Question about Frigidaire GLTF2940ES Front Load Washer
Clothes stay wet
Looks like my pumps going does not drain? Mildew in the ring leaves clothes smelling bad. Its only 6 months old dont think I am even going to fix it. No frigidaire products for me any more learned my lesson. Solution is in the manufactures court shold have looked here before I bought.
    President:
  • 1,294 Answers
Click on 'smell', tags above, there are a lot of solutions here, to this common problem. You'll find one or two to solve your prob surely.
Posted on Jun 12, 2008
  • prem mathew Jun 12, 2008
    For machine drainage:
    Check your exit hose spigot, it may be clogged. This is if your filter is all clean (ref manual) There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it (maximum 7 inches). Snaking out your standpipe & drain would be good too.
Bad smell in Bosch nexxt WFMC3200 washer
I have this problem with my Siemens machine, it is due to mainly running low temp washes and bateria building up in the hoses etc. (more prevalent if the machine is connected directly to the sink and not on a stand pipe). I run a 90 degree cycle every 4 weeks with the machine empty except for two capfuls of baby sterilisng fluid (approx half a mug) I buy stores own as it is cheaper than miltons. The first time I did mine I ran the cycle twice to be sure it was cleared out. My machine is six years old and the first smelly signs were when it was about a year old, I run the maintenance wash religiously ever 4 weeks and run a machine descaler such as oust thru every 4-6 months. Hope this helps. Roni. (ps don't be tempted to use bleach as it foams up and can cause more problems!!)
Jul 06, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Tip
Get rid of mildew safely, fast and cheap.wont stain cloths.
Your car got wet when the widow broke & now it stinks inside. My motor coach stinks because the roof was leaking water. The house stinks because the roof leaks.
HERE IS HOW TO FIX IT LIKE NEW FOR UNDER $12.00
first, fix where ever the leak is. NOw your couch,chair,rug,car seat & rugs,clothes,bed whatever, stinks because mold,mildew & fungus is growing all over.
depending on the size of the area buy 1 gallon,2 gallons or 3 gallons for large rooms,motor coaches, etc of WHITE VINEGAR which usually costs $2.25 to 3.00
per gallon. Spray lots on anything that is mildewed, moldy of has fungus growing.
the white vinegar will kill mold,mildew and fungus, within 30 minutes ,on contact.
The white vinegar will not stain clothes,carpets ,car seats or uphostered chairs however, i would keep it away from finely finished woods as it might possibly affect the fine finish. It probably wont, but test a small area that is not conspicious, just in case there is any reaction.
the white vinegar is often used in salid dressings , so aside from the room or car or your clothes smelling like salid dressing for a couple of days , no other side effects. the smell goes away, even from areas that you drenched in white vinegar, in a tops of 3 weeks. If you need the smell to go away faster, open all windows and direct a 20 inch box fan at the smelly area. anyway,the vinegar smells a lot better than the mold & mildew. It will save your cloths,your bed,your car, your interior rooms in your house, basements,garages, wood sheds, even wood lumber, that has been left outside too long, as long as the wood is not rotten.
The easiest way to apply the white vinegar is full strength and just pour the white vinegar right from the bottle into a 1 gallon pump up ortho sprayer, and spray your mildew room,rug,car seats,motor coach,basement,clothes or whatever. I has two rooms in my house get a good soaking in that big hurricane 2 years ago, sandy, i think it was called, and 3 days later the mildew smell was so bad i couldn't stay in either room. So I let everything in the room have it ,liberly, except for the tv set,which i kept dry.
