I have bought a Toshiba Satellite M200 laptop 2 weeks ago.While using Yahoo messenger,for the first time the camera works fine.If it hangs for some reason,if I close the camera and try to restart,it says "locked by other application".I tried to disable the "Chicon traybar exe" in msconfig-->startup so that the camera assistant software does not start up automatically and restarted my laptop.Now if the camera hangs while chatting,it says "webcam cannot be connected."My OS is Vista home premium.Tried to uninstall drivers by clicking on camera assistant software but on restart,vista automatically did not download latest drivers,though connected to internet.I have again downloaded the latest Chicony webcam driver for vista from Toshiba website and same problem.
Toshiba support centre will not help even if it is within warranty as it is not a hardware issue.
Please help.
same webcam problem. in some cases it locked by another apliction,in another case says that the web cam driver has failed.
ya vista have some problems go to your internet option and download manually the latest update of your webcam .this may be a problem because u are using latest version of yahoo but your web cam do not support it or either add xp also in ur laptop.
 Sunday, April 13, 2009 To whom it may of concern, Herewith I have to bring forward my...
(More)
Sunday, April 13, 2009 To whom it may of concern, Herewith I have to bring forward my disappointment that after a day of work, I could not close my notebook Toshiba Satellite P20 (Serial number: 74353716K; Part number: PSP26L-0PPJ9; Made in China; with Windows XP Home Edition), because of an enormous cracking noise. Screws and other little parts were jumping around. The hinges at the backside of the casing were totally deformed; this may be caused by the outgoing flow of the generated heat. I therefore was obliged to left my notebook open and had to bring it to the shop were I have bought it. They brought it to a center of repair in Jakarta, the costs of repair were quite high, i.e., IDR 4.75 million and it took more than two months to have the job done and with no warranty! The main issue is that there is something seriously wrong with the management of the generated heat. Here is a feature where one has obviously to deal with a wrong design of this P20 model. This is very sad, since this P20 is my workhorse and I am very happy with its specifications. With this letter I hope to contribute to an improved design of the notebook Toshiba Satellite P20. Sincerely yours, Adrian Venema Jl. Cisatu I, no.1 (Ciumbuleuit) 40142 Bandung Indonesia e-mail: adrinnuha@bdg.centrin.net.id
Win Vista Home Premium. OK, I power on the and everything starts out fine. I see the Toshiba splash...
(More)
Win Vista Home Premium. OK, I power on the and everything starts out fine. I see the Toshiba splash screen, the green Windows scrolling bar. OS loads can see desktop then I have 10 sec. till the screen goes black. The power light is still on but no HD activity light at all. I can boot into Safe Mode and works fine, can stay on for hours if I like. But will not find my network, direct wired or wireless, keeps assigning 169.xxx.x.xxx address. Thought it to be spyware or virus related, but could not get online in safe mode or even onto my local network. Ran the Toshiba restore disks. Now as Windows starts for first time it goes to a Toshiba splash screen to finish setup saying it will reboot after it finishes. This happens about 10 sec. after Windows starts at which time the screen again goes black. Still have the power light lit, but no HD activity light. I let it sit like this for hours and no change. Now if I boot into safe mode it says Windows installation is not complete to click OK to restart in Normal Mode to finish installation. No matter if I cancel the final installation step in Normal mode or not, 10 sec. after Windows loads the screen goes black.... PLEASE HELP!!!
I purchased a Satellite M300 notebook. It has a black glossy keyboard which I hated after 1 day of...
(More)
I purchased a Satellite M300 notebook. It has a black glossy keyboard which I hated after 1 day of use. Now there is a broken key cap, and I will have to get the unit serviced. Is there a replacement keyboard that I can get for this notebook that does not have a glossy finish.
comier957, Thank you for your attempt to help me with my problem. You offered a solution and asked...
(More)
comier957, Thank you for your attempt to help me with my problem. You offered a solution and asked me to let you know. I attempted to let you know what I had done but do not know if you received my reply. Thought I knew how to send it but it did not post under my original question. . Anyway, I had one SATA burner in port 1 and one SATA burner in port 3. Since I posted the question I traded one SATA burner for a Samsung IDE burner giving me 1 SATA Burner and 2 IDE Burners. Each of them seems to work as it should. Sorry I "jumped the gun" and made the trade. You most likely could have solved my issue. Thanks
