Question about Goldstar R8000 Air Conditioner
Where can i get a window mount for goldstar r8000
I was given a goldstar r8000 ac however they did not have a window mount. is it possible to get one somewhere?
I got hold of company and they are goin to take care of it ty willie
Posted on Jun 09, 2008
Our AC is 10 years old and keeps conking out. If I turn it off for about half an hour it will come back and work for several hours, sometimes more. I'm wondering if it needs coolant, and if so, what...
R134a is the only refrigerant that is approved, now. Unless you have all the specialized equipment to drain the system and capture the remaining freon, as well as the gauges and lines required to recharge the system, it's best left to the pros to recharge the compressor.
Jul 18, 2011 | Goldstar R8000 Air Conditioner
Should the vent be opened or closed when air is on.
If you live in Canada or far north where the outside air is cooler than the inside then open the vent and get the free Yankee air conditioning. If you live anywhere south of the salt line you need that vent closed tight.
Jul 16, 2011 | Goldstar R8000 Air Conditioner
My Goldstar has started squeeking... not vibrating... squeeking. Any suggestions? It sounds like something needs some WD-40 sprayed on it.
sound to me like the fan motors squeeking may need a little lube these motors are sealed to protect them from the elements it is possible that a lube port exsists on rear of the motor it will have a little plastic plug in it you can oil it there. a good one to use is zoom spout oiler hardwre store may have it wd 40 not good for this app. wont last. if not an old trick i do is tilt the unit with the shaft and condenser fan facing up and put just a couple drops on the shaft you will see it run in DONT USE TO MUCH CAN DAMAGE MOTOR so be careful this should help.
Jul 11, 2010 | Goldstar R8000 Air Conditioner
I need to see the securest possible places to attach the given hardware so it doesn't fall out of the window and keeps insects and the hot air out of the room. Helpful to see the pictorial directions...
hi ,back mounts are the best an will give you that security you need to insure the unit will not come out ,some of the assembly materials are there but some extras possibly would have to be add . thanks
May 15, 2010 | Goldstar M6004R Air Conditioner
Air conditioner
Clean YouFront Grill Filter or Clean Evoporator Coil By Water Pressure
Jun 30, 2008 | Goldstar R8000 Air Conditioner
Running Compressor Intermittently
replace the thermastat it has a bad set of contacts
May 05, 2008 | Goldstar R8000 Air Conditioner
Installing
Turn the curtain and bracket so when mounted to the ac the window will close behind it. Hope this helps. Thx RepairUSA
Jul 30, 2007 | Goldstar R5050 Air Conditioner
Room air conditioner
the unit needs to be tipped outward so that the lowest point of the unit is actually outside the window.
Jun 03, 2007 | Goldstar R8000 Air Conditioner
Goldstar R8000 Air Conditioner Logo
122 people viewed this question
Top Goldstar Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Dan Webster
Dan Webster
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
