Question about Hunter 27185 Remote Control
Ceiling fan, remote control
I have 3 leads coming down red a black thats appears to hot all the time, I have remote control 27157 how do I wire to these 3 leads.
  • johnb069 Jun 29, 2008
    I have a 27157 remote control that has a red lead from the receiver marked "fan". I do not have a red lead from the fan to connect to. I have a black, white and black/white from the fan, no red. The light works fine. Where should I wire the red lead?
    Thank you!
I call some one here is the USA a he walked my thru it, Its is a big different when you deal with some that speek your language
Posted on Jun 09, 2008
Light only turns on with the remote. How do I set it to turn on with the wall switch?
There are some fan models (particularly with a remote control) that use multiple cycles of a single power switch to select the operating mode. For example, if you simply flip the switch on, you get the fan. If you flip it on, then off, then on again within one second, you get the light. If you flip the switch on - off - on - off - on, you get both. The trick is to do it fast enough so the internal power circuit doesn't run out of capacitor charge and forget what you're trying to get it to do.
Sep 28, 2011 | Hunter 52" Ceiling Fan With Light And...
I purchased a hunter universal remote and have a hunter fan with canopy I am trying to get it hooked up to. I have all wiring configured the way it shows on diagram and still nothing. From the box in...
If everything is wired correctly, disconnect power at the source, then reconnect power and experiment with every possible combination of wall switches and the remote until the fan works correctly. At that point, do not use the wall switches again, ever.
Apr 17, 2017 | Hunter 27187 Remote Control
Need to know how to wire this fan. Not using a remote or wall switch
Hello! W/D here.
In your ceiling box, you'll find 3 wires; black, white and bare copper.
In your fan, you'll see 4 wires; black (or red), white blue, and green.
With your breaker tripped, connect the green wire on the fan to the bare wire in the ceiling (this is your ground).
Connect the white fan wire to the white ceiling wire (this is your common).
Connect the blue and black (or red) together, and connect these to the black wire in the ceiling (this is the hot lead, and will supply power to the fan and the light).
Best regards, --W/D--
Feb 13, 2011 | Westinghouse 78500 Casanova White Ceiling...
Wiring instructions are terrible. Ceiling wires = Red, Black, White, Copper. Fan wires = Black, White, Copper. Remote wires = Neutral in(Black), Live In(Black), Light out(White), Fan out(White),...
That is dificult to follow .. here is the usual wiring plan for ceiling fans .. green to green or bare and mounting bracket ... ceiling black and red are live from the switches, fan and light.with a remote you really only need one of these , so cap off the red and use the black as your input to the remote .. the neutral to the remote should be the white .. there are only 3 wires from the fan so I am assuming that there is no light , or the light will be activated from the remote .. the black for the fan and the black for the lights connect to marked wires on the remote. .. lights out, fan out
or looking at your description .. ((Remote wires = Neutral in(Black) white ceiling wire, Live In(Black) blaxck ceiling wire, Light out(White) blue Fan/Light wire, Fan out(White) black fan/light wire, Common(White) white ceiling and white fan/light wires.
May 21, 2010 | Hunter 27148 Remote Control
I am installing a ceiling fan/light with a remote control and the wiring in the ceiling has a red wire and two white wires which are connected. I am used to seeing only a black and a white wire. in order...
the two white wires are the neutrals, just add the fan's white wire to the other whites. The red wire is the hot wire, same as a black, so connect it to the black.
Oct 11, 2009 | Home Decorators Collection Star-tech Fan...
Nee to know how to wire a ceiling fan remote to the ceiling box please. Wires coming from box are: black-hot, bare-ground, and white-?. Wires coming from fan remote unit are: black labeled wire to black in...
Try this, connect green wire to bare wire. Connect both black (power) wires to black wire in the box. Connect the blue wire to the button for the lights, and the red wire with the strip to the button for the fan, and the common for the buttons to the white wire.
Oct 03, 2009 | Hunter 52" Ceiling Fan With Light And...
My ceiling fan has no reverse switch, how do i change the direction
My fan does not have a reverse switch for sure so I scoured the net and got no real answer. I did come accross a comment that said that it worked internally at the remote box in ceiling. Here is how I finally figured it out after about 6 months of searching. Put the fan on high, Turn wall switch OFF, Hold the HI button on remote, Turn switch back on. IT WORKS!!!!!!!!!!!!! Sparq
Jul 18, 2009 | Hampton Bay 24002 Ceiling Fan
How to wire a remote control ceiling fan, without using remote.
If you don't want the to use the remote you don't have to, but you don't have enough wires to switch the upper light, the lower light, and the fan. You can, however, switch the upper and lower lights together if that's okay. In order to do that you'd connect the white from the ceiling box to the white (neutral) on the fan, then the green from the ceiling box to any green(ground) wires on the fan, then the black from the ceiling box to the black(motor) from the fan, then the red from the ceiling box to the blue and orange (lights) from the fan. I'm assuming that the black and red in the ceiling box are also in the switch box where the fan/light control switch is going. Those are the ones you'll connect to the controller.
Jul 05, 2008 | Hampton Bay 04383 Calibre Ceiling Fan
Installing ceiling fan with two switches AND a remote
in your ceiling box should be three wires. a red goes to the three way switches, a black goes to the hot and the white is the neutral. the fan wires are black, blue and white. since you have a remote, connect the [fan] blue & black together with the [line] black. connect all white wires together. the remote will now ramp up your lights from off to full on and the fan remote will let you choose lo med high and off. just tape up the red wire in the box.
Aug 17, 2007 | Hampton Bay 04383 Calibre Ceiling Fan
Televison & Video Logo
746 people viewed this question
Top Hunter Televison & Video Experts
pblo
Level 1 Expert
Henry  Thomas
Henry Thomas
Paul Bade
Are you a Hunter Televison and Video Expert? Answer questions, earn points and help others
