SOURCE: digital camera problem
The suggestion that it would cost a thousand dollars to fix this problem is totally off the mark. Your camera's shutter has stuck open. Normally when you take a picture the shutter closes blocking out the light and allowing the image sensor to record what it saw at the moment the shutter closed. When the shutter sticks open the images come out over-exposed and have lines across them because the image sensor is unable to properly record the image. This problem can be fixed with complete disassembly of the camera and lens assembly. The labor costs in the range of $89 to $145 and parts are not usually required. Check with your manufacturer for recalls and/or warranty support. If they cannot help you for free, there are repair providers which you can find online who will work on your camera for reasonable rates. David Millier Advance Camera Repair
SOURCE: flickering lines and the color is off
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=813&modelid=8777&keycode=2112&id=29819
It has been confirmed that the connecting
parts of the internal wiring of the CCD used in affected products may
become disconnected, especially if the affected products are stored or
used in high-temperature and high-humidity environments. If this
occurs, the signal is not output from the CCD normally in Shooting
Mode, which may cause a distorted image or the absence of an image.
This malfunction can be confirmed on the LCD monitor screen during
shooting. The same malfunction also appears on the recorded image.
Canon's Response:
Effective immediately, and regardless of warranty status, Canon will
repair, free of charge, the products listed above exhibiting the
above-mentioned malfunction if Canon determines that the malfunction is
caused by the CCD image sensor. Canon will also cover the cost of
shipping and handling in connection with this repair.
U.S. residents are kindly directed to contact the Canon Customer
Support Center for further assistance at 1-800-828-4040. Support hours
are Monday thru Friday - 8:00 AM to 12:00 midnight; and Saturday 10:00
AM to 8:00 PM (all times EST). Alternatively, if electronic support is
preferred, please send your email to [email protected]
This information is for residents of the United States of America
and Puerto Rico only. If you do not reside in the USA or Puerto Rico,
please contact the Canon Customer Support Center in your region.
SOURCE: view screen has purple lines across whole screen cant take a pic.
It is bad ccd issue in Canon A95 camera and ccd imager needs to be replaced.
Canon will repair A95 free of cost as per announced scheme.
Click Canon CCD Advisory for details.
Good luck.
SOURCE: There is no picture review, has purple lines
CCD damaged. Replace the CCD & use the camera like before.
SOURCE: I have my canon a470 digital camera, recently i
This sounds like a stuck shutter, with the shutter stuck open. See this link, trying Fix #5A. If Fix 5A does not work, your camera is then likely experiencing a broken ribbon cable to the shutter control. Unfortunately, repairing that cable would be more costly than the value of the camera. Also, repairing the cable yourself is not recommended as finding a replacement cable would be just as costly, and the actual repair is very difficult.
