Question about LG LXA1230ACL Air Conditioner
  • 1,847 Answers
Contact the air conditation guy as the procudes of filling the gas can be only handled by an expert.
Hope this was helpful.
Posted on Jun 08, 2008
Fix a fridge leaking gas
Of course you have to re gas the unit. Will not work otherwise.
You remove all traces of refrigerant, roughen the hole area, and apply solder to seal. Then use a vacuum pump to evacuate the system and if it it holding vacuum after 30 minutes then you fill with the correct amount of refrigerant after installing a schraeder valve.. Has to be spot on since refrigerators are, unlike AC units, very critical regarding the amount of charge.
U have learned an expensive lesson!
Mar 06, 2016 | Refrigerators
AC is not throwing cold air anymore?
the unit must've run out of gas.You need to get a proffessional to get it re-gased.And ask him to locate any gas leak along the copper pipes and connections.
Dec 27, 2013 | Heating & Cooling
Transmission fluid started leaking after I replaced the radiator
Check the hoses and fittings going to cooler. Hopefully you did not damage unit during install of radiator.
Jul 26, 2017 | 2004 Dodge Caravan
How do i get the carborator off a 2010 polaris scrammbler 500 h.o.?
esasiest way is to take front plastic off then taking off your fuel tank.doesnt take long.
Jun 09, 2012 | Garden
What gas should I add to the portable air conditioning unit ?
First of all, you don't add "gas" to any AC unit. You add "refrigerant" i.e. freon because AC units (as is ALL cooling) devices run a refrigerant cycle. If you have to ask this question, you shouldn't be adding refrigerant to the AC. Seriously, there are EPA regulations that make it illegal for anyone to knowingly release refrigerant into the atmosphere, and you might be a good candidate for doing so. The fine is something like $200,000 per day per incident. But if you are adamant on doing so, you'll need some expensive tools to evacuate the refrigerant that's currently in the unit and replace it with something like R-134a. The AC should have documentation (if not written on the unit) on what type of refrigerant is is currently using. If you have to "add" refrigerant to it, that may mean that it is leaking; if it's leaking, you'll need to find and fix the leak first, or you'll be violating EPA regulations.
Jul 21, 2011 | Heating & Cooling
Rear AC blows but front doesn't blow at all. It just all of a sudden quit working today. Also when the AC was working up front the car would act like it was going to stall out and has actually died on...
Sorry no quick fix here as this gas is highly toxic and poloutes the ozone layer so take vehicle to a specialist AC garage who can then vacate the system and then check the front ac unit expansion valve or the restrictor valve if you call it that
Jun 18, 2011 | 2004 Chevrolet TrailBlazer
1997 Buick LeSabre speedometer, eratic operation reads faster than speed actually going, analog electronic unit. How do I repair and access it.
A reliable fix would be to send the cluster out for repair, if in fact the problem lies in the speedo head. There is a bulletin for this car that states that at 20mph the speedo can be + or - 4 mph inaccurate, and its normal operation.
I suggest first having the alternator tested. The VSS on this car produces an AC voltage signal. The alternator also produces AC voltage, which is converted to DC before it is output to the cars electrical system. If any AC voltage is leaking from the alternator, it can interfere with the VSS signal, and cause the speedo to read higher, or even show that the car is moving when sitting still.
Aug 13, 2010 | Buick LeSabre Cars & Trucks
How do I correctly order a new fan control board for my HVAC
You have two wires going outside they should be hooked to Y and C on the control board. If you have a meter check betweenY and C. If you have 24 volts your problem is outside. If your unit has a low pressure control it may be low on gas meaning a leak. Rusty
Jun 03, 2009 | Heating & Cooling
AC fan working intermittently
Check the fan blower resistor mounted in the under dash blower case. Mazda had pretty well designed systems and are user friendly. The resistors are a fairly common issue. Make sure also that the drain on your ac unit is draining out when the ac is on. They can fill up and cause some weird probs. check also that the carpet under the pass side dash is not wet. If so, you have a drain that is clogged or is leaking back int the dash floor. There is a repair for that also.
May 20, 2009 | 1999 Mazda Protege
Ac woes
When you open car in morning is there a strange smell in it? You can check ac pressure with a tyre gauge should have a filler looks like a tyre valve near ac unit under bonnet check if it has pressure if not you have a leak and need to find and fix that befor regas. If leak suspected (you got not preasure in unit) get ac regasser out and tell him/her you think it maybe leaking and if passenger floor wet and your system still uses freon good chance you have a leak, they should dye the gas and the leak will become very obvious very fast once car started and ac turned on. But if you use freon you may not be able to regas depending on the laws in your neck of the woods. Here in australia if your useing freon and you need to regas you have to change a fair bit to use a legal gas which depends on type of refrigerant unit installed.
Jul 26, 2008 | 1997 Dodge Ram 1500 Club Cab
LG LXA1230ACL Air Conditioner Logo
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
