Question about LG Dryers
DLE5955 Tromm Dryer. We have had this dryer for 3 months. The cooling light has started to come on during the entire cycle and stays lit. Clothes are not drying as quickly as before. They are damp at the end of the cycle. Lint filter and dryer vents checked and okay.
  • 1 more comment
  • Anonymous Sep 14, 2008
    The same problem has presnted itself on my LG model DLE5977 electric dryer. The "cooling indicator stays on for all cycles, sensor-dry or manual. Clothes take far too long to dry.
  • Tekjoedj Dec 01, 2008
    I have been using an LG modle DLE5977W and the Cooling light is always on and the clothes take way too long to dry.
  • Anonymous Mar 28, 2014
  • 4 Answers
Sounds like your outside vent is plugging up. Go outside your house and check for lint build up and just pull it loose with your fingers or a shop vac.
If it's not obviously plugged from outside, feel the volume it should be significant. If it's very weak (while running of course) your ductwork may be plugged elsewhere, for example at an elbow, or the joint between a flex hose and the actual duct.
Posted on Jun 26, 2008
Cooling light stays on during dry cycle. no heat is to dry clothes. I've switched the circut breaker numerous times and unplugged the unit many times also to "reset" . What's next..
Try a timed dry cycle instead of an automatic cycle. If that works, then you will need to clean off the moisture detection bars inside the dryer to get the auto cycle to work again. Look for two curved metal bars, about 3/16 inch wide and 4 inches long, about an inch apart, located just inside the front of the dryer, near the right side of the lint filter. (you'll have to stick your head in the dryer drum to see them) Often times, use of dryer sheets will result in a waxy coating forming on these bars, preventing the dryer from detecting the moisture in the clothes. The dryer sees no moisture, it goes into the cool down mode and then stops. Clean the bars off, and you should be back in the laundry business.
Feb 05, 2011 | LG DLE7177 Dryer
Whirlpool Cabrio dryer gas does not stay lit after a few minutes.
It sounds like your solenoid coil(s) might be no good. Easy fix and not very expensive.
Jan 11, 2018 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
My lg tromm DLG69885 gas dryer is not heating; otherwise it works fine. Dry light flashes cooling light stays on solid
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
May 20, 2010 | LG DLG5932W Gas Dryer
LG TROMM Front Load Dryer / Not drying clothes
check the vent or condensor depending on what type of dryer.
Sep 28, 2009 | Dryers
Items in dryer are not quite dry, cool down cycle is real short, heat is maintained in dryer when it stops and wrinkles clothes. Cool down cycle went from 4 minutes down to one, skipping 3 and 2. Same...
check and make sure it has a clear clean kinks in vent hose.if yours vents thru roof then you may want a chimney sweep to come and sweep your vent out.if it goes thru a wall check and make sure know blockage.
Mar 08, 2009 | LG DLE5955 Dryer
Clothes are taking 3 cycles to dry and cooling light on front wont shut off
The vent is clogged.  To make sure, disconnect the vent from the dryer and run the dryer normally.  If your clothes dry normally, then have a professional vent cleaning company take care of the vent.
The cooling light will always stay on during the run.  When it is blinking, the heat has stopped and is in the cooling process.
If there is no heating, you have a problem with the high limit switch or something else electrical and needs to be addressed by a qualified LG technician.
Oct 22, 2007 | LG DLE2512W Electric Dryer
Dryers Logo
833 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Dryer Expert? Answer questions, earn points and help others