The next day,i could only smell the mildew very faintly and the vinegar a lot,so i opened the windows and turned the 20 inch box fan on. I let the windows open 24 hours with the box fan on, after 24 hours, i could still smell a little vinegar,so i turned off the fan but left the windows open for another day. I was able to go in & watch tv again, but had some of the vinegar smell, not bad, but i kept looking for a salid to eat. 2 weeks later,the vinegar smell was completely gone but i noticed a faint mildew smell from the rug, so i gave the rug an even better soaking with vinegar. I had not applied enough vinegar to the rug to get down into the underpading where some mildew had survived and started to grow again. after the second application to the rug, It again took 3 weeks for the vinegar smell to disappear but the mildew smell was gone forever. The vinegar did not stain anything and i even applied *** to cloths that had gotten mildewy smelling in a leaky closet. 24 hours after i sprayed the clothes,i washed them and am wearing one of the shirts,restored to like new, as i type this. So,sometimes,you need a second application. sometimes you dont.one spray will do if you dont have rug underpading that needs to be really soaked good.
I have used the white vinegar on lumber left outside,sprayed it good and came back in 3 hours ,after it dried and started cutting the wood to fit on my mail box mounting. This stuff really works good.try it and i am sure ,you will like it.
Cheapest way to apply white vinegar is to empty your windex bottle into a jar,fill the windex bottle with white vinegar and have fun pumping the trigger about 400
times. works good for small areas if you dont have arthuritis in your hands.
on Oct 12, 2013 | Bloom Daisy Flowers Pink and White 12...
Our washer smells like mildew or mold whats up?
is it fully draining? old water will start to cause this. wash ur clothes and immediately dry them. dont leave wet clothes in the washer over a days period. hope i helped
Mar 12, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Washer makes clothes smell like dog
Hello there:
please follow these simple steps
Instructions Things You'll Need:
  1. Step 1 Balance your washing machine. Standing water breeds mildew and mold. A washing machine that isn't level to the ground stands a higher chance of not draining completely. Take a level and place it on the top of the machine along the front from side to side and then again along the side from front to back. If the machine is very off, you can adjust the feet to compensate or add something under one of the feet if it is not flat against the ground. Portable washing machines are especially prone to have standing water because they are moved around and not leveled each time.
  2. Step 2 Promptly remove your clothes at the end of a wash cycle. If you regularly leave the damp clothes in the washing machine for an extended period at the end of the cycle, you will have mildew in your clothes and your machine. The same is true if you put clean clothes in the dryer and they are not completely dry when the cycle ends and you don't go back for a few days to pull them out. Damp clothes in an enclosed space for days will mildew.
  3. Step 3 Leave your washing machine door open in between uses which gives the machine the opportunity to fully dry out.
  4. Step 4 Use white distilled vinegar in an empty machine. Run a load with only hot water and two cups of vinegar to clean out the machine and freshen the scent. Vinegar naturally eliminates odors and reduces the buildup of soap residue in the washer which contributes to mildew development. You can also add baking soda and/or bleach to the load for both their sanitizing properties as well as assisting in ridding the smell of mildew.
  5. Step 5 Regularly use vinegar when you wash your clothes. Add 1 cup of white distilled vinegar to the last rinse cycle. Vinegar has acidic properties but it is mild enough that it will not harm your fabric. It does dissolve alkalines in laundry detergent which makes for cleaner and softer clothes. The reduction of detergent buildup in your machine will help to also reduce the incidence of mildew.
  6. Step 6 If you have a front load washer, they are particularly prone to mildew and mold. Follow the manufacturers suggestion as to how much and what type of detergent should be used. It is generally less than the traditional top load washing machines. Once again, additional soap residue helps to breed mold and mildew. Also, pull the seals back from around the door and make sure there isn't a build up underneath them that needs to be cleaned out.
  7. Step 7 Finally, if you have done all of the above and nothing seems to work there are commercial products available that are recommended.
Dec 26, 2009 | Samsung WF338AAB 4.0 cu. ft. Front Load...
Clothes smell bad if not removed right away they have to be washed again like a mildew smell
You have probably left some clothes inside overnight and need to clean your washer.
There are some tablets you can buy at most home improvement and discount department stores that will do the job, but you can also run a load through with white clothes, hot water, and a bit of extra bleach. You could also run a load with just bleach and soap.
