Question about EliteGroup P4VMM2 Motherboard
How do I know if my motherboard is compatible with my processors voltage? where do i see the voltage indication of the motherboard?
I want to assemble a computer using a P4VMM2 motherboard but I am not sure with the compatibility of my motherboard and processor. How do I know if they 're compatible? What should I consider in buying the processor that would match my motherboard?
  • 55 Answers
Your board supports P4 CPU with 400Mhz bus speed. You can use any P4 CPU with 400MHz such as 2.4GHz/512/400. I think you can go as high as 2.8GHz.
Good Luck!
Posted on Jun 08, 2008
Cpu didnot run ,i cant find any signel on my cpu every thing is ok but there is a problems in motherboard what should i do ?
A) With great tact and diplomacy;
Do not refer to a Personal Computer as a CPU.
CPU = Central Processing Unit.
Another term is Microprocessor, or simply Processor for short.
CPU = Processor
B) Because of the method you used to refer to the Computer, I do not know if you're talking about; the PROCESSOR did not start, or the Computer.
C) If I we are to believe this is a reference to the Computer;
1) Check the Power Supply voltages,
OR
2) Substitute the Power Supply; with a KNOWN to be working, Compatible power supply, for a temporary test unit.
Why?
A) If ALL the LED lights were on at once, they would use less than 1 Watt of power.
B) EACH fan uses 2 to 3 Watts of power.
C) A typical Processor can use 51 to 125 Watts of power.
Just depends on what Processor it is.
A Power Supply with a weak voltage power rail, will not have enough power to turn the Processor on.
However I am still confused by the statements;
1) "CPU did not run"
Does this mean the COMPUTER did NOT turn on, which implies the Power Supply did not turn on;
OR,
Does this mean LED lights came on, fans may be spinning, but Windows does not load?
2) "I can't find any signal on my Computer........"
Signal = Voltage.
To see if there were voltages going through the motherboard, you wouldn't be posting on here. You would know how to take a multimeter, and test them.
Means to me you see No Signal on the monitor.
D) Are you FOLLOWING Anti-Static Procedures?
E) Power Supply voltages prove to be good, or you are using a KNOWN to be good, Compatible power supply?
Disconnect EVERYTHING from the motherboard.
NO cables to the motherboard, EXCEPT the 24-pin ATX main power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
[NOTE* Color of connector does NOT matter ]
,and the 4-pin ATX +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
Disconnect the data cable AT THE motherboard, for the Harddrive, and optical drive/s. (CD/DVD drive)
Disconnect the power cables to them also.
Disconnect ANY USB front panel cables.
LEAVE processor fan wire connected to motherboard.
You want the Processor, finned Heatsink sitting on it, and the Processor fan.
ONE stick of Ram Memory in Slot 1. (DIMM 1)
Leave graphics card in, IF used; or monitor is connected to the VGA port on the motherboard. (D-Sub connector)
Turn the Power Supply on.
You should be able to bring the BIOS Setup screen up.
If no, consider the motherboard to be bad.
http://www.msi.com/product/mb/G31M3-L-V2---G31M3-LS-V2.html
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130217
Post back in a Comment, as to the information I need.
CPU = Processor
PC = Computer, or just use Computer.
Regards,
joecoolvette
Mar 13, 2013 | MSI G31M3-L V2 Motherboard
Dont show video but it turn on perfectly
Usually indicates a bad Power Supply.
LED lights light, fans spin, but NO Signal on monitor.
No Video Signal, because the computer isn't sending one out.
Because the computer isn't working.
Know this;
1) If ALL the LED's were on at once, they would use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical processor can use from 51 to 125 Watts of power.
However not to jump the diagnostic flow chart; check the monitor cable FIRST.
Use on another known to be working computer. If it checks out OK, the problem is the computer, and I think -> Power Supply.
Test the 3 main voltages on the Power Supply, with a multimeter set to DC Voltage; OR use a KNOWN to be good, Compatible power supply, for a test unit.
For additional questions please post in a Comment.
Regards,
joecoolvette
Dec 29, 2012 | Computers & Internet
Is intel pentium 4 3.40 processor compatible with this motherboard?
Your post did not indicate what motherboard you actually have. The best way to know would be to go the the motherboard manufacturer website and check the specifications for your particular model.
Nov 15, 2010 | Computers & Internet
My computer is continuous reboot every 10 second. what can i do?
sachin_j_pat, this usually indicates there are bad Electrolytic Capacitors on the motherboard.
Specifically Radial Aluminum Electrolytic Capacitors, and used in the motherboard voltage regulator circuit.
Part of what the motherboard voltage regulator circuit does is to regulate voltage to the Processor.
A Processor must have a steady, 'clean' supply of voltage, and it must stay within a certain specified range.
Too little, and the Processor turns off. (BIOS turns the Processor off)
Look closely for visual signs of bad 'Caps'.
(Bad Electrolytic Capacitors)
Visual Signs of Capacitor Failure,
http://www.capacitorlab.com/visible-failures/
Demonstration of bad caps in the motherboard voltage regulator circuit,
http://www.youtube.com/watch?v=KN6_-8fYHo0
(Starts at 0:04)
Post back your diagnosis in a Comment.
Regards,
joecoolvette
[ Radial Aluminum Electrolytic Capacitors,
http://www.mouser.com/Passive-Components/Capacitors/Aluminum-Electrolytic-Capacitors/Aluminum-Electrolytic-Capacitors-Leaded/_/N-75hqw?Keyword=radial+aluminum+electrolytic+capacitor&FS=True
Oct 25, 2010 | ASUS P5PE-VM Motherboard
Replaced Gateway 105552 Foxconn C51GU01 Motherboard with another
Are you sure it is a good MB? If so double check all connections and try again. If you still have problems post back and let me know if you are getting any beeps at startup.
Jul 07, 2010 | Gateway GT5058 Desktop PC
What are the compatible processor and video card?
Refer this for processor : http://www.asrock.com/mb/cpu.asp?Model=P4VM800
Graphics : Slot Type: AGP8X/4X slot, Voltage: 1.5V you can find this type of graphics card in the market.. but you need to let the vendors know what type of slot you want. Good luck..
Apr 29, 2010 | Asrock P4VM800 Motherboard
Processor Compatability
Yes you can, it seems to support a wide variety of things, here is my source.
1. Socket 7 for Intel MMX, AMD K6 -2, K6 -3, IBM /Cyrix , IDT processors
2. Supports CPU multiplier 1.5/2.0....../6.0 for future processors
3. 66/75*/83*/95/100/105*/110*/115*/120*/125*/130*/135*/140* MHz FSB
4. CPU voltage 1.3V~3.5V
Hope this answers it!
Oct 09, 2008 | Gigabyte GA-5AX Motherboard
Asrock P4i65G motherboard/CPU
Hi Rlforeard, yes the BX80546PG3000E is compatible with the motherboard P4I65G.
http://www.alvio.com/product_view.aspx?product_ID=61048&source_ID=froogle
Here is the list from Asrock. CPU's supported for the Asrock P4I65G board. You will find you can go higher.
http://www.asrock.com/mb/cpu.asp?Model=P4I65G&s=478
Good Luck!
Mike
Jun 02, 2008 | Asrock Computers & Internet
EliteGroup P4VMM2 Motherboard Logo
592 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
