Back to:
Scanners
Generic problem for all Identix Scanners
Identix Touchprint Enhance Definition 3800 Livescan
posted by Salemsd on Jun 08, 2008
Dear Sir;
We are having a livescan application connected to Identix Touchprint Enhance Definition 3800 Livescan device, in some station there is a problem of send and Don't Send that usually appear when using some windows application, We are afraid that this problem is being caused by the Identix Scanner due to heat or some on none problem, since this problme in not frequent we are unable to track.
Your assistance is needed in this matter.
Regards
Salem
salem@zaf.com
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Can you Help with these Scanners problems?
Microtek ScanMaker 4900 Flatbed Scanner
when scanning it just shows either a solid color or lines...
Scanners
tengo un scanner alaska 5000u y baje los drivers para el...
Genius ColorPage Vivid Pro II Film Flatbed...
Compatibility issue between ColorPage-Vivid 1200XE and...
Scanners
how do i scan documents using my hpfax1250 and send them...
Canon CanoScan D1230U Flatbed Scanner
I have a canon scanner, but I have lost my scanner's...
Loading problems.
Repair Service
Find Scanner Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