Don't go overboard with the bleach, a little goes a long way. If you double the amount you might normally use that will be plenty. No more than a half cup.
But also keep in mind that if you leave clothes in overnight, there will be a smell when you take them out. Wet fabric in the dark is one of the best places around for mildew to grow.
Sep 01, 2009 | Maytag Neptune FAV6800AW Top Load Washer
LG washing machine has AWFUL mildew smell
Don't know if this is the same as your problem, but I had a Kenmore washer, (made by Whirlpool) that did the same thing. It was a high efficiency model without an agitator. I finally found out that this type of washer never drains completely but always has some water left in it. This water is somewhere internal that cannot be seen unless the machine is taken apart. That water goes bad and stinks. Everything smelled like mildew and for some while my husband thought I was was washing clothes and leaving them in until they dried. I ended up having to just buy a new machine and when the stinky washer was taken away, just tilting it caused all this foul water to come out everywhere. Also I found this on the internet http://www.consumeraffairs.com/homeowners/lg_washing_machine.html
scroll down and see how other people feel about this machine. I decided that instead of buying the newest, latest, greatest, with all the bells and whistles appliances, from now on I will buy the time tested, plain jane models.
Jun 02, 2009 | LG WM-2277HW Front Load Washer
Same here. We bought ours January 2005. Love the machines and take great care of them, too. Then the smell in the washer which seemed to affect certain clothes, like thick sweat pants and t-shirts (they smelled really "sour"). After doing some searches I found on this site where someone had recommended using a product called Affresh. I figured I might as well try it since my other attempts failed. This really worked for me. I bought it at Home Depot for $7 for a pkg of 3. I used 3 tablets per their directions, as this was my first time using it (afterwards they recommend using only 1 tablet per month). I was totally amazed as the smell was gone. I hope it works for you, too!
Oct 05, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Clothes/towels smell like mildew
Front load washers are so tight ( to seal in water ) that they tend to leave water in door gaskets and other places.. This water gets stagnant and can build up mildew etc..Home depot and other home goods stores sells a product called AFRESH and you use it about once a month ( with no clothes in washer).. It does help a bit..
Other techniques you can try would be to wipe down the gasket around the door opening after a wash is complete and to leave the door open between washes to let it air dry.. You should be using HE type laundry detergent and very little of it ( sveral drops is enough per load)..
hope that helps you...
Aug 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Admiral Washer smells like mildew
yes it could . If you are trying to pump the water 7 feet or more above the floor then it will at the end of the cycle get air into the drain hose causing cavatation, the result when the machines stops is the water running back down the drain hose back into the tub and that is what causes the musty smell.
Lower the drain if possible
Apr 10, 2008 | Admiral AW22 Top Load Washer
Smells of mildew and so do clothes
If the odor does not go away, it is probably time to change the rubber door boot, or you have something stuck in the drain. Take a good look at the rubber around the door. If it has mildew spots and/or mold, it generally won't go away. Pull the rubber back a bit and look BEHIND the boot as well. You may have some lost items stuck in the boot causing the odor. Last of all, UNPLUG the washer and remove the lower kick panel under the door by removing the three 7mm screws and check the drain pump for foreign objects. There's only one pump inside the washer so it won't be too hard to find. It is usually white in color and has a screw off access cover. There is a bit of residual water that remains in the wash tub all the time. You will need to drain this first or you will have a mess to clean up. You can use some towels or use a shop vac. If you use towels, lay them down around the drain pump and remove the access cover. If you use a shop vac, pull all the residual water from the wash tub through the drain line. Sometimes this pump will build up with all kinds of scunge from soap residue and/or foreign object getting caught. Clean it out real well and run the washer on a bleach cycle with the hottest water setting you have. Let me know if any of this helps you. If you decide to change to door boot, post a response to this solution and I will give you step-by-step procedures.
Aug 26, 2007 | Kenmore Elite 45986 Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
73 people viewed this question
Top Frigidaire Washing Machines Experts
Electrolux
Electrolux
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
