Question about DeLonghi Pinguino PAC-02 Air Conditioner
Delonghi piguino k900
I bought a second hand pinguino k900 and it didnt come with a manual. it seems to be working but not as cold. this might sound stupid . it seems like if i push the temperature towards 25 not 16 it gets cooler but that much. is there a site where i can get a manual of how work the a/c or can someone guide me thanks
nafa
  • dgallant Jun 12, 2008
    I also have the same model and looking for a manual on how to control the AC. Is the higher number colder or the lower number colder?
    Thanks.
  • Anonymous Jun 16, 2008
    I also require a manual.
Does anyone no where to find a user manual for this air conditioner?
Posted on Jun 15, 2008
I hear ya, mine doesn't function properly either. Can't cool my living room. Seems to kick out more heat than cold air. I don't have the manual either and could use it. I've been searching the net and can't find it.
Posted on Aug 12, 2009
Dude I am in the same boat. I wish there was a way so the temp. would go below 61.
Posted on Jun 09, 2008
Delonghi pinguino k900 air conditioner not working. The ac is not responsive to the buttons. Please help
Hello, these units are not as user serviceable as the old electromechanical types, unless you are fairly familiar with power I cant suggest you engage in actions that could seriously injure,even kill you if you make 1 error. I am sorry but many technicians today are not even familiar enough with these to attempt servicing them, with the cost of service these tend to be replaced more than repaired out of warranty.
Jun 29, 2013 | Heating & Cooling
I have a delonghi pinguino k900 which I purchased in 2003. for the past 2 years it only acts as a fan. what do I need to do?
Check last pages of your user manual there is the number to call repair service, the heater element must be replaced
Jul 25, 2008 | DeLonghi Heating & Cooling
I just bought a used DeLonghi Pinguino PAC 02. It seems to cool ok but the exhaust hose gets very warm. Is that normal?
Yes, that is normal. It's exhausting the heat from the compressor out the window.
Thanks for choosing FixYa.
Sep 09, 2011 | DeLonghi Pinguino PAC-02 Air Conditioner
Delonghi Pinguino K900, continued to blow hot air, what should be the solution. I want to enjoy the airconditioner aspect of the unit.
There a several things that can cause the problem you have described.
1. The Dehumidifier Mode is operating at the same time as the AC or is operation on it's on.
In dehumidifier Mode heat is produced.
2. Air filter needs to be removed and cleaned.
3. A blockage or crimp in the exhaust hose.
4. The exhaust has a leak or has come loose from the unit.
5. The unit is sitting in direct sunlight or is adjacent to a heat producing appliance.
6. Compressor needs to be recharged with R134a refrigerant gas.
The 6 things listed above are where you need to start troubleshooting. 5 of which are easy to check and correct.
Hope this helps you and thanks for choosing FixYa.
Jul 21, 2011 | DeLonghi Pinguino PACL90 Portable Air...
Pinguino ct 90 trips the circuit breaker and soaks the carpet....
My Delonghi Penguino ct90 no longer blows cold air out for longer than a couple of minuets need a fix for this and it is no longer under waranty. Please help.
Jul 05, 2009 | DeLonghi Pinguino PAC-700T Air Conditioner
I have lost my manual
http://safemanuals.com/user-guide-instructions-owner-manual/DELONGHI/PINGUINO%20PAC02-_E
Please don't forget to give me a Fixya rating
Feb 23, 2009 | DeLonghi Pinguino PAC-02 Air Conditioner
Delonghi pac-02 a/c
I had similar problem .... on very humid days unit leaks ..... temp solution for me was to drain the unit .... inserted wire coat hanger into tube .... lots of watery gook came out.. - even tilted/tipped the unit inorder to get as much water out of it.......afterwards unit worked fine.
We are VERY SASTIFIED with the Delonghi Pinguino - bought it years ago when it first came out and it has provided years of troublefree service .... the water build up / leaking was only recently - in fact we never drained the thing until this year.
Aug 23, 2008 | DeLonghi Pinguino PAC-02 Air Conditioner
K 900, pinguino
I had the same problem with my Delonghi K900.  I have an extended warrantee for both my Delonghi air conditioners.  It was taken into the shop and discovered that the hose that allows the water to drip into the collecting tank was clogged with dirt and dust. I find it is a good idea to have them cleaned and checked once a year, especially if used often. For under a hundred dollars, I have a warrantee that will last until the year 2010.  Sears offers warrantees for any home appliance, even if it wasn't purchased there. Taking the air conditioner apart yourself can cancel any warrantee on them machine. Hope this helps. Trisha
Jul 27, 2008 | DeLonghi Pinguino PAC-77E Air Conditioner
Try this link. I do not see a "K900" but maybe it is a start.
http://www.delonghi.com/Int/USA/customer.html
Jun 15, 2008 | DeLonghi Pinguino PAC-02 Air Conditioner
DeLonghi Pinguino PAC-02 Air Conditioner Logo
726 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
