cook", the second "Click" blows the power. Otherwise it would "Cook" with the door open, and I need not to tell you how DANGEROUS that could be. It first Tripped the Circuit Breaker which supplies power to the Microwave. After Re-Setting the Breaker the same thing happened except this time the Micro is DEAD- not even a light working. Yes, there is a line FUSE inside the Micro. You however need to address the Door Switch SHORT before replacing the fuse. If not, it will just Blow The Fuse Again, and Again, until the Short is corrected.
Call around, ask How much to replace a Door Safety Switch.
Good Luck!
Feb 15, 2008 | Microwave Ovens
Microwave Ovens Logo
589 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
