Question about Jenn-Air 24 in. JDB2100AW Dishwasher
Jenn-Air JDB2100AWS - Heater doesn't turn off
I picked up a Jenn-Air JDB2100AWS for free - the problem with it (as I was told) is that the heater (cal-rod) never shut off and over heated the unit. The sound deadening insulation (mastic type material bonded to the outside of the steel tub) was melted away in some areas. I re-adhered the sound deadening insulation using a heat gun and ran the unit (hooked up the electrical and filled it with water by hand) - it appears to operate fine (pumps out okay, cal-rod works, rinses / spins inside, etc).
Any ideas how I can fix the system so that the cal-rod shuts off at the appropriate time? Is there a thermostat to replace or should I just replace the circuit board? I have no problem replacing a few parts to insure that I've covered the problem so that it's not a fire hazard.
Thanks.
2 Suggested Answers
Sea Breeze
  • 4655 Answers
SOURCE: jenn air 24 in jdb2100aws
Link below has everything you need to get answers. Hope this helps.
http://personafile.com/Jenn-Air-Dishwasher-JDB2100AWS-P0719881000055.htm
Posted on Feb 02, 2009
Screws falling out of track
Add some lock tight to your screws and reinstall......Hope this helps.
Jul 04, 2012 | Jenn-Air 24 in. JDB2100AWS Built-in...
Dishwasher is not draining
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
Please note that dishwashers don't drain out the complete water such that heating element doesn
Oct 20, 2010 | Jenn-Air 24 in. JDB2100AWS Built-in...
Jenn Air ElectrCook top One of the cook top heater is not working
well it can only be a few things on a cooktop... u either have a bad element or a bad switch.......usually on most to replace either u must lift top up and out and remove the screws all the way round to open unit up...hope this helps let me know how it goes
Feb 26, 2010 | Cooktops
Warm hinged seal on Jenn-Air french door refrigerator
there is a heater runs through there that keeps the seals dry so they dont mold from condensation from opening the doors its called a mullon heater
Jan 29, 2009 | Jenn-Air JCD2295HES Side by Side...
I have a 2006 honda Element
replace the heater core
Dec 20, 2008 | 2006 Honda Element
Re: Refrigator will not stay cold
defrost problems are caused by 3 things
bad: 1) defrost timer/ timer board 2) defrost heater (in freezer) or burnt wire going to the heater 3) bi-metal thermostat (round metal piece attached to the coils with     at least 2 wires going to it)
a good technician can test components without the machine running. all you need is a simple $5 meter any tech that gets angry, show him/her the door!
Jun 15, 2008 | Jenn-Air JCD2389G Side by Side...
Jenn-Air 24 in. JDB2100AW Dishwasher Logo
125 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
