Question about Toyotomi TID-2400 Air Conditioner
The "tank full" light flashing
I inherited a Toyotomi TID-2400 ac unit, without a manual. I tried running it last night. It cooled for maybe an hour, then the "flashing" light came on. Whenver I try to turn it on, the "flashing" light comes on. I filled the tank with water, but to no avail. Without a manual, I have no clue what I should be doing. Any thoughts?
Dear-heart, the tank should be EMPTY...when it's full the machine shuts off to keep from over flowing.
Dump the water out and try again. The "flashing light" is to tell you the tank is full of condensate water and needs to be emptied.
In hot, humid climes this will happen often. Many models can be hosed for continuous operation.
Good luck
Anakron
Posted on Jun 23, 2009
You can find a user manual at http://www.toyotomiusa.com/products/manuals/TID-2400%20(Type%20A,%20B)%20-%2020456095%20-%20Multi%20Lingual.pdf
Posted on Jun 09, 2008
  • Lkelchy Jun 09, 2008
    Again, the place to find the user manual is http://tinyurl.com/5uoeoj. Or just go tohttp://www.toyotomiusa.com and your unit's manual there under Portable Air Conditioners.
    Meanwhile, I believe what you need to do is empty the tank. The unit produces water as it cools.
How do I recharge freon on a toyotomi TID 1800 unit?
You can't. You have to be licensed to use and dispense refrigerant gasses. 'Freon' went out years ago. Look in Yellow Pages for someone local.
Oct 10, 2016 | Toyotomi TID-1800 Air Conditioner
How do I drain water from a toyotomi portable ac unit
1. put it on higher position near water drainage, window...etc
2. make hole in water tank
3. put tube in hole and lead tube in drainage or outside (hole in frame of window recommended for long term use). Fix tube with glue
4. take care that water tank is higher than end of the tube
5. done
Jul 06, 2014 | Toyotomi TAD-T40LW 14000 BTU Portable Air...
My Toyotomi TAD-30F 'tank full' light keeps coming on despite my emptying the tank daily.
Check and see if the light is activated by a float switch. If it is it may be sticking. Your owners manual may have a clue.
Jul 11, 2012 | Toyotomi TAD-30F Portable Air Conditioner
Ac unit keeps reading fl or full. every 2-3 hours. auto clean button drains out about 1/4 a gallon of water and then stops draining. turn back on ac & repeat process every 2-3 hours. I have tried...
After reading over the Owner's Manual for your unit, I wonder if you are operating it in the Cool & Dry Mode. If that's the case, the dehumidifier is in operation, which would account for having to drain the unit every 2 to 3 hours. Ideally, the Cool and Dry Mode should only be operated for about an hour, when the unit is first started . Removing the humidity will allow the AC function to cool more effectively. But, it is not necessary for it to remain in Cool & Dry mode all the time. Because the AC itself unit will remove some humidity too.
Hope this helped you to troubleshoot and solve the issue of having to drain the unit every 2 to 3 hours
Jun 27, 2011 | LG LP1200DXR Portable Air Conditioner
My 1800 will put out ac and then will go off
Check an error code displayed?
If unit stops immediately after you switch on, fan motor mechanism locked. Check motor and PCB.
If unit stops after few seconds, check coil and room air sensor and replace if it's defective.Helpful?
Jan 19, 2011 | Toyotomi TID-1800 Air Conditioner
Btu of Dimplex Dac 3400/Toyotomi TID-1200 please
It is a 3400BTU unit--Checked from my own unit.
Cheers,
Tony
Sep 09, 2010 | Toyotomi TID-1200 Air Conditioner
Diminished capacity. Have had it on high for over
You probably have a dirty coil... this is the most common problem with inefficiently operating units.
do you change your filter or clean it often? how old is the unit? do you smoke inside that room? are there any animals that live in there? how clean is the room on a scale of 1 to 10.
Oct 10, 2009 | Toyotomi TID-1800 Air Conditioner
Both Lights flashing and fridge not getting cold
I turned the fridge and freezer off using the circular dials, I then turned the unit off at the mains. Left it for a few minutes and then turned the power back on. I then turned the circular dials to "max" and then depressed the super cool and super freeze buttons to turn this facility on. This time they came on normally (not flashing) and no alarm sounded. The fridge and freezer then started to get cold. Once the unit had been running for several hours I then turned the dials to the 3/4 mark and depressed the super cool and super freeze buttons again to turn them off. Over night the fridge and the freezer appear to be working properly so I hope that my problem is solved. Maybe the unit just needed to "settle" before being switched on?
Sep 03, 2009 | Freezers
TOYO TA-09CHS aircon problem
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem.
Jun 09, 2009 | Toyotomi TIN/TIG-329D Air Conditioner
Toyo Aircon. Starts perfectly. Runs for approx 5 min and then the yellow "timer" light starts flashing and machine stops working. Green power light on...yellow timer light flashing. When you switch unit...
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem. Good luck!
Dec 28, 2008 | Toyotomi TIN/TIG-329D Air Conditioner
Toyotomi TID-2400 Air Conditioner Logo
561 people viewed this question
Top Toyotomi Heating & Cooling Experts
hmca
Level 1 Expert
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Toyotomi Heating and Cooling Expert? Answer questions, earn points and help others
