Question about LG Dryers
Tromm DLE5955 dryer less than 3 months old. Flow sense light continues to show 2 bars even though venting was checked and is clear. Yesterday, cooling light started to come on during the cycle and stay lit during the entire cycle. Clothes are damp at end of cycle.
  • 3 more comments
  • silchad Jun 08, 2008
    I stated in the problem that the duct, etc are clean and clear. The lint screen is obviously the first thing anyone would check and I clean if after every load. The problem is the flow sensor and the cooling light.
  • silchad Jun 11, 2008
    It's a dryer not a washer. Thanks.
  • Anonymous Mar 12, 2014
    whirlpool cabrio dryer: sensor light (overheat). Comes on during dry cycle. Have checked vent flow and had all vents cleaned out. What next
  • Anonymous Mar 17, 2014
    My Samsung dryers starts, vent clean.. cooling cycle stays on
  • Anonymous Mar 23, 2014
    the dryer will not heat up when started the cooling cycle stays lit
    President:
  • 2,712 Answers
Found this on another site:
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
However, since you stated that this unit is less than 3 months old, I wouldn't try to attempt to open the unit. It is still under warranty and you should excercise your warranty options (Thats what you are paying extra for!)
Best to contact your point of purchase and inform them of this issue.
Hope that helps! If you found my answer to be of any help, kindly take a moment to "Accept" my solution. Should you have any further queries, kindly post back and I will try to assist you further as best I can.
Cheers!
IrishDruid.
Posted on Jun 11, 2008
  • Swilin Sampson
    Swilin Sampson Jun 11, 2008
    Like I said, please contact the shop, as your unit is still under warranty. Thats your easiest and cheapest option :)
    Brigadier General:
  • 3,614 Answers
First lets identify the problem.. did the washer still start to spin and do the its works to cycle and rotate the tub...?
-0r- did the washer didn't start at all & get no function to make the washer in it's work.. & got this error..?
Again... what kind of error did you see / happen / occur, during the time you start the operation...
thank you.
    Sergeant:
    Champion:
  • 230 Answers
There may be some connections left inside or this may be due to the problem with the thermistor so check ....i think checking by own may not be a risky one so go with near service centers
  • balachander megavarnam
    balachander megavarnam Jun 11, 2008
    thanks for using fixya
    you may press the accept button on my solution if you are satisfied
    Genius:
  • 3,422 Answers
HI,
Clean the lint screen/filter before or after drying each load of clothes. If clothing is still damp at the end of a typical drying cycle or drying requires longer times than normal, this may be a sign that the lint screen or the exhaust duct is blocked.
Please don't forget to rate or accept the solution.
Posted on Jun 08, 2008
    Guru:
  • 1,894 Answers
Did u do a hard reseet>?
  • 1 more comment
  • dewan nafees ahmed Jun 08, 2008
    else this may be the thermistor problem which has died and failing to detect the temperature.
    else the circuit board has got some error(which can be cleared by resets) which prevents to analyze the temperature inside.
    try to do a hard reset and see.
    if it is not fixed means it can be the thermistor problem
    to fix the components u must be well experienced in electronics.
    else its risky to do by yourself.
  • sportster Aug 14, 2012
    exactly how do you do the hard reset. My friends LG DLE 5595W will not turn off.
Why would check vent light go on after replacing sensor and computer
Is the dryer vent blocked with lint? If there is a restriction in air flow in the vent system, the dryer will stop. Make sure the vent path is completely clean even in the wall where the vent hose connects.
Oct 07, 2016 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Our new lg dryer model #DLE1310w is not drying properly. We have 6 medium side towels that are not very wet in the dryer even on the hottest setting it is taking two cycles to dry the towels. When we...
Recheck the vent all the way to the outside and make sure the vent hose is not smashed behind the dryer.
Long time to dry complaints almost always are due to a restricted vent.
Remove vent to dryer and test a wet load if they dry ok then the house vent is at fault.
Jan 17, 2010 | LG Dryers
Dryer keeps drying and getting too hot
Check the dryer vent .The vent is stopped up,in the vent,or in the inside of dryer,in the lint hopper.Clean it out and unstop the dryer,and the vent.
Oct 10, 2009 | Whirlpool LER5636P Electric Dryer
LG TROMM Front Load Dryer / Not drying clothes
check the vent or condensor depending on what type of dryer.
Sep 28, 2009 | Dryers
Dryer flow sensor shows 4 bars
lint trap holder has got some lint overflow caught down inside it ,past lint screen , I use a piece of small pool pump hose taped to the end of a normal vacuum to suck it out
May 08, 2009 | LG DLE5955 Dryer
Items in dryer are not quite dry, cool down cycle is real short, heat is maintained in dryer when it stops and wrinkles clothes. Cool down cycle went from 4 minutes down to one, skipping 3 and 2. Same...
check and make sure it has a clear clean vent.no kinks in vent hose.if yours vents thru roof then you may want a chimney sweep to come and sweep your vent out.if it goes thru a wall check and make sure know blockage.
Mar 08, 2009 | LG DLE5955 Dryer
DLE5955 Tromm Dryer. We have had this dryer for 3 months. The cooling light has started to come on during the entire cycle and stays lit. Clothes are not drying as quickly as before. They are damp at...
Sounds like your outside vent is plugging up. Go outside your house and check for lint build up and just pull it loose with your fingers or a shop vac.
If it's not obviously plugged from outside, feel the volume it should be significant. If it's very weak (while running of course) your ductwork may be plugged elsewhere, for example at an elbow, or the joint between a flex hose and the actual duct.
Jun 08, 2008 | LG Dryers
Roper dryer
if you are sure vent is ok ..did you try a load with vent disconnected??...there is a chance there is something blocking air flow in lint screen/blower housing ..remove the 2 screws under filter remove all back screws remove 4 screws holding blower housing in place ..you then can pull complete housing out back
May 18, 2008 | Roper REX4634KQ Electric Dryer
LG Tromm dryer now takes two cycles to dry a load
The problem with the LG tromm dryers are seemingly two fold.
1. The dryer stops heating and drying the cloths. I found out AFTER HAVING IT SERVICED TWICE AND WAITING A MONTH FOR A NON ESSENTIAL PART. The problem turned out to be the dryer vent going from the wall to the outside was severly clogged. Once this was corrected the dryer worked great.
2. The second issue probably is a design issue in that a large amount of lint seems to get by the lint filter and ends up in the vent that the dryer is connected to and goes out side the house. In my case I have a long dryer vent imbeded into the wall to the exterior, in a shorter vent this probably wouldn't be an issue.
Dec 20, 2007 | Dryers
Dryers Logo
562 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
