Question about MSI KM4M-L Motherboard
I've put it to AGP in my BIOS but its still doesn't work
I've a MSI KM4M-L. I've change Init display to AGP to disable my onboard graphic card but when i connect my AGP card, my monitor doesn't receives any signal...
    President:
  • 2,351 Answers
It is possible that the AGP slot is dirty/dusty from non use over time. Use alcohol dripped onto a cotton swab & clean the copper connectors within the AGP slot. Blow is out using canned air. If the back side of you're AGP card has more than one output.
Ex: DVI, VGA or S-Video. Try hooking you're monitor to another output. (You may need an adapter to convert the out going signal). The AGP card would include an adapter to allow VGA to DVI. Here is a pic to help you understand.
http://www.csncables.com/Cables-to-Go-27596-GY1420.html
Also check the AGP card. Some need additional power. If so there will be a power input. It can vary from a small power cord just like a floppy drive or look just like an IDE power connector.
Luck!
Mike
Posted on Jun 09, 2008
How do i disable onboard video on a intel d865glc motherboard?
A couple things to try:
  1. Most important, check with Intel's support site to see if you have the latest version of the BIOS.
  2. Boot to the BIOS: Choose "Configuration", then "Video", choose "Enable if Primary" or if you're feeling brave choose to Disable it entirely. WARNING: DON'T do this until your other card is working properly! You've been warned!
  3. While still in BIOS: Choose "Configuration", then "Video", choose "AGP" if available, or "Auto" if AGP is not an option.
Information from Intel support website.
Oct 21, 2012 | Gigabyte GV-N76G256D-RH GeForce 7600GS,...
Disable onboard graphics of my PCChips M825LU motherboard?
Yes its a BIOS setting that you have to change. Usually you change from on-board to AGP settings or plug the graphics card in, take out the motherboard battery and the power cord from the back, leave it for 20 minutes and put them all back again.
This will reset the BIOS and should auto detect the AGP graphics card. You will however need to set the date and time but you can do that from Windows.
Regards.
Jun 28, 2010 | PC Chips Computers & Internet
Installed a new Saphirre Radeon x1650 512mb, 128bit, AGP 8x card. But I am not seeing a significant increase over the onboard graphics. The card install sheet says to Disable the onboard video, but I don't...
In your BIOS on the main screen choose INTEGRATED PERIPHERIALS (get a copy of your manual here if you don't have one), then go to INIT DISPLAY FIRST, and choose AGP. It's not clear from the manual if AGP is an available option, choose PCI slot if it is not. ECS is notoriously sloppy with their BIOS programming.
While you are in the BIOS, under ADVANCED CHIPSET FEATURES choose AGP &P2P BRIDGE CONTROL then make sure your AGP DATA RATE is set to auto.
Apr 16, 2009 | EliteGroup 661FX-M7 (661FXM7V11)...
No display with AGP card
Re Instal the video Card
that what i thinksss
Oct 04, 2008 | MSI MS-6390 (-6390-010) Motherboard
HOW TO DISABLE MY ONBOARD GRAPHIC CARD??
For user BIOS21 & julio1963,
How to enable you're (Add-in AGP video card) & disable the onboard, integrated S3 graphics UniChrome 2D/3D PCI graphics card.
Enter you're bios. Open you're user manual to page 3-13. Integrated Peripherals. Go to, Init display first. Set to AGP.
(Not to PCI). That is all you need to change. The MSI bios will than see you're add in AGP card & automatically disable the PCI S3 graphics, (Onboard) card.
Enjoy!
If I can help you further, feel free to post here.
Please, each user's vote this issue as a fix, if this helped you to get you're bios to see you're new AGP graphics cards.
Mike
May 31, 2008 | MSI KM4M-L Motherboard
Need help
You need to enter your motherboards bios. As the system starts up press the Delete key every two seconds. Hopefully you'll have video doing this. If you do not have video display. You'll have to remove the new video card for a short while. Again enter your bios. Still have your manual? If not click the link & download it here. http://www.foxconnchannel.com/EN-US/support/downloads.aspx?ProductModel=865G7MC-ES&TypeID=en-gb0000001
Enter Advanced Chipset Features
Goto pg. 33
On-Chip VGA (Default: Enabled). Disable this.
Init Display First (Default: Onboard/AGP) Change to AGP/Onboard. The AGP is to load first before the onboard.
Save & shut down the system. Clean out the AGP slot. There can be a dust build up from not using it. Canned air works well.
Leave the side case off untill your sure the 7600 is running correctly.
Get to know your board alittle. Read the manual a wee bit.
Good Luck! Enjoy!
please vote
Feb 15, 2008 | Foxconn (865G7MC-ES) Motherboard
How to disable onboard VGA
I believe if you install an AGP card the onboard VGA is supposed to be automatically disabled. Did you buy an AGP card?
Nov 28, 2007 | Foxconn P4M800P7MA-RS2 Motherboard
MSI KM4M-L Motherboard Logo
88 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
