Question about Gateway FPD1975W 19" LCD Monitor
Thin yellow line on the right of the LCD Screen
I have a TFT LCD Monitor and currently I am running Vista Ultimate. Suddenly a thin yellow line appeared... at first intermittent and then stayed on for some time... then the line flickers some times. The line is on the right hand side about 1.5 inches from edge. Any help will be appreciated.
Thanks
Rolando
    Champion:
  • 220 Answers
If it's a straight line from top to bottom panel could be defective.Not much you can do as cost of panel will compare with a new monitor.
Samir
Posted on Jun 16, 2008
I have a thin yellow line running from top to bottom about 10 inches from the left side, what's wrong?
This can be due to faulty LCD driver IC which creates a noise bar and is shown. Check the cords to the display and also the ground connection to the display. If this is good then the IC can be faulty.
Dec 15, 2011 | Hanns.G Corporation JW-199DPB 19" LCD...
My syncmaster has a pencil thin yellow line that runs from top to bottom of the screen that has only just appeared. how can you fix it?
You have failing monitor due to the TFT driving circuits, see the pictures in my troubleshooting guide to see if it the same as you see in your monitor.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Oct 01, 2010 | Samsung SyncMaster 940MW 19" LCD Monitor
Car TFT LCD monitor with only an s-video cable input??
A bit late on this! You will need a multi cable for the unit. It connects with the cable on the monitor and the other end has several terminals, usually like so.... NTSC video, audio, bat positive and battery negative. Could also be left and right audio.
Jul 15, 2009 | Car Audio & Video
Hi i have the above laptop and its been more than a year since i am using it. Suddenly there was green vertical line which came on my screen.I thought it would go away but instead after a week there was...
Have a friend had this issue on his older laptop (more than 10 green lines near center). The TFT/LCD is damaged. Replace is the only thing you can do. But the cost may get you half a netbook.
Or you can stick with using External Monitor like a desktop replacement.
Apr 11, 2009 | Compaq Presario Laptop
2 thin vertical line on lcd monitor
The thin ribbon that connects the board on the back of the lcd screen to the front glass of the lcd screen got damaged.
It wraps around the top of the screen and is very thin and can be easily damaged.
May be from old age and heat at the top of the screen or it could have gotten hit at the top.
If you keep pushing it in and out you may damage another one and make another line.
The cheapest way to repair this is to replace the lcd screen with a good used one because trying to find a shop to try to repair it would cost more than a new monitor.
Sorry there isn't an easy fix to this.
Fran
Mar 29, 2009 | Taxan Crystalvision 680 TCO 99-S 15" LCD...
all those sounding intelligent and saying that replacing lcd hardware will fix the problem probably didnt have the problem themseleves . i had exactly same problem with samsung syncmaster 2043swx monitor . i just restarted and booted into safe mode ( by pressing F8 key at startup ) tried changing reolution in display settings . rebooted in normal mode and asll lines are gone and never appear again . i am uisng windows Vista . so i think it is probably a driver glitch something .
Jul 07, 2008 | LG Flatron L1951S 19" LCD Flat Panel...
LCD monitor problem
what is the solution for this? my husband just turned his pc on when we got home and there are line blue lines running up n down in the black
Oct 11, 2007 | Computers & Internet
On screen thin yellow and blue vertical lines.
Unfortunately the LCD is going faulty.. one or more of the "Driver" transistors that operates the LCD elements RGB, have faulted ON.. perhaps this link may help fix it. Otherwise :( http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
Apr 21, 2007 | NEC LCD
Gateway FPD1975W 19" LCD Monitor Logo
444 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
